New to Python, first shell for my dream project 24.11
I’m new to Python, however, I did spend 2 weeks getting NixOS installed, even having to go into windows powershell and clean up the boot record from making so many mistakes at the beginning with google searches and following Gemini/Claude instructions, and got it done lol.
Pretty proud of where I got my configs too at this point, I dropped them at the end so you can be in awe at the power :rofl:
Just want you to know I actually can follow instructions and/or do it myself with a little help :slight_smile:
Quick first question: Do I need flakes enabled to just run a shell because I am getting this:
[cosmic@nixos:~/projects/psychobio_project]$ nix shell
path '/home/cosmic/projects/psychobio_project' does not contain a 'flake.nix', searching up
error: could not find a flake.nix file
[cosmic@nixos:~/projects/psychobio_project]$ nix develop -f shell.nix
error (ignored): error: experimental Nix feature 'flakes' is disabled; add '--extra-experimental-features flakes' to enable it #at this point I enabled flakes in my configuration.nix
[cosmic@nixos:~/projects/psychobio_project]$ nix develop -f shell.nix #hope about to be crushed because I was all caught up and autopilot
error: could not find a flake.nix file #and reality kicks in
All I want to do is run a script on already downloaded XML versions of PubMed papers, and the script I have is designed to operate on python3 with lxml & networkx.
In the docs for 24.11 I see that the python3 installed with the system includes python312, and since I am new, I just put all this in my configuration.nix:
    python3Full #available in nix-env, added in packages for accessability and stability
    python312Packages.biopython #extensive libraries- https://biopython.org/docs/latest/Tutorial/chapter_quick_start.html
    python312Packages.elementpath #https://github.com/sissaschool/elementpath
    python312Packages.networkx #for CAG
    python312Packages.pep8 #https://pep8.readthedocs.io/en/release-1.7.x/
    python312Packages.scikit-bio #r&d/educator tool kit- https://scikit.bio/
    python312Packages.types-lxml #https://github.com/abelcheung/types-lxml
but when I try to run my script, I get this error:
$ python generate_config_from_pubmed.py –input_dir input_pubmed_xml –output_dir config –output_config psychobiotics_config.json [--log generator.log]
  File "/home/cosmic/projects/psychobio_project/generate_config_from_pubmed.py", line 6, in <module>
    from lxml import etree as ET
ModuleNotFoundError: No module named 'lxml'
Now to be honest, I got pointed to this magical post Jack’s Full Solution, and would really love to do that to my system and just not worry about anything, and while that post makes more and more sense to me, I would love to see if anyone could help me understand it a little better?
And then this got shared in case I just wanted to brute force nix to do the thing: Heretic Packaging
I don’t even need to run the script in a shell, but I need to know how to do it anyway.
The feeling like I am missing something very obvious is getting familiar, but I’m enjoying it because a solution feels great when it shows up lol
thanks everyone
~Brian
Here’s where I’ve gotten my configs to:
#configuration.nix
{ config, pkgs, ... }:
  imports =
      ./hardware-configuration.nix
  # Bootloader.
  networking.hostName = "nixos"; # Your hostname
  # Enable networking
  # Zram & other memory stuff
  zramSwap.enable = true;
  zramSwap.memoryPercent = 50;
  # Network Proxy Settings
  # Set your time zone.
  time.timeZone = "America/Los_Angeles";
  i18n.extraLocaleSettings = {
    LC_ADDRESS = "en_US.UTF-8";
    LC_IDENTIFICATION = "en_US.UTF-8";
    LC_MEASUREMENT = "en_US.UTF-8";
    LC_MONETARY = "en_US.UTF-8";
    LC_NAME = "en_US.UTF-8";
    LC_NUMERIC = "en_US.UTF-8";
    LC_PAPER = "en_US.UTF-8";
    LC_TELEPHONE = "en_US.UTF-8";
    LC_TIME = "en_US.UTF-8";
  services.xserver.videoDrivers = [ "amdgpu" ];
  # Enable the GNOME Desktop Environment.
  services.xserver.desktopManager.gnome.enable = true;
  # Configure keymap in X11
  services.xserver.xkb = {
    layout = "us";
    variant = "";
