i’m packaging modelio: init at 5.1.0 by yuuyins · Pull Request #154188 · NixOS/nixpkgs · GitHub
but
where’s this invalid character '?? (https://github.com/NixOS/nix/blob/fbd0a6c6e2e87f6679fe5cabaddaa877cf3e5a90/src/libutil/util.cc#L1573)
$ nix build --print-build-logs --show-trace /home/yuu/dev/nixpkgs#modelio
warning: Git tree '/home/yuu/dev/nixpkgs' is dirty
error: invalid character in Base64 string: '
hile evaluating the attribute 'buildPhase' of the derivation 'modelio-5.1.0'
at /nix/store/11nyljykmm5bsn1y3zl6mqdcgn16p7pn-source/pkgs/stdenv/generic/make-derivation.nix:270:7:
269| // (lib.optionalAttrs (attrs ? name || (attrs ? pname && attrs ? version)) {
270| name =
271| let
default.nix
{ lib
, javaPackages
, fetchFromGitHub
, fetchurl
, fetchpatch
, makeWrapper
, eclipse-sdk
, maven3
, openjdk8_headless
, atk
, cairo
, freetype
, gcc
, glib
, glibc
, gtk2
, jre8
, libXtst
, perl
, python
, swt
, webkitgtk
maven360 = maven3.overrideAttrs (oldAttrs: rec {
_pname = "maven";
pname = "apache-${_pname}";
majorVersion = "3";
version = "${majorVersion}.6.0";
src = fetchurl {
url = "https://archive.apache.org/dist/${_pname}/${_pname}-${majorVersion}/${version}/binaries/${pname}-${version}-bin.tar.gz";
sha256 = "0ds61yy6hs7jgmld64b65ss6kpn5cwb186hw3i4il7vaydm386va";
jdk = openjdk8_headless;
maven = maven360;
in (javaPackages.mavenfod.override {
inherit maven;
}) rec {
pname = "modelio";
version = "5.1.0";
src = fetchFromGitHub {
owner = "modelioopensource";
repo = pname;
rev = "v${version}";
sha256 = "sha256-+9dJuP+MzUZdzyjdjzgWNa5AyCv2U0Pz6v8MkBta4Gk=";
mvnSha256 = "sha256-6U1iDAcUMMQUH1FiYtoVhnU62rzZPqFkCZcZRpwqN8g=";
# mvnParameters = "";
patches = [
# Fixes for building with Maven.
# Error when building with Maven:
# bin.includes value(s) [*/] do not match any files.
# https://github.com/ModelioOpenSource/Modelio/issues/38
(fetchpatch {
name = "build-properties-remove-non-existent-directories-from-bin-includes.patch";
url = "https://github.com/yuuyins/Modelio/commit/04fdda793f8ef191ff11ae9f633e07c052fc28bc.patch";
sha256 = "sha256-S8KqfRtzf1fHi9gFyQiG3iHuhUxNyk0XcSqBnSCNsWs=";
nativeBuildInputs = [
eclipse-sdk
maven
openjdk8_headless
buildInputs = [
atk # libatk
cairo # libcairo
freetype # libfreetype.so.6
gcc # stdc++ 6
glib # libglib2
glibc # libc6
gtk2 # libgtk2
jre8 # java 8
libXtst # libxtst6
perl # plugins/**/bin/{antRun.pl,runant.pl,...}
python # plugins/**/bin/{runant.py,...}
swt #
webkitgtk # libwebkitgtk-1.0
JAVA_HOME = openjdk8_headless.home;
LANG = "C.UTF-8";
LC_ALL = "C.UTF-8";
installPhase = ''
runHook preInstall
mkdir --parents $out/bin
install -D --mode=644 \
"$src/products/target/products/org.modelio.product/linux/gtk/x86_64/Modelio ${version}/*" \
--target $out
# ln --symbolic $out/usr/lib/modelio-open-source${version}/modelio $out/bin/modelio
# ln --symbolic $out/usr/lib/modelio-open-source${version}/modelio.sh $out/bin/modelio.sh
rm --recursive --force $out/usr/lib/modelio-open-source${version}/jre
ln --symbolic ${jre8.home}/jre $out/usr/lib/modelio-open-source${version}/jre
runHook postInstall
meta = with lib; {
description = "Free, extensible modeling environment for UML and BPMN";
homepage = "https://www.modelio.org";
changelog = "https://github.com/ModelioOpenSource/Modelio/releases";
license = licenses.gpl3;
platforms = platforms.all;
maintainers = with maintainers; [ yuu ];
maven-fod.nix (a bit modified from master)
{ lib
, stdenv
, maven
{ src
, patches ? []
, pname
, version
, mvnSha256 ? "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA="
, mvnHash ? "sha256-${mvnSha256}"
, mvnFetchExtraArgs ? {}
, mvnParameters ? ""
} @args:
# originally extracted from dbeaver
# created to allow using maven packages in the same style as rust
stdenv.mkDerivation (rec {
fetchedMavenDeps = stdenv.mkDerivation ({
name = "${pname}-${version}-maven-deps";
inherit src patches;
buildInputs = [
maven
buildPhase = ''
mvn clean package -Dmaven.repo.local=$out/.m2 ${mvnParameters}
# keep only *.{pom,jar,sha1,nbm} and delete all ephemeral files with lastModified timestamps inside
installPhase = ''
find $out -type f \
-name \*.lastUpdated -or \
-name resolver-status.properties -or \
-name _remote.repositories \
-delete
# don't do any fixup
dontFixup = true;
outputHashMode = "recursive";
outputHash = mvnHash;
} // mvnFetchExtraArgs);
buildPhase = ''
runHook preBuild
mvnDeps=$(cp -dpR ${fetchedMavenDeps}/.m2 ./ && chmod +w -R .m2 && pwd)
mvn clean package --offline "-Dmaven.repo.local=$mvnDeps/.m2" ${mvnParameters}
runHook postBuild
} // args)
