The game seems to require java 7 so I used an old version. The game runs if I disable the sound. Otherwise I get an error about OpenAL.
The game ships its own “libopenal64.so” (in native/linux). I’m not sure if I should use it or use nixos.openal.
A “game key” is needed to reach the part where it crashes.
Any ideas?
Should java be able to find the so file with -Djava.library.path=$out/native/linux and --suffix LD_LIBRARY_PATH : $out/native/linux?
The game also ship its own jre. I thought maybe I could try to patchelf it but it was a pita and I’m not sure it would work.
oldPkgs2 = builtins.fetchGit { url = https://github.com/NixOS/nixpkgs-channels.git; ref = "nixos-18.03"; };
oldPkgs = import oldPkgs2 {};
nixpkgs = import <nixpkgs> {};
libPath = with nixpkgs; nixpkgs.stdenv.lib.makeLibraryPath [
libGL
xorg.libX11
xorg.libXcursor
xorg.libXext
xorg.libXrandr
xorg.libXxf86vm
with nixpkgs;
stdenv.mkDerivation {
name = "starsector-0.9a-RC10";
src = fetchurl {
url = http://s3.amazonaws.com/fractalsoftworks/starsector/starsector_linux-0.9a-RC10.zip;
sha256 = "14mlc1xxj3dym0zywgq4qhh6ad9v9ax65rna21i8lymmwasdh8lb";
buildInputs = [
pkgs.unzip
makeWrapper
installPhase = ''
mkdir -p "$out/bin"
cp -r {*.jar,data,graphics,native,sounds} $out/
makeWrapper ${oldPkgs.openjdk7.jre}/bin/java $out/bin/starsector \
--add-flags "-server -XX:CompilerThreadPriority=1 -XX:+CompilerThreadHintNoPreempt -Djava.library.path=$out/native/linux -Xms1536m -Xmx1536m -Xss1024k -classpath janino.jar:commons-compiler.jar:commons-compiler-jdk.jar:starfarer.api.jar:starfarer_obf.jar:jogg-0.0.7.jar:jorbis-0.0.15.jar:json.jar:lwjgl.jar:jinput.jar:log4j-1.2.9.jar:lwjgl_util.jar:fs.sound_obf.jar:fs.common_obf.jar:xstream-1.4.10.jar -Dcom.fs.starfarer.settings.paths.saves=/tmp/start/saves -Dcom.fs.starfarer.settings.paths.screenshots=/tmp/start/screenshots -Dcom.fs.starfarer.settings.paths.mods=/tmp/start/mods -Dcom.fs.starfarer.settings.paths.logs=/tmp/starsector.log com.fs.starfarer.StarfarerLauncher" \
--suffix LD_LIBRARY_PATH : $out/native/linux \
--suffix LD_LIBRARY_PATH : ${libPath}
I also tried patching the so files with:
for exe in $out/native/linux/*.so{,.*} ; do
patchelf --set-rpath "$out/native/linux:${libPath}:${oldPkgs.openjdk7.jre}/lib/openjdk/jre/lib/amd64" "$exe"
done
error init: Could not locate OpenAL library.
2302 [Thread-5] ERROR sound.new - org.lwjgl.LWJGLException: Could not locate OpenAL library.
at org.lwjgl.openal.AL.create(AL.java:156)
at org.lwjgl.openal.AL.create(AL.java:102)
at org.lwjgl.openal.AL.create(AL.java:206)
at sound.new$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sound.new.o00000(Unknown Source)
at com.fs.starfarer.combat.CombatMain.main(Unknown Source)
at com.fs.starfarer.StarfarerLauncher$1.run(Unknown Source)
at java.lang.Thread.run(Thread.java:745)
2369 [Thread-5] ERROR com.fs.starfarer.combat.CombatMain - java.lang.NullPointerException
at sun.awt.X11FontManager.getDefaultPlatformFont(X11FontManager.java:779)
at sun.font.SunFontManager$2.run(SunFontManager.java:433)
at sun.font.SunFontManager.<init>(SunFontManager.java:376)
at sun.awt.X11FontManager.<init>(X11FontManager.java:32)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at java.lang.Class.newInstance(Class.java:383)
at sun.font.FontManagerFactory$1.run(FontManagerFactory.java:83)
at sun.font.FontManagerFactory.getInstance(FontManagerFactory.java:74)
at sun.font.SunFontManager.getInstance(SunFontManager.java:250)
at sun.font.FontDesignMetrics.getMetrics(FontDesignMetrics.java:264)
at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:1030)
at javax.swing.JComponent.getFontMetrics(JComponent.java:1625)
at javax.swing.plaf.basic.BasicGraphicsUtils.getPreferredButtonSize(BasicGraphicsUtils.java:276)
at javax.swing.plaf.basic.BasicButtonUI.getPreferredSize(BasicButtonUI.java:376)
at javax.swing.plaf.basic.BasicButtonUI.getMinimumSize(BasicButtonUI.java:366)
at javax.swing.JComponent.getMinimumSize(JComponent.java:1743)
at javax.swing.plaf.basic.BasicOptionPaneUI.addButtonComponents(BasicOptionPaneUI.java:692)
at javax.swing.plaf.basic.BasicOptionPaneUI.createButtonArea(BasicOptionPaneUI.java:630)
at javax.swing.plaf.basic.BasicOptionPaneUI.installComponents(BasicOptionPaneUI.java:178)
at javax.swing.plaf.basic.BasicOptionPaneUI.installUI(BasicOptionPaneUI.java:141)
at javax.swing.JComponent.setUI(JComponent.java:665)
at javax.swing.JOptionPane.setUI(JOptionPane.java:1861)
at javax.swing.JOptionPane.updateUI(JOptionPane.java:1883)
at javax.swing.JOptionPane.<init>(JOptionPane.java:1846)
at javax.swing.JOptionPane.showOptionDialog(JOptionPane.java:858)
at javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:667)
at javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:638)
at org.lwjgl.J2SESysImplementation.alert(J2SESysImplementation.java:56)
at org.lwjgl.Sys.alert(Sys.java:213)
2377 [Thread-5] ERROR com.fs.starfarer.StarfarerLauncher - java.lang.NullPointerException
Exception in thread "Thread-5" java.lang.NullPointerException
