### Description
Starting yesterday (Aug 5th) librespot stopped allowing tracks t…o be played. Devices still could connect to the librespot instance but playing any tracks would cause the player to rotate through songs, never actually playing anything. Logs show the following error message:
[2025-08-06T16:43:01Z INFO librespot_core::spclient] Resolved "gew1-spclient.spotify.com:443" as spclient access point
[2025-08-06T16:43:02Z INFO librespot_core::spclient] Resolved "gew4-spclient.spotify.com:443" as spclient access point
[2025-08-06T16:43:03Z INFO librespot_core::spclient] Resolved "guc3-spclient.spotify.com:443" as spclient access point
[2025-08-06T16:43:03Z ERROR librespot_playback::player] Unable to load audio item: Error { kind: Unavailable, error: StatusCode(500) }
This also seems to correspond with the sunsetting of the Spotify's V2 Ads API: https://developer.spotify.com/documentation/ads-api.
### Version
Dev branch: be37402
### How to reproduce
Steps to reproduce the behavior in librespot e.g.
1. Launch librespot in release mode with no additional parameters except "--name"
2. Connect with Spotify Connect on iPhone Spotify app (Have not tested on android)
3. In the client, select a playlist and play from the playlist
4. Then, scroll to bottom and select a song from the "Recommended Songs" section
5. Selected song does not play
### Log
[2025-08-06T17:16:21Z INFO librespot] librespot 0.6.0-dev be37402 (Built on 2025-08-06, Build ID: tJ5Uubmn, Profile: release)
[2025-08-06T17:16:21Z TRACE librespot] Command line argument(s):
[2025-08-06T17:16:21Z TRACE librespot] v
[2025-08-06T17:16:21Z TRACE librespot] name "test"
[2025-08-06T17:16:21Z DEBUG librespot_core::session] new Session
[2025-08-06T17:16:21Z DEBUG librespot_discovery::server] Zeroconf server listening on 0.0.0.0:36803
[2025-08-06T17:16:21Z INFO librespot_playback::mixer::softmixer] Mixing with softvol and volume control: Log(60.0)
[2025-08-06T17:16:21Z DEBUG librespot_playback::player] new Player [0]
[2025-08-06T17:16:21Z INFO librespot_playback::convert] Converting with ditherer: tpdf
[2025-08-06T17:16:21Z INFO librespot_playback::audio_backend::rodio] Using Rodio sink with format S16 and cpal host: ALSA
[2025-08-06T17:16:21Z INFO librespot_playback::audio_backend::rodio] Using audio device: default
[2025-08-06T17:16:21Z DEBUG librespot_playback::audio_backend::rodio] Rodio sink was created
[2025-08-06T17:16:27Z DEBUG librespot_discovery::server] POST "/" {}
[2025-08-06T17:16:27Z DEBUG librespot_core::session] Shutdown: Invalidating session
[2025-08-06T17:16:27Z DEBUG librespot::component] new MercuryManager
[2025-08-06T17:16:27Z DEBUG librespot::component] new ChannelManager
[2025-08-06T17:16:27Z DEBUG librespot_core::session] new Session
[2025-08-06T17:16:27Z DEBUG librespot_connect::spirc] new Spirc[0]
[2025-08-06T17:16:27Z DEBUG librespot_playback::player] command=SetSession
[2025-08-06T17:16:27Z DEBUG librespot_core::session] drop Session
[2025-08-06T17:16:27Z DEBUG librespot::component] drop ChannelManager
[2025-08-06T17:16:27Z DEBUG librespot::component] drop MercuryManager
[2025-08-06T17:16:27Z DEBUG librespot::component] new DealerManager
[2025-08-06T17:16:27Z DEBUG librespot::component] new SpClient
[2025-08-06T17:16:27Z DEBUG librespot_core::spclient] Client token unavailable or expired, requesting new token.
