I know the basics of packaging software with nix (which was enough so far), but I have run into issues trying to package SourceGit, a .NET project. I also opened a package request for it. What I have so far is the following:
{ buildDotnetModule
, fetchFromGitHub
, xorg
buildDotnetModule rec {
pname = "sourcegit";
version = "8.7";
src = fetchFromGitHub {
owner = "sourcegit-scm";
repo = "sourcegit";
rev = "v${version}";
hash = "";
projectFile = "src/SourceGit.csproj";
nugetDeps = ./deps.nix;
# for issue with UI framework, see https://github.com/AvaloniaUI/Avalonia/issues/3020#issuecomment-1902270097
runtimeDeps = with xorg; [
libICE
libSM
libX11
libX11.dev
The way I understood it after reading the NixOS Wiki, I now need to run nix-build -A sourcegit.fetch-deps
to generate the deps.nix
. As all of my NixOS systems use Flakes, I am supposed to use nix build
instead though, which does not have a -A
option. I did not find any way to do this with nix build
But even without that option, running nix build
leads to another issue:
> nix build
error: flake [...] does not provide attribute 'packages.x86_64-linux.default' or 'defaultPackage.x86_64-linux'
I have tried setting outputs.packages.x86_64-linux.default
in my Flake to something like inputs.nixpkgs
, which doesn’t work. I also could not find out what I need to set here to make it work. My flake is here.
So… how can I get this working, ultimately resulting in a working Nix package for SourceGit? Any help appreciated!
I just saw that @TomaSajt opened a PR to close my packaging request, I will close this topic if/when this is merged.
By the way, here’s a simple template flake you can use if you don’t want to use the nixpkgs repo to write your packages:
outputs =
{ self, nixpkgs }:
system = "x86_64-linux";
my-package = pkgs.callPackage ./my-package.nix { };
To build this you should be able to do nix build .#my-package
If you want to be able to build it only using nix build
you can swap
my-package =
to
packages.${system}.default =
Haha, so far I just put my local packages directly in environment.systemPackages
of my NixOS config. That was fine so far, but also a pain when debugging.
Thank you so much! This is really useful to me.
How were you able to generate the deps.nix
though? As said before, I couldn’t figure out how to do it with nix build
The .#my-package
part of the command is the derivation to evaluate. You can change it over to .#my-package.passthru.fetch-deps
. Building this derivation should create a file named result
, which actually is an executable. You can run this with ./result deps.nix
, which should create the deps.nix
file.
A weird thing: when doing this, it will complain that nugetDeps
doesn’t exist, so you’ll need to temporarily set nugetDeps
to any non-null value you’d like (e.g. 1
) so it doesn’t complain and then after generating deps.nix
change nugetDeps
to ./deps.nix
alright, thank you so much! ![:slight_smile: :slight_smile:](https://discourse.nixos.org/images/emoji/twitter/slight_smile.png?v=12)
