Hi,
I have an AMD Ryzen 7800X3D, but I don’t want to use all cores to compile the process. I have set up nix.settings.cores = 12 and It uses full cores and threads instead 12.
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 16
On-line CPU(s) list: 0-15
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 7800X3D 8-Core Processor
CPU family: 25
Model: 97
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Stepping: 2
Frequency boost: enabled
CPU(s) scaling MHz: 95%
CPU max MHz: 5050,0000
CPU min MHz: 545,0000
BogoMIPS: 8399,98