[2025-08-06T17:16:27Z DEBUG librespot_core::http_client] Requesting https://clienttoken.spotify.com/v1/clienttoken
[2025-08-06T17:16:27Z DEBUG librespot_core::spclient] Received a granted token
[2025-08-06T17:16:27Z TRACE librespot_core::spclient] Got client token: GrantedTokenResponse { token: "AADhjKnrrmw0g92Ln4jWcpUBz+kl1q0cZPOTVGGIMf0GN8PTYART58Ob4kE51TlcV67vvkApoNXONr6dvJfpzd6qLzQOv6BH3d44CsRHF90MyTWWO87VeHSzUw/x/zmyxYrzRah6SH6ZAQ4a165nD+Omf8YZnYP1XbDak2rGmR2S67Q8ABxPuJeQaROkNZt91Cuuz8wxHUVhAkMvR9JNzs0R8fp3dLY9eMlsch5bn1jMFqfsDP19rfgJZ4IceYmRrgExASx9xY24ttz5cqDy90hv9zDuN4seTPEOOoiduXy0F56FF7BW/rEd2YBpB1nLk1RHeOxWjcM=", expires_after_seconds: 1216800, refresh_after_seconds: 1209600, domains: [TokenDomain { domain: "spotify.com", special_fields: SpecialFields { unknown_fields: UnknownFields { fields: None }, cached_size: CachedSize { size: 0 } } }, TokenDomain { domain: "spotify.net", special_fields: SpecialFields { unknown_fields: UnknownFields { fields: None }, cached_size: CachedSize { size: 0 } } }], special_fields: SpecialFields { unknown_fields: UnknownFields { fields: None }, cached_size: CachedSize { size: 0 } } }
[2025-08-06T17:16:27Z DEBUG librespot::component] new ApResolver
[2025-08-06T17:16:27Z DEBUG librespot_core::http_client] Requesting https://apresolve.spotify.com/?type=accesspoint&type=dealer&type=spclient
[2025-08-06T17:16:27Z INFO librespot_core::session] Connecting to AP "ap-guc3.spotify.com:4070"
[2025-08-06T17:16:28Z DEBUG librespot_core::connection] Connection to "ap-guc3.spotify.com:4070" failed: Connection refused (os error 111)
[2025-08-06T17:16:28Z DEBUG librespot_core::connection] Retry access point...
[2025-08-06T17:16:28Z DEBUG librespot_core::connection] Connection to AP established.
[2025-08-06T17:16:28Z DEBUG librespot_core::connection] Authenticating with AP using AUTHENTICATION_STORED_SPOTIFY_CREDENTIALS
[2025-08-06T17:16:28Z INFO librespot_core::session] Authenticated as '1219828745' !
[2025-08-06T17:16:28Z DEBUG librespot::component] new Login5Manager
[2025-08-06T17:16:28Z DEBUG librespot_core::http_client] Requesting https://login5.spotify.com/v3/login
[2025-08-06T17:16:28Z TRACE librespot_core::session] Received Ping
[2025-08-06T17:16:28Z TRACE librespot_core::session] keep-alive state: PendingPong, timeout in 60.0
[2025-08-06T17:16:28Z DEBUG librespot_core::session] Session strong=5 weak=6
[2025-08-06T17:16:28Z INFO librespot_core::session] Country: "US"
[2025-08-06T17:16:28Z TRACE librespot_core::session] Received product info: {...}
[2025-08-06T17:16:28Z DEBUG librespot::component] new MercuryManager
[2025-08-06T17:16:28Z TRACE librespot_core::mercury] mercury response <hm://pusher/v1/connections/YTk0YThmZTVjY2IxOWJhNjFjNGMwODczZDM5MWU5ODc5ODJmYmJkMytBUCt0Y3A6Ly8wYWIxNDhlOS5pcC5ndWMzLnNwb3RpZnkubmV0OjUwMjcrN0U2QjE2MTkzNThCODU2NzNCM0Y0MzIwNjc4QjhBQzFCMURGRkU4MUM2N0UxRDU5OEFDMEY5QzE2OEZGMzQxRA%3D%3D> is handled by dealer
[2025-08-06T17:16:28Z TRACE librespot_core::login5] Got auth token: Token { access_token: "BQB2o7tVgByewM5xiLfZODhlDdOodOX12vMgp1PZlDZldrilB2QqOHqoUKjmfm9ykj8i9vPZaYuvi73EWwerAA2pQ7588JAiuit5fiNHX-myb5IqaQiQBid4ZKyAvGW05ikb7Bs4dwg--1B4iLpPqbeWU8Ots-6nMntnfPi-gmxqwzYQ2OIcs2CCICTy6p8HTIWIDdzKNZlKi7IDokhcHN6iMtDQMSFMyzWvZW62M4gq5UxX_gG_cck3I-b5Fht9vFEZFgtXbJKd0S-OKp0kosIw1rgAcCiRHOkvAiz7RnAT_R562Lhw7mbSg7uLu0MuWBekzHrLK5It3mApNa5nud6YVlFUTNJeegpybUOF9-KY64GPEBbct4qepb2ZITLiY5J0OYIy3RaQxw", expires_in: 3600s, token_type: "Bearer", scopes: [], timestamp: Instant { tv_sec: 749357, tv_nsec: 102916569 } }
[2025-08-06T17:16:28Z DEBUG librespot_connect::spirc] SpircTask::set_volume(0)
[2025-08-06T17:16:28Z DEBUG librespot_playback::player] command=AddEventSender
[2025-08-06T17:16:28Z DEBUG librespot_core::dealer::manager] Launching dealer
