Neovim :checkhealth problems
health#nvim#check
## Configuration
  - OK: no issues found
## Performance
  - OK: Build type: Release
## Remote Plugins
  - OK: Up to date
## terminal
  - ERROR: command failed: infocmp -L
  - INFO: $VTE_VERSION='6401'
  - INFO: $COLORTERM='truecolor'
health#provider#check
  - ERROR: Failed to run healthcheck for "provider" plugin. Exception:
    function health#check[21]..health#provider#check[4]..<SNR>101_check_ruby[15]..<SNR>101_system, line 11
    Vim(let):E903: Process failed to start: no such file or directory: "/bin/bash"
What can I do about it? What would not work if I don’t fix this errors?
Proper solution:
A) Substitute /bin/bash with store path during plugin build
B) Create a PR to the plugin repo to use /usr/bin/env bash instead
hacky solution:
Do something similar to this https://github.com/gytis-ivaskevicius/nixfiles/blob/6a5d3cd5ea4c4a75481ef28d9d66d4241785beee/config/base-desktop.nix#L15-L17 for /bin/bash
Can you provide some code? I don’t understand what should I do with this line:
  systemd.tmpfiles.rules = [
    "L+ /lib64/ld-linux-x86-64.so.2 - - - - ${pkgs.stdenv.glibc}/lib64/ld-linux-x86-64.so.2"
Rewrite it in a way that it doesn’t link the ld-linux but bash instead.
    "L+ /bin/bash - - - - ${pkgs.bash}/bin/bash"
Should suffice. Though this is really option Z, please try B first and use A to mitigate until the fix has landed.
Do you mean this plugin? GitHub - neovim/neovim-ruby: Ruby support for Neovim
Thanks for the suggestions. I had this problem when trying to run the windows nvim (i.e., the one in nvim-win64.zip) from within cygwin, and this was my solution:
export SHELL=/cygwin64/bin/bash
before starting nvim-qt.exe, or defining it this way:
alias nvim=‘SHELL=/cygwin64/bin/bash ~/pkgs/Neovim/bin/nvim-qt.exe’
But that only worked on nvim-qt.exe, nvim.exe still freezes, but at least one version of nvim runs.
