fetchTarball and other builtin fetchres are not allowed in restricted-eval mode (or rather only specific URLs are allowed for them, which may be empty). In nixpkgs using derivation based fetchers is necessary, like pkgs.fetchzip, pkgs.fetchurl etc.
Derivation based fetchers have the advantage that they’ll be executed at build time, wheras builtin fetchers will fetch at evaluation time. This would be detrimental for nixpkgs, since just planning a build would require downloading all sources which would slow down things on Hydra a lot (especially since evaluation is single threaded).
I just unpacked it manually in the drv. This was for testing anyways and doesn’t need to actually build; eval is the issue.
I’m currently not near the machine where I made those changes but you can just swap out builtins.fetchTarball with fetchurl: fetchurl and call the macport patches with fetchurl in the drv.
Yeah but I don’t see why it shouldn’t just be lazy about fetchTarball too?
error: creating directory '/homeless-shelter': Read-only file system
… while evaluating 'optionalString'
at /nix/store/bj5x5234nnh8khp2vg51alvdcws6a4xi-source/lib/strings.nix:202:5:
201| # String to return if condition is true
202| string: if cond then string else "";
203|
… from call site
at /nix/store/bj5x5234nnh8khp2vg51alvdcws6a4xi-source/pkgs/applications/editors/emacs/generic.nix:124:6:
123|
124| (lib.optionalString (withMacport && !srcRepo) ''
125| cp -r ${macportPatches fetchurl}/. .
… while evaluating the attribute 'postPatch' of the derivation 'emacs-27.2'
at /nix/store/bj5x5234nnh8khp2vg51alvdcws6a4xi-source/pkgs/stdenv/generic/make-derivation.nix:205:7:
204| // (lib.optionalAttrs (attrs ? name || (attrs ? pname && attrs ? version)) {
205| name =
206| let
… while querying the derivation named 'emacs-27.2'