[2025-08-06T17:16:28Z TRACE librespot_connect::spirc] Received connection ID update: "MzI2ZTNmZWEtMDE0OS00ZDY5LTg5MTMtYTMyYjJmYWQ2ZTY0K2RlYWxlcit0Y3A6Ly8wYWIxNDhkMy5pcC5ndWMzLnNwb3RpZnkubmV0OjU3MDArREJGMzFCNjBGMTFEOEYxNjYyRjEyMEU4MDY0RkJBMDkwRUZENjJBQzY4NDQ4MkIyRTJEOTYyMDA5ODNEMEJGNw=="
[2025-08-06T17:16:28Z INFO librespot_core::spclient] Resolved "guc3-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:28Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=402916273
[2025-08-06T17:16:28Z TRACE librespot_core::dealer] Sent ping
[2025-08-06T17:16:29Z TRACE librespot_core::dealer] Received pong
[2025-08-06T17:16:29Z DEBUG librespot_connect::spirc] successfully put connect state for a94a8fe5ccb19ba61c4c0873d391e987982fbbd3 with connection-id MzI2ZTNmZWEtMDE0OS00ZDY5LTg5MTMtYTMyYjJmYWQ2ZTY0K2RlYWxlcit0Y3A6Ly8wYWIxNDhkMy5pcC5ndWMzLnNwb3RpZnkubmV0OjU3MDArREJGMzFCNjBGMTFEOEYxNjYyRjEyMEU4MDY0RkJBMDkwRUZENjJBQzY4NDQ4MkIyRTJEOTYyMDA5ODNEMEJGNw==
[2025-08-06T17:16:29Z INFO librespot_connect::spirc] active device is <> with session <2OYm1jZc6ckmcLXZGjWmQG>
[2025-08-06T17:16:29Z TRACE librespot_core::dealer] dealer request hm://connect-state/v1/player/command
[2025-08-06T17:16:29Z TRACE librespot_core::dealer::protocol] message was sent with gzip encoding
[2025-08-06T17:16:29Z TRACE librespot_core::dealer::protocol] websocket request: Object {...}
[2025-08-06T17:16:29Z DEBUG librespot_connect::spirc] handling: 'endpoint: transfer' from 76d8b73a7d83cbe17bbf6da2f5c4d5fa9334660e
[2025-08-06T17:16:29Z WARN librespot_connect::state::context] couldn't load context info because: context is not available. type: Default
[2025-08-06T17:16:29Z DEBUG librespot_connect::spirc] found initial track <spotify:track:7dWCYXkZMWnCKIcxmEC8Rc>
[2025-08-06T17:16:29Z TRACE librespot_connect::context_resolver] added spotify:user:1219828745:collection to resolver queue
[2025-08-06T17:16:29Z DEBUG librespot_connect::context_resolver] update for resolve_uri: <Some("spotify:user:1219828745:collection")>, context_uri: <spotify:user:1219828745:collection>, update: <Default> is already added
[2025-08-06T17:16:29Z TRACE librespot_connect::state::transfer] shuffle_seed: <Some("stable:619768a1")> (spotify), <None> (own)
[2025-08-06T17:16:29Z DEBUG librespot_connect::state] updated connect play status playing: true, paused: true, buffering: true
[2025-08-06T17:16:29Z DEBUG librespot_playback::player] command=Load(SpotifyId("spotify:track:7dWCYXkZMWnCKIcxmEC8Rc"), false, 0)
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=3087464660
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=2912894540
[2025-08-06T17:16:29Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=1171717386
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/context-resolve/v1/spotify:user:1219828745:collection
[2025-08-06T17:16:29Z TRACE librespot_connect::spirc] ==> LoadingPause
[2025-08-06T17:16:29Z DEBUG librespot_core::dealer::manager] replying to ws request: Success
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=4278651821
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=1744511082
[2025-08-06T17:16:29Z INFO librespot_core::spclient] Resolved "gae2-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:29Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=2894824682
[2025-08-06T17:16:30Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/context-resolve/v1/spotify:user:1219828745:collection
[2025-08-06T17:16:30Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:30Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=1603512908
[2025-08-06T17:16:30Z DEBUG librespot_connect::spirc] handling next context Some("spotify:user:1219828745:collection")
