I am installing nixos using the gnome graphical installer (23.11). I have a Thinkpad x395 AMD laptop. I used to have an Arch and Windows dual boot, but i’m interested in erasing the disk and installing nixos.
The installer hits ~40% and crashes with the following error log: termbin.com/blbw
"nixos-install: /run/current-system/sw/bin/nixos-install: line 168: /run/current-system/sw/bin/nix-build: Input/output error"
Something I found odd: from reboot, the installer suggests autoformatting, but when it errors and I open the installer again, i only have the option to manual partition. Manually setting the /boot and / mountpoints leads to the same error as above.
The same “nix-build: Input/output error” appears when I call nix-rebuild switch
from the live usb terminal. The configuration is just
{ config, pkgs, ... }:
imports = [ <nixpkgs/nixos/modules/installer/cd-dvd/installation-cd-graphical-calamares-gnome.nix> ];
Also, just calling nix-build
with no arguments results in bash: /run/current-system/sw/bin/nix-build: Input/output error
. All nix specific commands do the same.
Any ideas for what could be going wrong?
