Need help installing flakes
I looked through some documentation including the wiki page, but I can’t figure out how to install flake packages like nix-flatpak. After trying to copy the “getting started” section I got the error undefined variable 'nix-flatpak' under modules = [. I also get the error The option \services.flatpak.packages’ does not exist. With this in myconfiguration.nix`:
services.flatpak.packages = [
    "app.zen_browser.zen"
My flake.nix is below. I don’t know if either the documentation is too scatted, I’m too impatient / lazy to look through enough of it, or both.
    nixpkgs.url = github:NixOS/nixpkgs/nixos-unstable;
    nix-flatpak.url = "github:gmodena/nix-flatpak/?ref=latest";
  outputs = { self, nixpkgs, ... }@inputs: {
    nixosConfigurations.NixOS-MBP = nixpkgs.lib.nixosSystem {
      system = "aarch64-linux";
      modules = [
        nix-flatpak.nixosModules.nix-flatpak
        ./configuration.nix
You’ve just overlooked a word:
  outputs = { self, nixpkgs, nix-flatpak, ... }@inputs: {
      modules = [
        ./configuration.nix
Personally, I would recommend doing this, however; it keeps your flake.nix neater and makes the module system do what the module system is supposed to do:
# flake.nix
      specialArgs.flake-inputs = inputs;
      modules = [
        ./configuration.nix
# configuration.nix
{ flake-inputs, ... }: {
  imports = [
    flake-inputs.nix-flatpak.nixosModules.nix-flatpak
I’ve also quoted your URLs for you.
How would I know what to write for other flakes?
You look at the name in your inputs:
For nixpkgs, for example, it would be flake-inputs.nixpkgs.<whateveryouwanttoaccess>. For your system nixpkgs this isn’t very useful, but if you had a second nixpkgs (e.g. to get unstable) you could grab packages from it that way.
As for the bit after the input name (e.g. .nixosModules.nix-flatpak), there are a number of standardized outputs (most notably for NixOS users, packages, nixosModules, legacyPackages and lib, but there’s also e.g. devShells), and you need to check the documentation of the flake you depend on for the specific name of its module/package/whatever.
See the docs for more details on how flakes work: nix flake - Nix 2.28.1 Reference Manual
