Need help debug protonmail-bridge automation
i have been spend 3 days on this one and cant figure out anymore where is the issue. AERC is my terminal mail client it works on my gmail and other no issues on automation part, but my 4 proton mail accounts dosent work it says no user etc basically it isint running as background.when i stop proton.mail.service manually and run protonmail-bridge –-noninteractive AERC and all accounts works as should so there is just issues on my automation and i cant see it anymmore where and what
{ pkgs, ... }: {
  # 1. VPN (Wait for Network, not Graphical Session)
  systemd.user.services.proton-vpn-autostart = {
    Unit = {
      Description = "Proton VPN Auto-Connect";
      After = [ "network-online.target" ];
      Wants = [ "network-online.target" ];
    Service = {
      ExecStartPre = "${pkgs.coreutils}/bin/sleep 10";
      ExecStart = "${pkgs.proton-vpn-cli}/bin/protonvpn connect -f";
      Restart = "on-failure";
      RestartSec = "15s";
    Install = { WantedBy = [ "default.target" ]; };
  # 1. PROTONMAIL BRIDGE
  systemd.user.services.protonmail-bridge = {
    Unit = {
      Description = "Protonmail Bridge (CLI Background)";
      # Wait for network and VPN
      After = [ "network-online.target" "proton-vpn-autostart.service" ];
      Requires = [ "proton-vpn-autostart.service" ];
    Service = {
      # Use full path and explicit flags
      ExecStart = "${pkgs.protonmail-bridge}/bin/protonmail-bridge --noninteractive --no-window";
      # Crucial: Give the service access to your secrets and the Nix certificate store
      Environment = [
        "DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/%U/bus"
        "PATH=${pkgs.gnome-keyring}/bin:${pkgs.libsecret}/bin:${pkgs.protonmail-bridge}/bin"
        "SSL_CERT_FILE=/etc/ssl/certs/ca-bundle.crt"
      # Persistence settings
      Restart = "always";
      RestartSec = "15s";
      StartLimitIntervalSec = 0;
  # 2. AERC MONITOR
  systemd.user.services.aerc-background = {
    Unit = {
      Description = "Aerc Background Monitor";
      After = [ "protonmail-bridge.service" ];
      Requires = [ "protonmail-bridge.service" ];
    Service = {
      # Increase sleep to ensure Bridge has actually bound to ports 1143/1025
      ExecStartPre = "${pkgs.coreutils}/bin/sleep 15";
      ExecStart = "${pkgs.aerc}/bin/aerc";
      Restart = "always";
      Environment = "DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/%U/bus";
  };  # 4. TRASH CLEANUP
  systemd.user.services.home-trash-cleanup = {
    Unit = { Description = "Daily cleanup of user trash bin"; };
    Service = {
      ExecStart = "${pkgs.trash-cli}/bin/trash-empty 30";
got it running now and all works seems it needs to have access ~/.config/protonmail/bridge/
so now finally i have working logic and it is here if someone needs it
# --- PROTONMAIL BRIDGE ---
  # (Keeping your working Bridge config here for reference)
    Unit = {
      Description = "Protonmail Bridge";
      After = [ "network.target" "hyprland-session.target" ];
    Service = {
      Type = "simple";
      ExecStart = "${pkgs.protonmail-bridge}/bin/protonmail-bridge --noninteractive --no-window --log-level info";
      Environment = [
        "HOME=/home/phatle"
        "XDG_CONFIG_HOME=/home/phatle/.config"
        "PROTONMAIL_BRIDGE_KEYCHAIN=plaintext"
      Restart = "always";
      RestartSec = "10s";
    Install = { WantedBy = [ "hyprland-session.target" ]; };
