Hi guys
I’m experiencing something really weird. When I enter a development shell using nix develop
then building nix stuff no longer works inside the shell (or at least when all of this happens inside a container).
I’ve made an example here:
The error message when running nix build
inside nix develop
is always something like the following:
error: builder for '/nix/store/gvh9z2yplwlh4sgn0ra1dqnvljaz740b-test.drv' failed with exit code 1;
last 2 log lines:
> unpacking sources
> variable $src or $srcs should point to the source
For full logs, run 'nix log /nix/store/gvh9z2yplwlh4sgn0ra1dqnvljaz740b-test.drv'.
Does this make sense to any of you?
