Nix does not use /etc/nix/nix.conf anymore
I don’t know exactly when this started to happen but I used to be able to use nix-command and flakes experimental features without any additional flags by adding this to my config:
nix.settings.experimental-features = ["nix-command" "flakes"];
Now nix gives me an error every time I try to use any of these two experimental features:
error: experimental Nix feature 'nix-command' is disabled; use '--extra-experimental-features nix-command' to override
My /etc/nix/nix.conf looks like this:
# WARNING: this file is generated from the nix.* options in
# your NixOS configuration, typically
# /etc/nixos/configuration.nix.  Do not edit it!
allowed-users = *
auto-optimise-store = false
builders =
cores = 0
extra-sandbox-paths =
max-jobs = auto
experimental-features = nix-command flakes
require-sigs = true
sandbox = true
sandbox-fallback = false
substituters = https://cache.nixos.org/
system-features = nixos-test benchmark big-parallel kvm
trusted-public-keys = cache.nixos.org-1:6NCHdD59X431o0gWypbMrAURkbJ16ZPMQFGspcDShjY=
trusted-substituters =
trusted-users = root
I’ve also tried with extra-experimental-features instead of experimental-features (the documentation is not very clear on which one you should use) but I got the same result.
Can you please check for a user configuration at ~/.config/nix/nix.conf?
Does it contain the experimental-features as well?
That is one of the first things I checked. There is no ~/.config/nix/nix.conf. Is there any way I can troubleshoot this? Can I pass nix a config file to use to make sure my /etc/nix/nix.conf works correctly?
I configured this an hour ago. I had to use
extra-experimental-features = nix-command flakes
So I made some more progress. I copied the global conf to my user conf directory (which was empty before):
sudo cp /etc/nix/nix.conf ~/.config/nix/nix.conf
and now everything works again.
So the title of this thread still stands. For some reason nix does not use my global /etc/nix/nix.conf
Does anyone have any ideas why?
Could you check the permissions of /etc/nix and /etc/nix/nix.conf ? If they have something like a chmod 000 or 500 with wrong ownership, it may explain the issue (but it would be weird to have this state on NixOS)
700 for /etc/nix and 777 for /etc/nix/nix.conf. Are these correct?
I also just remembered I recently changed to an “impermanence” setup where my / (and therefore also /etc) is a tmpfs file system. Could this be the issue?
Yes, this could be an issue. What if you use 755 for /etc/nix/ ?
Setting permissions of /etc/nix to 755 fixed it! Thank you @Solene !
I’m not entirely sure how to make this change permanent while keeping the directory in a tmpfs file system…
You can use systemd.tmpfiles.rules = [ "d /etc/nix/ 0755 root root" ];
I just figured out what was changing the /etc/nix permissions. In the impermanence README the example config suggests to use:
files = [
        file = "/etc/nix/id_rsa";
        parentDirectory = { mode = "u=rwx,g=,o="; };
which causes the parent directory of /etc/nix/id_rsa, i.e. /etc/nix, to have 700 permissions.
I don’t know in what scenarios this is a good idea but it’s probably a very bad default for most users. It looks like an issue was created on this topic so hopefully it gets fixed soon so that users like me that copy paste config without paying too much attention :smiley: don’t encounter these issues down the road.
