I am using flakes in my system config. I am trying to add a myApp
flake into my inputs
and then use it. To do so I have to set programs.myApp.package
to be the package from the myApp
flake (inputs.myApp.packages.x86_64-linux.default
). If I were not to do this, myApp
would fail to build since my “main” nixpkgs
from the system flake would be used (the version of Rust there isn’t new enough which will cause compilation errors) instead of the ones from myApp
flake (where Rust is new enough)
I’ve asked about this on Matrix and it has been suggested this can be fixed by amending myApp
flake. Would anyone be able to recommend a way to do so?
flake.nix
outputs = {nixpkgs, ...}: let
pkgs = import nixpkgs {system = "x86_64-linux";};
packages.x86_64-linux = {
default = nixpkgs.legacyPackages.${"x86_64-linux"}.callPackage ./nix/package.nix {inherit pkgs;};
devShells.default = import ./nix/shell.nix;
nixosModules.default = import ./nix/module.nix;
nix/module.nix
lib,
config,
pkgs,
}: let
cfg = config.programs.myApp;
with lib; {
options.programs.myApp = {
enable = mkEnableOption "myApp";
package = mkOption {
type = types.package;
default = pkgs.callPackage ./package.nix {};
description = ''
The myApp package to use.
config = mkIf cfg.enable {
environment.etc."myApp.toml".text = ''...'';
nix/package.nix
lib,
pkgs,
}: let
cargoTomlPath = ../Cargo.toml;
cargoTomlContent = builtins.fromTOML (builtins.readFile cargoTomlPath);
pkgs.rustPlatform.buildRustPackage rec {
pname = "myApp";
version = cargoTomlContent.workspace.package.version;
src = lib.cleanSource ../.;
cargoToml = cargoTomlPath;
cargoLock = {
lockFile = ../Cargo.lock;
buildInputs = with pkgs; [
LIBCLANG_PATH = "${pkgs.libclang.lib}/lib";
LD_LIBRARY_PATH = "${pkgs.lib.makeLibraryPath buildInputs}";
