Nix-shell, CMake, GCC, QT Creator not working together
I’m stuck trying to get CMake, GCC and QT Creator working. I created a shell.nix file and run it using just nix-shell. From this nix shell I then launch QT Creator and try to configure a CMake Project. I keep running into a problem where g++ is looking for crt1.o and crti.o. (I also tried it not specifying glibc or libcxx.) Any suggestions?
shell.nix
{ pkgs? import <nixpkgs> {} }:
pkgs.mkShell {
  nativeBuildInputs = [
    pkgs.git
    pkgs.gcc
    pkgs.glibc
    pkgs.libcxx
    pkgs.lld
    pkgs.gdb
    pkgs.cmake
    pkgs.gnumake
    pkgs.qt5.full
    pkgs.qtcreator
The CMake Output from within QT Creator:
Running /nix/store/5cl0n3viqbgfgh0zaizaag6p3s5444x6-cmake-3.19.7/bin/cmake -S /home/wmadmin/Working/libsys -B /run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY '-GUnix Makefiles' -DCMAKE_BUILD_TYPE:String=Debug -DQT_QMAKE_EXECUTABLE:STRING=/nix/store/g6761vwblm4v7ai64xv891a0pjp4grf2-qt-full-5.15.2/bin/qmake -DCMAKE_PREFIX_PATH:STRING=/nix/store/g6761vwblm4v7ai64xv891a0pjp4grf2-qt-full-5.15.2 -DCMAKE_C_COMPILER:STRING=/nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/gcc -DCMAKE_CXX_COMPILER:STRING=/nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/g++ in /run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY.
-- The CXX compiler identification is GNU 10.3.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - failed
-- Check for working CXX compiler: /nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/g++
-- Check for working CXX compiler: /nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/g++ - broken
-- Configuring incomplete, errors occurred!
See also "/run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY/CMakeFiles/CMakeOutput.log".
See also "/run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY/CMakeFiles/CMakeError.log".
CMake Error at /nix/store/5cl0n3viqbgfgh0zaizaag6p3s5444x6-cmake-3.19.7/share/cmake-3.19/Modules/CMakeTestCXXCompiler.cmake:59 (message):
  The C++ compiler
    "/nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/g++"
  is not able to compile a simple test program.
  It fails with the following output:
    Change Dir: /run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY/CMakeFiles/CMakeTmp
    Run Build Command(s):/nix/store/wfzdk9vxayfnw7fqy05s7mmypg5a8lyr-gnumake-4.3/bin/make cmTC_0656d/fast && /nix/store/wfzdk9vxayfnw7fqy05s7mmypg5a8lyr-gnumake-4.3/bin/make  -f CMakeFiles/cmTC_0656d.dir/build.make CMakeFiles/cmTC_0656d.dir/build
    make[1]: Entering directory '/run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY/CMakeFiles/CMakeTmp'
    Building CXX object CMakeFiles/cmTC_0656d.dir/testCXXCompiler.cxx.o
    /nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/g++    -o CMakeFiles/cmTC_0656d.dir/testCXXCompiler.cxx.o -c /run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
    Linking CXX executable cmTC_0656d
    /nix/store/5cl0n3viqbgfgh0zaizaag6p3s5444x6-cmake-3.19.7/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0656d.dir/link.txt --verbose=1
    /nix/store/sjhz1j2d1ssn59f66kqp92xj9mpsww2d-gcc-10.3.0/bin/g++ CMakeFiles/cmTC_0656d.dir/testCXXCompiler.cxx.o -o cmTC_0656d
    /nix/store/5ddb4j8z84p6sjphr0kh6cbq5jd12ncs-binutils-2.35.1/bin/ld: cannot find crt1.o: No such file or directory
    /nix/store/5ddb4j8z84p6sjphr0kh6cbq5jd12ncs-binutils-2.35.1/bin/ld: cannot find crti.o: No such file or directory
    collect2: error: ld returned 1 exit status
    make[1]: *** [CMakeFiles/cmTC_0656d.dir/build.make:106: cmTC_0656d] Error 1
    make[1]: Leaving directory '/run/user/1000/QtCreator-YvSgaj/qtc-cmake-wtSWgvRY/CMakeFiles/CMakeTmp'
    make: *** [Makefile:140: cmTC_0656d/fast] Error 2
  CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
  CMakeLists.txt:2 (project)
CMake process exited with exit code 1.
Elapsed time: 00:00.
I made progress but I dont understand why. In QT Creator you can select the compiler to use. It gives me two options:
/nix/store/88ghxafjpqp5sqpd75r51qqg4q5d95ss-gcc-wrapper-10.3.0/bin/g++
When it is using the first path, it works, but when it is using the second path it does not. The fact that the first path has wrapper in the name suggest maybe an overlay sitting on-top of gcc?
Yeah, the gcc wrapper sets some extra variables so that gcc can find its libraries etc. Most of the time you want to use that.
