i want my base config(the one that is booted automatically into) to NOT use the dgpu at all, and i want a specialisation that has nvidia enabled for full power consumption(i have a laptop).
i have attatched both files below.
The problem i am facing is that, the default config is still using nouveau even though it is blacklisted. gaming-time is working well.
# default.nix
boot = {
extraModprobeConfig = lib.mkDefault ''
blacklist nouveau
options nouveau modeset=0
blacklistedKernelModules = lib.mkDefault [
"nouveau"
"nvidia"
"nvidiafb"
"nvidia_drm"
"nvidia-uvm"
"nvidia_modeset"
"nv"
"rivafb"
"rivatv"
"ipmi_msghandler"
"ipmi_devintf"
services.udev.extraRules = lib.mkDefault ''
# Remove NVIDIA USB xHCI Host Controller devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{power/control}="auto", ATTR{remove}="1"
# Remove NVIDIA USB Type-C UCSI devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{power/control}="auto", ATTR{remove}="1"
# Remove NVIDIA Audio devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{power/control}="auto", ATTR{remove}="1"
# Remove NVIDIA VGA/2D controller devices
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x03[0-9]*", ATTR{power/control}="auto", ATTR{remove}="1"
# gamig-time.nix
lib,
pkgs,
config,
specialisation = {
gaming-time.configuration = {
hardware.nvidia-container-toolkit.enable = true;
services.xserver.videoDrivers = lib.mkForce ["nvidia"];
hardware.graphics = {
enable32Bit = true;
extraPackages = with pkgs; [
# https://discourse.nixos.org/t/nvidia-open-breaks-hardware-acceleration/58770/2
nvidia-vaapi-driver
vaapiVdpau
libvdpau
libvdpau-va-gl
vdpauinfo
libva
libva-utils
# https://wiki.nixos.org/wiki/Intel_Graphics
#vpl-gpu-rt
hardware.nvidia = {
# This will no longer be necessary when
# https://github.com/NixOS/nixpkgs/pull/326369 hits stable
#modesetting.enable = true;
modesetting.enable = lib.mkForce true;
dynamicBoost.enable = true;
prime = {
amdgpuBusId = "PCI:5:0:0";
nvidiaBusId = "PCI:1:0:0";
nvidiaSettings = true;
# package = config.boot.kernelPackages.nvidiaPackages.beta;
open = lib.mkForce true; #https://wiki.nixos.org/wiki/NVIDIA#cite_note-1
package = config.boot.kernelPackages.nvidiaPackages.mkDriver {
version = "570.86.16"; # use new 570 drivers
sha256_64bit = "sha256-RWPqS7ZUJH9JEAWlfHLGdqrNlavhaR1xMyzs8lJhy9U=";
openSha256 = "sha256-DuVNA63+pJ8IB7Tw2gM4HbwlOh1bcDg2AN2mbEU9VPE=";
settingsSha256 = "sha256-9rtqh64TyhDF5fFAYiWl3oDHzKJqyOW3abpcf2iNRT8=";
usePersistenced = false;
prime.reverseSync.enable = lib.mkForce true;
powerManagement.enable = lib.mkForce false;
powerManagement.finegrained = lib.mkForce false;
prime.offload = {
enableOffloadCmd = lib.mkForce false;
boot = {
# kernelPackages = lib.mkForce pkgs.linuxKernel.packages.linux_xanmod;
# kernelPackages = pkgs.linuxPackages_6_6; # use 6.6 LTS kernel
kernelParams = lib.mkMerge [
["nvidia-drm.fbdev=1"]
"nvidia.NVreg_UsePageAttributeTable=1" # why this isn't default is beyond me.
"nvidia_modeset.disable_vrr_memclk_switch=1" # stop really high memclk when vrr is in use.
(lib.mkIf config.hardware.nvidia.powerManagement.enable [
"nvidia.NVreg_TemporaryFilePath=/var/tmp" # store on disk, not /tmp which is on RAM
blacklistedKernelModules = ["nouveau"];
kernelModules = ["nvidia-uvm"];
environment = {
systemPackages = (
with pkgs; [
# nvidia-vaapi-driver
# # libva
# libva-utils
# nvidia-utils
# # libvdpau-va-gl
# # vaapiVdpau
# # libva-vdpau-driver
nvtopPackages.full
# nvidia-container-toolkit
# sessionVariables = {
# "__EGL_VENDOR_LIBRARY_FILENAMES" = "${config.hardware.nvidia.package}/share/glvnd/egl_vendor.d/10_nvidia.json";
variables = {
# https://discourse.nixos.org/t/nvidia-open-breaks-hardware-acceleration/58770/12?u=randomizedcoder
# https://gist.github.com/chrisheib/162c8cad466638f568f0fb7e5a6f4f6b#file-config-nix-L193
MOZ_DISABLE_RDD_SANDBOX = "1";
LIBVA_DRIVER_NAME = "nvidia";
GBM_BACKEND = "nvidia-drm";
NVD_BACKEND = "direct";
EGL_PLATFORM = "wayland";
# prevents cursor disappear when using Nvidia drivers
WLR_NO_HARDWARE_CURSORS = "1";
MOZ_ENABLE_WAYLAND = "1";
XDG_SESSION_TYPE = "wayland";
NIXOS_OZONE_WL = "1";
__NV_PRIME_RENDER_OFFLOAD = "1";
__NV_PRIME_RENDER_OFFLOAD_PROVIDER = "NVIDIA-G0";
__GLX_VENDOR_LIBRARY_NAME = "nvidia";
__VK_LAYER_NV_optimus = "NVIDIA_only";
