Need JRE as a dependency for CPLEX package
I need to install CPLEX to compile a project. There is a CPLEX package (the package still needs the binary installer, because its propitiatory software, which is fine for me. I got it on my system). After some fiddling I got so far, to set the environment-variable NIXPKGS_ALLOW_UNFREE=1 and added cplex.releasePath = <path to my installer> to ~/.config/nixpkgs/config.nix. But when I then run nix-shell -p jre cplex I get the error:
  /nix/store/5vh1963xxg4zq47226blhwrd2vag78l3-cplex-128.drv
building '/nix/store/5vh1963xxg4zq47226blhwrd2vag78l3-cplex-128.drv'...
Running phase: unpackPhase
Running phase: patchPhase
Running phase: configurePhase
Running phase: buildPhase
JRE libraries are missing or not compatible....
Exiting....
Running phase: glibPreInstallPhase
Running phase: installPhase
Running phase: dropIconThemeCache
Running phase: glibPreFixupPhase
Running phase: fixupPhase
patchelf: getting info about '/nix/store/xf2nv3chig5wnlch7an1j88ljrkhsz8v-cplex-128/opl/bin/x86-64_linux/oplrun': No such file or directory
error: builder for '/nix/store/5vh1963xxg4zq47226blhwrd2vag78l3-cplex-128.drv' failed with exit code 1;
       last 10 log lines:
       > Exiting....
       For full logs, run 'nix-store -l /nix/store/5vh1963xxg4zq47226blhwrd2vag78l3-cplex-128.drv'.
I guess that I have to install JRE in order to install CPLEX, but that apparently didn’t work. I am new to nix, so please look over my ignorance.
How can I fix the missing JRE in order to install CPLEX?
I first want to test if I can get cplex running in a nix-shell and then provide a shell.nix file in my repository. But I already struggle with getting it working in a nix-shell.
I have the same problem. Any help appreciated.
This would be an issue with the package expression in nixpkgs, though as it’s proprietary and paywalled, I imagine not many people are looking at this and maintaining it…
Understandable, although sad… I desperatly need to make it work for OeGOR Summer School 2024 in just a few days… So I’m currently trying to create a custom flake for the test project provided: See on GitHub. I have the CPLEX installer bin, and now, I need to make it work for the project… which is challenging since the installer bin expects a classic file system.
So I have worked on my custom flake, and I feel I’m getting closer and closer to success. I get the error:
 ❮onyr ★ nixos❯ ❮oegor_column_generation_2024❯❯ nix develop
warning: Git tree '/home/onyr/code/phd/oegor_column_generation_2024' is dirty
error: builder for '/nix/store/sakvgl3ik4kwk4p3ly710r1c748ga6bs-cplex-128.drv' failed with exit code 1;
       last 10 log lines:
       > calling 'envTargetTargetHook' function hook 'make_glib_find_gsettings_schemas' /nix/store/0b03sxzh696k4wlm7bjf7crxb8cjph9j-gtk+-2.24.33
       > calling 'envTargetTargetHook' function hook 'findGdkPixbufLoaders' /nix/store/0b03sxzh696k4wlm7bjf7crxb8cjph9j-gtk+-2.24.33
       > calling 'envTargetTargetHook' function hook 'addPkgToClassPath' /nix/store/kkdmb2qhyprdg9x373hd1bcfxdvkf6r9-libXtst-1.2.4
       > calling 'envTargetTargetHook' function hook 'make_glib_find_gsettings_schemas' /nix/store/kkdmb2qhyprdg9x373hd1bcfxdvkf6r9-libXtst-1.2.4
       > calling 'envTargetTargetHook' function hook 'findGdkPixbufLoaders' /nix/store/kkdmb2qhyprdg9x373hd1bcfxdvkf6r9-libXtst-1.2.4
       > calling 'envTargetTargetHook' function hook 'addPkgToClassPath' /nix/store/acxxrpwzjg7xkhq8jxzasqby1bndnxs3-glibc-locales-2.39-52
       > calling 'envTargetTargetHook' function hook 'make_glib_find_gsettings_schemas' /nix/store/acxxrpwzjg7xkhq8jxzasqby1bndnxs3-glibc-locales-2.39-52
       > calling 'envTargetTargetHook' function hook 'findGdkPixbufLoaders' /nix/store/acxxrpwzjg7xkhq8jxzasqby1bndnxs3-glibc-locales-2.39-52
       > cp: cannot stat '/home/onyr/cplex2210/cplex_studio2210.linux_x86_64.bin': No such file or directory
       For full logs, run 'nix log /nix/store/sakvgl3ik4kwk4p3ly710r1c748ga6bs-cplex-128.drv'.
error: 1 dependencies of derivation '/nix/store/rv1n3hyhsi7ww14sa5d0s90pl75i2zvl-nix-shell-env.drv' failed to build
 ❮onyr ★ nixos❯ ❮oegor_column_generation_2024❯❯ ls /home/onyr/cplex2210/cplex_studio2210.linux_x86_64.bin
I guess this is because flake doesn’t allow the access to a “hard coded” path. How can I fix that ?
EDIT
Ok, so I fixed the issue by making a derivation for the installer file for CPLEX… and now, I feel trapped like Ouroboros…
Exiting....
Going back to CPLEX installer having JRE version or access issues…
EDIT 2:
Apparently, this is related to this known error where the installer needs sudo privileges to make a tmp dir in root… wtf
So I sent an email to the maintainer of the CPLEX nixpkgs (bfortz), let’s see where it goes…
EDIT 3:
I got an answer from bfortz. Apparently this bug has stayed on his task list for around 2 years already. Unfortunatly, he really doesn’t have the time to have a look at it and fix it.
Hints and findings:
Install CPLEX on linux (without administration privileges)
So, I found a way to make CPLEX work on NixOS… using a rather creative method. I freed up some disk space, installed Ubuntu 24.04 LTS, and used it to run the CPLEX installer, deploying the files on my /home partitions. This setup allows me to switch operating systems with minimal hassle. After rebooting into NixOS and modifying some CMakeList variables with the necessary paths, BOOM! It worked :smiley:
I’m documenting this trick for the future, in case anyone else needs to use CPLEX on NixOS and is unable to successfully continue the packaging effort concerning the CPLEX installer and its installation on NixOS.
Finally fixed here:
Amazing, many thanks :slight_smile:
