I’m trying to build a simple Swift project on NixOS. Here are the steps to reproduce:
git clone https://github.com/PerfectlySoft/PerfectTemplate.git
cd PerfectTemplate
touch shell.nix
Add shell.nix
with following contents:
with import <nixpkgs> {};
stdenv.mkDerivation {
name = "swift-env";
buildInputs = [
openssl
stdenv
binutils
cmake
pkgconfig
curl
glibc
icu
libblocksruntime
libbsd
libedit
libuuid
libxml2
ncurses
sqlite
swig
Running nix-shell --pure shell.nix
and from there swift build
, gives me:
gcc: error: x86_64-unknown-linux: No such file or directory
gcc: error: unrecognized command line option ‘-target’
gcc: error: unrecognized command line option ‘-fblocks’
gcc: error: unrecognized command line option ‘-fmodules’; did you mean ‘-fmudflap’?
gcc: error: unrecognized command line option ‘-fmodule-name=PerfectCZlib’
gcc: error: unrecognized command line option ‘-fmodules-cache-path=/home/dmi3y/Dev/Swift/PerfectTemplate/.build/x86_64-unknown-linux/debug/ModuleCache’
It seems to me that I’m not using the the right compiler, but I can’t figure out which compiler I should be using. Appreciate any advice here!
