That’s the correct file.
Check also implementation in raspberry-pi-nix and Raspberry Pi camera on NixOS
Following steps should be required:
1. device tree overlay part
- download / copy the file (
maybe stick to default or lts branches, master only has compiled .dtbo so no .dts on master use the one on the branch matching your kernel version, currently 6.6y branch for NixOS 25.05 linux/arch/arm/boot/dts/overlays/ov5647-overlay.dts at rpi-6.6.y · raspberrypi/linux · GitHub)
- replace
compatible = "brcm,bcm2835"; with what’ts compatible with your device
e.g for Zero 2 W, it should be compatible = "brcm,bcm2837";
- replace the
#include "ov5647.dtsi" with the content of ov5647.dtsi
- file should then look like this:
// SPDX-License-Identifier: GPL-2.0-only
// Definitions for OV5647 camera module on VC I2C bus
/dts-v1/;
/plugin/;
i2c_frag: fragment@0 {
target = <&i2c_csi_dsi>;
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
cam_node: ov5647@36 {
compatible = "ovti,ov5647";
reg = <0x36>;
status = "disabled";
clocks = <&cam1_clk>;
avdd-supply = <&cam1_reg>;
dovdd-supply = <&cam_dummy_reg>;
dvdd-supply = <&cam_dummy_reg>;
rotation = <0>;
orientation = <2>;
port {
cam_endpoint: endpoint {
clock-lanes = <0>;
data-lanes = <1 2>;
clock-noncontinuous;
link-frequencies =
/bits/ 64 <297000000>;
vcm_node: ad5398@c {
compatible = "adi,ad5398";
reg = <0x0c>;
VANA-supply = <&cam1_reg>;
csi_frag: fragment@1 {
target = <&csi1>;
csi: __overlay__ {
status = "okay";
brcm,media-controller;
port {
csi_ep: endpoint {
remote-endpoint = <&cam_endpoint>;
data-lanes = <1 2>;
fragment@2 {
target = <&i2c0if>;
__overlay__ {
status = "okay";
fragment@3 {
target = <&i2c0mux>;
__overlay__ {
status = "okay";
reg_frag: fragment@4 {
target = <&cam1_reg>;
__overlay__ {
startup-delay-us = <20000>;
clk_frag: fragment@5 {
target = <&cam1_clk>;
__overlay__ {
status = "okay";
clock-frequency = <25000000>;
__overrides__ {
rotation = <&cam_node>,"rotation:0";
orientation = <&cam_node>,"orientation:0";
media-controller = <&csi>,"brcm,media-controller?";
cam0 = <&i2c_frag>, "target:0=",<&i2c_csi_dsi0>,
<&csi_frag>, "target:0=",<&csi0>,
<®_frag>, "target:0=",<&cam0_reg>,
<&clk_frag>, "target:0=",<&cam0_clk>,
<&cam_node>, "clocks:0=",<&cam0_clk>,
<&cam_node>, "avdd-supply:0=",<&cam0_reg>,
<&vcm_node>, "VANA-supply:0=",<&cam0_reg>;
vcm = <&vcm_node>, "status=okay",
<&cam_node>,"lens-focus:0=", <&vcm_node>;
&cam_node {
status = "okay";
&cam_endpoint {
remote-endpoint = <&csi_ep>;
- find the correct
hardware.deviceTree.filter - that will depends on kernel used, if using *rpi* kernels, then check here for naming per model
e.g for Zero 2 W use smth like bcm2837-rpi-zero-2*
- add
dts file to your config hardware.deviceTree
hardware = {
deviceTree = {
filter = "bcm2837-rpi-zero-2*";;
overlays = [
name = "ov5647-overlay";
dtsFile = ./path/to/ov5647-overlay.dts;
2. libcamera and rpicam-apps
You’ll need to package these as not in nixpkgs, rpicam-apps uses a fork of libcamera so can’t use the pkgs.libcamera directly.
See @SergeyMironov solution.
3. config.txt
Following will be needed:
camera_auto_detect=0
gpu_mem=128
cma=256
dtoverlay=ov5647 # or other overlay, depending on camera model
disable_fw_kms_setup=1
Important:
disable_fw_kms_setup=1 must be set on a fresh install, otherwise it would not work and camera won’t get detected (if added after the 1st boot) - idk the correct process to disable that after it was enabled, as assuming some setup gets done and needs to be un-installed therefore
overlay “patching” can be automated
here’s an example that generates the file and output required attributes to add to the deviceTree.overlays: nixos-raspberry-pi-build/modules/camera/overlays/ov5647.nix at main · JimJ92120/nixos-raspberry-pi-build · GitHub
Then import like this