[2025-08-06T17:16:30Z DEBUG librespot_connect::state::context] updated context Default to <Some("spotify:user:1219828745:collection")> (502 tracks)
[2025-08-06T17:16:30Z DEBUG librespot_connect::context_resolver] last item of type <Default>, finishing state setup
[2025-08-06T17:16:30Z DEBUG librespot_connect::state::transfer] active track is <spotify:track:7dWCYXkZMWnCKIcxmEC8Rc> with index Ok(146) in Default context, has 502 tracks
[2025-08-06T17:16:30Z DEBUG librespot_connect::state::transfer] setting up next and prev: index is at Some(146) while shuffle true
[2025-08-06T17:16:30Z DEBUG librespot_connect::state::tracks] set track to: spotify:track:7dWCYXkZMWnCKIcxmEC8Rc at 146 of 502 tracks
[2025-08-06T17:16:30Z DEBUG librespot_connect::state::tracks] finished filling up next_tracks (80)
[2025-08-06T17:16:30Z DEBUG librespot_connect::state] updated connect play status playing: true, paused: true, buffering: true
[2025-08-06T17:16:30Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=4095084933
[2025-08-06T17:16:30Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=2899168007
[2025-08-06T17:16:30Z INFO librespot_core::spclient] Resolved "gue1-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:30Z DEBUG librespot_core::http_client] Requesting https://gue1-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=4039170469
[2025-08-06T17:16:30Z DEBUG librespot_core::http_client] Requesting https://gue1-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=2312688876
[2025-08-06T17:16:31Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:31Z DEBUG librespot_core::http_client] Requesting https://gue1-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=3781198736
[2025-08-06T17:16:31Z INFO librespot_core::spclient] Resolved "gew4-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:31Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/ed63725a623c43f9b321d8821c274fd2?product=0&country=US&salt=1575241319
[2025-08-06T17:16:31Z ERROR librespot_playback::player] Unable to load audio item: Error { kind: Unavailable, error: StatusCode(500) }
[2025-08-06T17:16:31Z ERROR librespot_playback::player] Skipping to next track, unable to load track <SpotifyId("spotify:track:7dWCYXkZMWnCKIcxmEC8Rc")>: ()
[2025-08-06T17:16:31Z DEBUG librespot_connect::state::tracks] marking spotify:track:7dWCYXkZMWnCKIcxmEC8Rc as unavailable
[2025-08-06T17:16:31Z DEBUG librespot_connect::state::tracks] finished filling up next_tracks (80)
[2025-08-06T17:16:31Z DEBUG librespot_connect::state] updated connect play status playing: true, paused: true, buffering: true
[2025-08-06T17:16:31Z DEBUG librespot_playback::player] command=Preload(SpotifyId("spotify:track:4hR3E8w9JI1eTvH0vuVvun"))
[2025-08-06T17:16:31Z DEBUG librespot_playback::player] Preloading track
[2025-08-06T17:16:31Z DEBUG librespot_playback::player] command=Load(SpotifyId("spotify:track:4hR3E8w9JI1eTvH0vuVvun"), false, 0)
[2025-08-06T17:16:31Z TRACE librespot_connect::spirc] ==> LoadingPause
[2025-08-06T17:16:31Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=758789378
[2025-08-06T17:16:31Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=742004312
[2025-08-06T17:16:31Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=3558800872
[2025-08-06T17:16:32Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:32Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=686760185
[2025-08-06T17:16:32Z DEBUG librespot_core::http_client] Requesting https://apresolve.spotify.com/?type=accesspoint&type=dealer&type=spclient
[2025-08-06T17:16:32Z INFO librespot_core::spclient] Resolved "guc3-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:32Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=1279317125
[2025-08-06T17:16:32Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=964409184
