Hi, I’ve taken a look at the packaging guide and took some existing nixpkgs for apps written in Go as an example.
I’m trying to pack autobrr and I successfully managed to create a build and run the result, but when visiting the app in the browser I get an internal server error. I’m not sure why, but I’m thinking it’s to do with building the frontend. autobrr uses pnpm, but I couldn’t find easy to understand (for a newb) resources on how to create nixpkgs that involve pnpm.
I’ve gotten this so far:
{ lib, buildGoModule, fetchFromGitHub }:
#with import <nixpkgs> {};
buildGoModule rec {
pname = "autobrr";
version = "1.43.0";
src = fetchFromGitHub {
owner = "autobrr";
repo = "autobrr";
rev = "v${version}";
hash = "sha256-hlQ+rSU9M3P1NytcV9OsdX0VO/O4k6ARSHaz5tgsvv4=";
vendorHash = "sha256-KJeMuB6C/uijuHIKl8LDMa5PMZhU8TJKyj3NZVfrPJE=";
subPackage = [ "cmd/autobrr" "cmd/autobrrctl" ];
CGO_ENABLED = 0;
meta = with lib; {
description = "Modern, easy to use download automation for torrents and usenet.";
homepage = "https://github.com/autobrr/autobrr";
license = lib.licenses.gpl2Only;
maintainers = with lib.maintainers; [ muradbu ];
nix-build -E 'with import <nixpkgs> {}; callPackage ./test.nix {}'
error:
… while calling the 'abort' builtin
at /nix/store/4djy3i4nbcd9rrrx6rvbhl6zdpnd9md9-nixos-24.05/nixos/lib/customisation.nix:269:13:
268| # which is especially relevant with allowAliases = false
269| else abort "lib.customisation.callPackageWith: ${error}";
270|
error: evaluation aborted with the following error message: 'lib.customisation.callPackageWith: Function called without required argument "pnpm" at /home/murad/nixpkgs/pkgs/servers/autobrr/test.nix:6, did you mean "clpm", "epm" or "fnm"?'
I made a temporary test.nix without the Go related things to isolate the problem.
That error means you have a package that callPackage cannot provide, this means your instance of nixpkgs does not provide pnpm. I assume your nixpkgs channel is release-24.05, pnpm was only recently packaged, so it’s only available in nixpkgs-unstable.
callPackageWith is a function used to construct the callPackage function:
callPackage = callPackageWith pkgs;
As a suggestion, you could clone nixpkgs and develop with your package already placed in its correct place (pkgs/by-name/au/autobrr/package.nix). Then build with nix-build -A autobrr.
