NixOS-LiveCD-CN - Customized NixOS Live CD for build
NixOS-LiveCD-CN - 专为中国用户定制的NixOS Live CD
项目背景
这个 LiveCD 是我为了解决在新设备上不能直接部署我的现有配置,而必须创建一个最小系统配置,然后才能远程部署所解决的。
它解决了如下问题:
  • 我所在的地区无法直连 GitHub 与 cache
  • 我的 flake 里有私人仓库,需要 SSH & GPG 密钥才能访问
项目简介
这是一个基于官方 NixOS Gnome 安装镜像的自定义 Live CD 镜像项目,专门为中国用户的使用环境和网络条件进行了深度优化。
核心特性
:globe_with_meridians: 完整中文本地化
  • 系统界面完全中文化
  • 预配置中文输入法
  • 本地化时区和语言设置
:rocket: 网络环境优化
  • 集成 Clash Verge Rev 代理客户端
  • 针对中国大陆网络环境优化
  • 解决软件源访问问题
:locked: 安全功能增强
  • 支持 GPG 智能卡
  • 增强的加密和认证功能
  • 安全的密钥管理
:high_voltage: 现代化体验
  • 启用 Nix Flakes 支持
  • 更好的包管理体验
  • 现代化的构建系统
适用场景
  • 系统安装: 为NixOS新手提供友好的安装环境
  • 系统维护: 用于系统救援和恢复
:star: 如果这个项目对您有帮助,请给个 Star 支持一下!
NixOS-LiveCD-CN Customized NixOS Live CD for build
Project Background
This LiveCD was created to solve the problem where I couldn’t directly deploy my existing configuration on new devices, and had to create a minimal system configuration first before being able to deploy remotely.
It addresses the following issues:
  • Unable to directly connect to GitHub and cache from my region
  • My flake contains private repositories that require SSH & GPG keys for access
Project Overview
This is a custom Live CD image project based on the official NixOS Gnome installation image, specifically optimized for Chinese users’ environment and network conditions.
Key Features
:globe_with_meridians: Complete Chinese Localization
  • Fully Chinese system interface
  • Pre-configured Chinese input methods
  • Localized timezone and language settings
:rocket: Network Environment Optimization
  • Integrated Clash Verge Rev proxy client
  • Optimized for mainland China network environment
  • Solves software repository access issues
:locked: Enhanced Security Features
  • Support for GPG smart cards
  • Enhanced encryption and authentication
  • Secure key management
:high_voltage: Modern Experience
  • Nix Flakes support enabled
  • Better package management experience
  • Modern build system
Use Cases
  • System Installation: Friendly installation environment for NixOS beginners
  • System Maintenance: For system rescue and recovery
:star: If this project helps you, please give it a Star!
