gurkan
December 29, 2019, 12:16pm
1
Hi there,
I am packaging two new python packages: One (A) depends on the other (B).
B is declared as input argument in package A like:
{ lib
, buildPythonPackage
, packageB
, pytest
Now I’d like to test it, but when I call it via nix-shell and callPackage, it’s failing with this error:
error: anonymous function at /my-local-nix-tree/pkgs/development/python-modules/packageA/default.nix:1:1 called without required argument 'packageB'
Which is understandable. (If there is a way to supply this, please show
And this won’t work for a reason I don’t get:
nix-shell -I /my-local-nix-tree/ -p packageA
(or nix-shell -I /my-local-nix-tree/ -p python3Packages.packageA )
both are declared in the correct locations in the local clone, maybe I didn’t understand the -I parameter correctly.
Can I really use my local tree with -I parameter and/or handle this without creating a shell.nix file?
Thanks for any help.
danbst
December 29, 2019, 7:05pm
2
I think you use pkgs.callPackage
, but should use pkgs.python3.pkgs.callPackage
, which includes other python packages into scope.
export NIX_PATH=nixpkgs=/my-local-nix-tree
nix-shell -p python3.pkgs.packageA
I think -I
isn’t implemented for nix-shell -p
yes
For single commands:
$ nix run -f . python3Packages.requests --command python -c 'print("hello")'
hello
“proper nix-shell”
$ nix-shell -I nixpkgs=./. -p python3Packages.requests
“hacky nix-shell” (nix-shell can also just evaluate an arbitrary expression)
$ nix-shell -p "with import ./. {}; with python3Packages; [ requests lxml ]"
[nix-shell:/home/jon/projects/nixpkgs]$
gurkan
December 30, 2019, 11:03pm
4
Oh my… Apparently using ~ while declaring nixpkgs was not OK with my zsh configuration. Worked with -I nixpkgs=./. and proper full path from root Thanks!
