Hello!
Basically what the title says; I would appreciate any help in creating my own module which compiles the ZFS kernel module for the linux-surface kernel module by jakeday and qzed. I unfortunately have almost no idea where to begin, except for this reddit thread, which provides a way to override a nixpkg with a custom version.
Thank you kindly for the help!
I’m assuming using the following in the configuration file won’t work, due to both the kernelPackages
not including the nixos-surface
value and the zfs
value not having the correct build implementation in pkgs
, correct?
{ config, ... }:
imports = [ ./hardware-configuration ./nixos-surface/surface.nix ];
boot.kernelPackages = [ surface ];
boot.extraModulePackages = with config.boot.kernelPackages; [ zfs ];
