Hello.
I’m trying to create a derivation for the Pyrebase package.
My problem is that one of the package requirements is gcloud, which has been updated to google-cloud-sdk.
Nix has the google-cloud-sdk package, but when building Pyrebase it shows a error message that the gcloud requirement was not satisfied.
I tried assigning the gcloud variable to the google-cloud-sdk, even though I knew it wouldn’t work.
gcloud ? pkgs.google-cloud-sdk
Any suggestions what I can do?
snowkes
February 7, 2023, 11:35am
3
Hi,
With Pyrebase4 I had the same problem:
No matching distribution found for gcloud>=0.18.3
About firebase-rest-api, the error was different:
FileNotFoundError: [Errno 2] No such file or directory: ‘setup.py’.
This happens because firebase-rest-api has a pyproject.toml instead of a setup.py After adding format=“pyproject” in my derivation I got a exception error, with a list of fails related to:
ModuleNotFoundError: No module named ‘flit_core’
UPDATE: I think I solved this error by adding flit-core to my derivation’s buildInputs. Now I have a version error related to pyjwt. The version available on nixpkgs is 2.5.0 and the firebase-rest-api requirements ask for 3.3.2.
No matching distribution found for python_jwt>=3.3.2
Adding this to the derivation didn’t work either:
prePatch = ‘’
substituteInPlace requirements.txt pyproject.toml
–replace “python_jwt>=3.3.2” “python_jwt>=2.5.0”
I managed to create the firebase-admin package, but it doesn’t fit my need.
Try GitHub - josewails/Pirebase: A simple python wrapper for the Firebase API. instead of Pyrebase4, but remove 'gcloud>=0.18.3',
from setup.py
. Pirebase uses google-cloud-storage
which is the one of the successors of the successor of gcloud
You need to package python-jwt and add it to the buildInputs for pirebase.
Same result. My derivation:
{ pkgs ? import <nixpkgs> {}
, lib ? pkgs.python310Packages.lib
, buildPythonPackage ? pkgs.python310Packages.buildPythonPackage
, fetchPypi ? pkgs.python310Packages.fetchPypi
, requests ? pkgs.python310Packages.requests
, google-auth ? pkgs.python310Packages.google-auth
, requests-toolbelt ? pkgs.python310Packages.requests-toolbelt
, python-jwt ? pkgs.python310Packages.pyjwt
, pycryptodome ? pkgs.python310Packages.pycryptodome
, google-cloud-storage ? pkgs.python310Packages.google-cloud-storage
, sseclient ? pkgs.python310Packages.sseclient
buildPythonPackage rec {
pname = "pirebase";
version = "3.1.29";
src = fetchPypi {
pname = "Pirebase";
inherit version;
sha256 = "17a6dd740f7edf2a07d79a9836763d67a69a862040f0f0b4f9b8e2639bf1b0f8";
propagatedBuildInputs = [
requests
google-auth
requests-toolbelt
python-jwt
pycryptodome
sseclient
postPatch = ''
substituteInPlace setup.py \
--replace "gcloud>=0.18.3" " "
meta = with lib; {
description = "A simple python wrapper for the Firebase API";
homepage = https://github.com/josewails/Pirebase;
license = licenses.mit;
is not python-jwt
. python-jwt
is not packaged in nixpkgs.
So is it not possible to build this derivation?
NobbZ
February 7, 2023, 6:35pm
10
You can package what’s missing.