  # Enable sound with pipewire.
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
  users.users.cosmic = {
    isNormalUser = true;
    description = "cosmic";
    packages = with pkgs; [
    #  thunderbird
  # Install firefox.
  # Allow unfree packages
  # List packages installed in system profile. to search, run:
  # $ nix search wget
  # EXPERIMENTAL package features
  nix.settings.experimental-features = [ "nix-command" ];
  # HP Model 14-dk0028wm Laptop Research Workstation Environment
    brave # ### chromium based browser just in case
    clinfo
    driversi686Linux.libva-vdpau-driver
    #flameshot # testing screenshot tool, may return, trying gscreenshot
    geany # testing as IDE/text editor
    gitFull
    github-desktop
    gnome-commander # ## twin-pannel file manager with usefullness
    #gscreenshot
    libreoffice
    qalculate-gtk # ### replacing gnome-calculator
    usage # ### baobab replacement attempt
    util-linux
    vim
    wget
    #xdg-desktop-portal-gnome
    zram-generator
  # attempting easyPubMed Install
  #install.packages = ("easyPubMed");
  #  For 24.11, pretty big list of packages options to setup your GNOME environment
  #  with an adjustable amount of bloat :)
  #  #blahblah = an active package that gets installed, delete (#) to remove package
  #  #??? = Probably/Maybe remove carefully
  #  #XXX = please don't deactvate without reason
  environment.gnome.excludePackages = with pkgs; [
  # ### all packages active here are being removed
    cheese #webcam not welcome as a default
    evince #document viewer, no need with LibreOffice
    geary #email client, develop if wanted
    gnome-backgrounds #no need
    gnome-bluetooth #no need
    gnome-calendar #no need
    gnome-characters # ### special character map, testing removal unless needed
    gnome-clocks #no need
    gnome-connections # ### testing removal of Remote Client
    gnome-contacts #basic contacts app, no need
    gnome-font-viewer #no need
    gnome-initial-setup #no issues so far with stability
    gnome-logs #?
    gnome-maps #no need
    gnome-music #no need
    gnome-online-accounts #I don't want this as a default
    gnome-photos #no need
    gnome-tour # GNOME Shell detects the .desktop file on startup, no need
    gnome-user-docs #useful reference to start with
    gnome-weather #weather app, no need
    snapshot # ### removal shouldn't effect DE stability
    totem #video player
    yelp #help viewer
    # ### These are useful, pending replacement, or possibly sensitive
    #glib #helps gsettings program and others I believe
    gnome-calculator # ### testing Qalculate-gtk
    #gnome-console #nice to start with ### Possibly replace with Geany
    gnome-text-editor # ### testing Geany as replacement
    #gnome-themes-extra #for the rizz
    # ??? These are probably ok, alright, or oopsie things to remove
    baobab # ### attempting to replace with Usage
    #???gnome-control-center #for desktop functionality?
    loupe #might be useful, attempting to use flameshot
    nautilus #attempting gnome-Commander
    simple-scan # ### testing removal
    #???gnome-system-monitor #XXX Might support DE, test carefully
    #XXX Most likely or absolutely need to be here to function
    #XXXadwaita-icon-theme ### don't delete, replace
    #XXXgnome-color-manager #default screen correction, good to start with, upgrade later
    #XXXgnome-menus #makes desktop work
    #XXXgnome-epiphany #??? probably has DE stabilizing benefits
    #XXXgnome-orca #screen reader that keeps the desktop functional
    #XXXgtk3.out #gtk-launch program, keep for desktop
    #XXXxdg-user-dirs #update user directories, don't disable unless you know what you're doing
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # ### Other Services ###
  # Enable the OpenSSH daemon.
  # Open ports in the firewall.
  # ### Default Release Value ###
  system.stateVersion = "24.11"; # Did you read the comment?
