Problem
I use Nextcloud with the Memories app on NixOS. I have libtensorflow in my environment.systemPackages but still get the following notice on the Recognize settings page:
Could not load libtensorflow in Node.js. You can try to manually install libtensorflow or run in WASM mode.
I also get this error when running nextcloud-occ recognize:classify:
Classifier process output: Error: libtensorflow.so.2: cannot open shared object file: No such file or directory
at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
at Module.load (node:internal/modules/cjs/loader:1119:32)
at Module._load (node:internal/modules/cjs/loader:960:12)
at Module.require (node:internal/modules/cjs/loader:1143:19)
at require (node:internal/modules/cjs/helpers:119:18)
at Object.<anonymous> (/mnt/data/nextcloud/store-apps/recognize/node_modules/@tensorflow/tfjs-node-gpu/dist/index.js:72:16)
at Module._compile (node:internal/modules/cjs/loader:1256:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
at Module._load (node:internal/modules/cjs/loader:960:12) {
code: 'ERR_DLOPEN_FAILED'
Any idea what’s going on and how to fix it?
System Details
- nextcloud 27.1.5
- memories 5.0.3
- nodejs 18.18.2
- tensorflow 2.13.0
Recognize downloads the libtensorflow that it needs. The only two packages that I have have in my environment.systemPackages are ffmpeg and nodejs_18. On the recognize admin settings page I have the node.js path set to /run/current-system/sw/bin/node. Be sure to run the nextcloud-occ recognize:download-models. You can also try running nextcloud-occ maintenance:repair. I feel like that fixed a few things after a recent update.
I am running nextcloud 28 and Recognize 6.0.1.
Thanks for the swift reply.
Yep, I’ve got those there too.
Got this.
I ran that a while back. The admin page says this:
The machine learning models have been downloaded successfully.
I tried it anyway. Didn’t make a difference.
Gave it a go. Everything looked fine until this:
- Install recognize dependencies
- WARNING: Failed to automatically install dependencies for recognize. Check the recognize admin panel for potential problems.
- Force-reset all Text sessions before Yjs migration
- Initialize migration of background images from dashboard to theming app
- ERROR: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 7 no connection to the server
- Add background job to check for backup codes
- Populating added database structures for workflows
So there’s something wrong with the DB connection. I presume it’s unrelated but it’s blocking any progress here. Gotta fix that.
EDIT
Fixed the DB issue (got rid of idle_session_timeout = 3000 in my psql config) and then noticed a different message in the UI mentioning that libtensorflow was correctly loaded but GPU mode wasn’t working. Since I don’t have an nvidia card, I presume GPU mode is not supported. I just flipped that toggle and now everything is green!
Unfortunately I’m not really sure what the issue and/or fix was. Presumably something in nextcloud-occ maintenance:repair. Anyway, thanks for helping me get there!
Hi.
I have recognize installed via pkgs.fetchNextcloudApp
and I have issue with models:
# nextcloud-occ recognize:download-models
Failed to download models
Unable to open "/nix/store/82wpw01yl3nkacq6yxr0dh84q4jmajfc-nextcloud-app-recognize-6.1.1/lib/Service/../../models.tar.gz" using mode "w+":
fopen(/nix/store/82wpw01yl3nkacq6yxr0dh84q4jmajfc-nextcloud-app-recognize-6.1.1/lib/Service/../../models.tar.gz): Failed to open stream: Read-only file system
It’s because store is readonly. So do you have recognize installed from nextcloud store?
Yes, all my nextcloud apps are installed from the store. I have snapshots and backups of the whole /var/lib/nextcloud directory and the database if I ever need to reinstall.