[2025-08-06T17:16:32Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=2135893380
[2025-08-06T17:16:32Z INFO librespot_core::spclient] Resolved "gae2-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:32Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=7894501
[2025-08-06T17:16:33Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:33Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=4080441059
[2025-08-06T17:16:33Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=1972310619
[2025-08-06T17:16:33Z INFO librespot_core::spclient] Resolved "gew1-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:33Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/metadata/4/track/8ce3dc930191437d9875537e5f4a578f?product=0&country=US&salt=2732354491
[2025-08-06T17:16:33Z ERROR librespot_playback::player] Unable to load audio item: Error { kind: Unavailable, error: StatusCode(500) }
[2025-08-06T17:16:33Z ERROR librespot_playback::player] Skipping to next track, unable to load track <SpotifyId("spotify:track:4hR3E8w9JI1eTvH0vuVvun")>: ()
[2025-08-06T17:16:33Z DEBUG librespot_connect::state::tracks] marking spotify:track:4hR3E8w9JI1eTvH0vuVvun as unavailable
[2025-08-06T17:16:33Z DEBUG librespot_connect::state::tracks] finished filling up next_tracks (80)
[2025-08-06T17:16:33Z DEBUG librespot_playback::player] command=Preload(SpotifyId("spotify:track:3P6zjYxB5sqnNGyd3QRBDz"))
[2025-08-06T17:16:33Z DEBUG librespot_connect::state] updated connect play status playing: true, paused: true, buffering: true
[2025-08-06T17:16:33Z DEBUG librespot_playback::player] Preloading track
[2025-08-06T17:16:33Z DEBUG librespot_playback::player] command=Load(SpotifyId("spotify:track:3P6zjYxB5sqnNGyd3QRBDz"), false, 0)
[2025-08-06T17:16:33Z TRACE librespot_connect::spirc] ==> LoadingPause
[2025-08-06T17:16:33Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/metadata/4/track/7da7756d55894e87b4531782a4da67a1?product=0&country=US&salt=607883474
[2025-08-06T17:16:34Z DEBUG librespot_connect::state] updated connect play status playing: true, paused: true, buffering: true
[2025-08-06T17:16:34Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=2809328732
[2025-08-06T17:16:34Z TRACE librespot_metadata] Received metadata: Track {...}
[2025-08-06T17:16:34Z INFO librespot_playback::player] Loading <Never Say Die> with Spotify URI <spotify:track:3R2jaCtqawdBv6mZ2Ym7Ty>
[2025-08-06T17:16:34Z WARN librespot_playback::player] <Never Say Die> is not available in any supported format
[2025-08-06T17:16:34Z ERROR librespot_playback::player] Skipping to next track, unable to load track <SpotifyId("spotify:track:3P6zjYxB5sqnNGyd3QRBDz")>: ()
[2025-08-06T17:16:34Z DEBUG librespot_connect::state::tracks] marking spotify:track:3P6zjYxB5sqnNGyd3QRBDz as unavailable
[2025-08-06T17:16:34Z DEBUG librespot_connect::state::tracks] finished filling up next_tracks (80)
[2025-08-06T17:16:34Z DEBUG librespot_playback::player] command=Preload(SpotifyId("spotify:track:6tifCCTIVBLC2TmTquYG7G"))
[2025-08-06T17:16:34Z DEBUG librespot_playback::player] Preloading track
[2025-08-06T17:16:34Z DEBUG librespot_playback::player] command=Load(SpotifyId("spotify:track:6tifCCTIVBLC2TmTquYG7G"), false, 0)
[2025-08-06T17:16:34Z TRACE librespot_connect::spirc] ==> LoadingPause
[2025-08-06T17:16:34Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=2294052662
[2025-08-06T17:16:34Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=717621256
[2025-08-06T17:16:34Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:34Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=1326129676
[2025-08-06T17:16:34Z DEBUG librespot_core::http_client] Requesting https://gew1-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=1182401983
