Hello, I’m new to nix, it’s been a one-month journey so far, but I love it already. Recently, I created my first flake; it’s almost identical to the “overengineered hello” template from nix flake init
. The script is a maintenance script to help with recurring tasks; also it’s not so useful, it makes me practice, please don’t judge.
Anyway, I need that script installed as part of my configuration for everyday usage, but also part of a nix shell I plan to use for bootstrapping.
For the nix shell, I have absolutely no idea how to install it, as I can’t find a way to add another flake than the nixpkgs one. So that’s the first thing I’d like to find out.
The second thing is about the “regular” install, I found more resources discussing that, but I cannot make it work. I added the repo as a flake:
description = "Nindouja's flake";
outputs = { ... }: {
ninja-script = {
url = "git+https://gitlab.vba.ovh/snippets/3.git";
And to install it like so in home manager (also tried in system config):
{pkgs, ...}: {
home.packages = with pkgs; [
#ninja-script.defaultPackage
In both cases I got this error and I don’t know how to interpret it.
error: attribute 'override' missing
at /nix/store/g861759ghxxwvyfdbv17xf3iahgm8rcb-source/pkgs/stdenv/darwin/default.nix:461:15:
460|
461| ninja = super.ninja.override { buildDocs = false; };
462|
Any help would be greatly appreciated.
I managed to install it !! For future references, I used this syntax in my home/system packages:
ninja.packages.${system}.ninja
(I renamed it from ninja-script to ninja but that’s not relevant; the important part is the ${system} part
I’m gonna start looking to add it to my shell now I have more info. But I still have no idea how to add my flake as an input.
By “nix shell” do you mean a development shell? You would add it the same way you did for home or system packages – add it to nativeBuildInputs
in flake.nix
, like so:
devShells.${system}.default = pkgs.mkShell {
nativeBuildInputs = [ <reference to your custom script> ]; # <- this
In the code from the original post it’s already added to the inputs:
Are you referring to something else as an input, like an override of a package?
When I run nix-shell, nix will load the shell.nix file in the current directoy; but does it execute it in the “context” of the flake.nix in that same directory ? I made the assumption shell.nix was it’s own clustered context ?
That does not seem to be the case, because with that shell.nix file in the same directory as the flake:
{pkgs ? import <nixpkgs> {}}:
with pkgs;
pkgs.mkShell {
packages = [
# Nix
nix
home-manager
# Secrets management
age
sops
ssh-to-age
# Ninja dependencies
git
alejandra
deadnix
# Utilities
vim
wget
jq
yq
unzip
nix-output-monitor # TODO mke it work
Nix cannot find my package. That’s not surprising to me as I have done nothing to make shell.nix aware of my package. For home/system config I inherit it when building my output.
In case it’s not clear, the package I’m providing via flake is in a different repo than my actual config; both have a flake.nix file
The package repo: Sign in · GitLab
The config repo: Nindouja / NixOs · GitLab
Correct, shell.nix
is not flake-aware by itself. devShells
is its analog in flakes.
Technically you can use builtins.getFlake
to extract things from flakes in .nix
files:
# flake.nix
outputs = { self, nixpkgs }: {
packages.x86_64-linux.hello = nixpkgs.legacyPackages.x86_64-linux.hello;
packages.x86_64-linux.default = self.packages.x86_64-linux.hello;
# shell.nix
pkgs ? import <nixpkgs> { },
with pkgs; # NOTE: With scopes have gotchas. See https://nix.dev/guides/best-practices.html#with-scopes
pkgs.mkShell {
packages = [
age # Some sample package from pkgs
(builtins.getFlake "path:////tmp/tmp.4cGlth4cgi").packages.${system}.default # this tmp dir contains flake.nix and shell.nix files
Which results in:
❯ which hello
which: no hello in ...
❯ nix-shell ./shell.nix
❯ which hello
/nix/store/...
But this approach takes <nixpkgs>
reference from channels. If you are using flakes anyway – you probably want devshell if you want to pull in development-only packages.
Perfectly clear !
I saw some mentions of dev shells during my learning but as I’m new I was going one step at a time and wanted to understood nix shells better first. I guess I’ll look into them right now. Thanks a lot !!
I hate when links in frul points to 404 repo, so here is the new link to the flake/script I mentioned above. It was just a snippet but I moved it to an actual repo.
Sorry for the ping, I could not edit my post it seems
