Good Evening, I’m working on packaging onedriver for nixOS.
My derivation is currently as follows:
{stdenv, buildGoModule, fetchFromGitHub, lib, makeWrapper, pkgs, ...}:
{onedriver = buildGoModule rec {
pname = "onedriver";
version = "0.14.0";
src = fetchFromGitHub {
owner = "jstaf";
repo = pname;
rev = "v${version}";
hash = "sha256-Jo+J719mtsDxqwETT80Q0k6t3bhApBEd4v9dR2w81Y0=";
nativeBuildInputs = [
stdenv
makeWrapper
pkgs.gcc
pkgs.libwebkit2gtk-4.0.dev
pkgs.json-glib.dev
buildPhase = ''
make
installPhase = ''
# Custom installation commands, if needed
mkdir -p $out/bin
cp onedriver $out/bin/
meta = with lib; {
description = "onedriver is a native Linux filesystem for Microsoft OneDrive.";
homepage = "https://github.com/jstaf/onedriver";
license = licenses.gpl3;
However, when I use the command nix build --dry-run --file Onedriver.nix onedriver to test this derivation, I get the following error message:
error:
… from call site
at «none»:0: (source not available)
error: function 'anonymous lambda' called without required argument 'stdenv'
at /path/to/file/Onedriver.nix:1:1:
1| {stdenv, buildGoModule, fetchFromGitHub, lib, makeWrapper, pkgs, ...}:
2|
Could someone help me to find the error in my derivation?
Your file defines a function expecting the following args:
it means you have to set all those args in the command:
nix build --dry-run \
--arg stdenv '(import <nixpkgs> {}).stdenv' \
--arg fetchFromGitHub '(import <nixpkgs> {}).fetchFromGitHub' \
Or use callPackage:
--expr '((import <nixpkgs> {}).callPackage ./Onedriver.nix {}).onedriver'
Furthermore, I have a local version here that works (yes, it should have been upstreamed):
{ lib
, buildGoModule
, fetchFromGitHub
, installShellFiles
, pkg-config
, glib-networking
, json-glib
, withGUI ? true
, webkitgtk
, wrapGAppsHook
bins = if withGUI then "onedriver onedriver-launcher" else "onedriver-headless";
buildGoModule rec {
version = "0.12.0";
owner = "jstaf";
repo = "onedriver";
hash = "sha256-KuFJKB2SjCl8UL1GMuLpWMkNmHntMzAl5rHoOeY2fYw=";
vendorSha256 = "sha256-vHmSmluiJdfIvVyAc7Um9v+1I50AGGIYw6la9w8rNso=";
postPatch = ''
substituteInPlace resources/onedriver.desktop \
--replace /usr $out
substituteInPlace resources/onedriver@.service \
--replace /usr/bin/fusermount /run/wrappers/bin/fusermount \
--replace /usr/bin $out/bin
buildInputs = [ glib-networking json-glib ]
++ lib.optional withGUI webkitgtk;
nativeBuildInputs = [ installShellFiles pkg-config ]
++ lib.optional withGUI wrapGAppsHook;
# I couldn't find a way to pass the correct parameter to have it build the
# headless version when using our Go infrastructure, so just use upstream's
# Makefile
buildPhase = ''
runHook preBuild
make ${bins}
runHook postBuild
# the Makefile assumes FHS, so we would have to create a bunch of directories
# for it to work.
installPhase = ''
runHook preInstall
install -Dm555 -t $out/bin ${bins}
install -Dm444 -t $out/share/icons/onedriver resources/*.{png,svg}
install -Dm444 -t $out/share/applications resources/*.desktop
install -Dm444 -t $out/lib/systemd/user resources/*.service
install -Dm444 -t $out/share/doc/onedriver LICENSE *.md
installManPage resources/*.?
runHook postInstall
doCheck = false;
meta = with lib; {
description = "OneDrive file system";
license = licenses.gpl3Only;
maintainers = with maintainers; [ peterhoeg ];