[2025-08-06T17:16:35Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:35Z INFO librespot_core::spclient] Resolved "gew4-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:35Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=22001533
[2025-08-06T17:16:35Z TRACE librespot_core::dealer::protocol] message was sent with gzip encoding
[2025-08-06T17:16:35Z DEBUG librespot_connect::spirc] cluster update: Ok(UNKNOWN_CLUSTER_UPDATE_REASON) from 76d8b73a7d83cbe17bbf6da2f5c4d5fa9334660e, active device: a94a8fe5ccb19ba61c4c0873d391e987982fbbd3
[2025-08-06T17:16:35Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=1777322199
[2025-08-06T17:16:35Z DEBUG librespot_connect::state] updated connect play status playing: true, paused: true, buffering: true
[2025-08-06T17:16:35Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3?product=0&country=US&salt=1666413210
[2025-08-06T17:16:35Z DEBUG librespot_core::http_client] Requesting https://gew4-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=149578250
[2025-08-06T17:16:36Z DEBUG librespot_core::spclient] Error was: Err(Error { kind: Unavailable, error: StatusCode(500) })
[2025-08-06T17:16:36Z DEBUG librespot_core::http_client] Requesting https://apresolve.spotify.com/?type=accesspoint&type=dealer&type=spclient
[2025-08-06T17:16:36Z INFO librespot_core::spclient] Resolved "guc3-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:36Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=2761546402
[2025-08-06T17:16:36Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=3692260121
[2025-08-06T17:16:36Z DEBUG librespot_core::http_client] Requesting https://guc3-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=3791732134
[2025-08-06T17:16:36Z INFO librespot_core::spclient] Resolved "gae2-spclient.spotify.com:443" as spclient access point
[2025-08-06T17:16:36Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/metadata/4/track/d4aa698ffa0e4dafb35e4c2ee7359704?product=0&country=US&salt=3047355305
[2025-08-06T17:16:36Z TRACE librespot_core::dealer::protocol] message was sent with gzip encoding
[2025-08-06T17:16:36Z ERROR librespot_playback::player] Unable to load audio item: Error { kind: Unavailable, error: StatusCode(500) }
[2025-08-06T17:16:36Z ERROR librespot_playback::player] Skipping to next track, unable to load track <SpotifyId("spotify:track:6tifCCTIVBLC2TmTquYG7G")>: ()
[2025-08-06T17:16:36Z DEBUG librespot_connect::spirc] cluster update: Ok(DEVICE_STATE_CHANGED) from 76d8b73a7d83cbe17bbf6da2f5c4d5fa9334660e, active device:
[2025-08-06T17:16:36Z INFO librespot_connect::spirc] device became inactive
[2025-08-06T17:16:36Z WARN librespot_connect::state::context] couldn't load context info because: context is not available. type: Default
[2025-08-06T17:16:36Z DEBUG librespot_core::http_client] Requesting https://gae2-spclient.spotify.com:443/connect-state/v1/devices/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3/inactive?notify=false&product=0&country=US&salt=2296889863
[2025-08-06T17:16:37Z DEBUG librespot_connect::state] reset_playback with active ctx <Default> fill_up ctx <Default>
[2025-08-06T17:16:37Z WARN librespot_connect::spirc] failed filling up next_track during stopping: Invalid state { context is not available. type: Default }
[2025-08-06T17:16:37Z DEBUG librespot_playback::player] command=Stop
[2025-08-06T17:16:37Z DEBUG librespot_connect::state::tracks] marking spotify:track:6tifCCTIVBLC2TmTquYG7G as unavailable
[2025-08-06T17:16:37Z ERROR librespot_connect::spirc] could not dispatch player event: Invalid state { context is not available. type: Default }
[2025-08-06T17:16:37Z TRACE librespot_connect::spirc] ==> Stopped
### Host (what you are running `librespot` on):
- OS: Linux
- Platform: Lenovo T14
### Additional context