and
# Do not modify this file!  It was generated by ‘nixos-generate-config’
# and may be overwritten by future invocations.  Please make changes
# to /etc/nixos/configuration.nix instead.
{ config, lib, pkgs, modulesPath, ... }:
  imports =
    [ (modulesPath + "/installer/scan/not-detected.nix")
  boot.initrd.availableKernelModules = [ "xhci_pci" "ahci" "usb_storage" "sd_mod" ];
  boot.initrd.kernelModules = [ "amdgpu" ];
  boot.kernelModules = [ "kvm-amd" ];
  boot.extraModulePackages = [ ];
  fileSystems."/" =
    { device = "/dev/disk/by-uuid/a64bb1dc-cf69-4d41-89db-98a22ea3cabe";
      fsType = "ext4";
  fileSystems."/boot" =
    { device = "/dev/disk/by-uuid/1284-4374";
      fsType = "vfat";
      options = [ "fmask=0077" "dmask=0077" ];
  fileSystems."/efi" =
    { device = "/dev/disk/by-uuid/ACD2-C2B7";
      fsType = "vfat";
      options = [ "fmask=0022" "dmask=0022" ];
  swapDevices =
    [ { device = "/dev/disk/by-uuid/c4a01f3b-299c-4871-a728-6d19f8106e7b"; }
  # General AMD GPU/OpenGL support settings, for the 24.11 instructions:
  hardware.graphics =
    { enable = true;
      enable32Bit = true;
      extraPackages = with pkgs; [
        libvdpau-va-gl
        libva-vdpau-driver
        amdvlk
        rocmPackages.clr
        rocmPackages.clr.icd
        libva
      extraPackages32 = with pkgs; [
        driversi686Linux.amdvlk
  # Enables DHCP on each ethernet and wireless interface. In case of scripted networking
  # (the default) this is the recommended approach. When using systemd-networkd it's
  # still possible to use this option, but it's recommended to use it in conjunction
  # with explicit per-interface declarations with `networking.interfaces.<interface>.useDHCP`.
  networking.useDHCP = lib.mkDefault true;
  # networking.interfaces.eno1.useDHCP = lib.mkDefault true;
  # networking.interfaces.wlp2s0.useDHCP = lib.mkDefault true;
  nixpkgs.hostPlatform = lib.mkDefault "x86_64-linux";
  hardware.cpu.amd.updateMicrocode = lib.mkDefault config.hardware.enableRedistributableFirmware;
To install Python with packages, don’t just throw them next to each other but use python3.withPackages instead. Example is here: Python - NixOS Wiki
I tried the format listed on that page for setting up the system packages properly, and with this:
       error: syntax error, unexpected ')', expecting ';'
       at /etc/nixos/configuration.nix:119:6:
          118|         types-lxml
          119|     ]))
I have tried different layouts, including “;” in different spots… it just isn’t liking that parenthesis.
when I try this layout:
    (python3.withPackages (python-pkgs: with python-pkgs: [
        biopython
        elementpath
        pep8
        requests
        scikit-bio
        types-lxml
i get this:
error:
       … while evaluating the attribute 'config.system.build.toplevel'
         at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:1:12288:
       … while calling the 'seq' builtin
         at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:1:12297:
       at /etc/nixos/configuration.nix:120:7:
          119|         ];
          120|       )
          121|     )
I’m trying to follow what’s on the wiki but that’s not working for me, any advice?
I put a “:” where I should have put a “;” in the beginning. Old vs corrected, rebuilt no issues
    (python3.withPackages (ps: with ps: [
        biopython
new
    (python3.withPackages (ps: with ps; [
        biopython
        elementpath
        pep8
        requests
        scikit-bio
        types-lxml
