Nixos on OVH kimsufi: cloning builder process: Operation not permitted
Hey,
I’m having an issue while installing nixos on a kimsufi dedicated server.
I’m following this guide: Installing NixOS on a Kimsufi
I have a problem when chrooting into the install environment. When executing nix/store/hfa8sap493ip9q4wxpnm88m2wcjbl2si-nixos-system-nixos-18.09.1388.03dc6471c12/init, the chroot process ends up with the following error:
unpacking the NixOS/Nixpkgs sources...
error: cloning builder process: Operation not permitted
error: unable to start build process
I don’t know how to fix or debug this to be honest. Google was no help.
The partition on which I mount the nixos installer as plenty of space.
Full log:
root@rescue:~# ls
nixos-minimal-18.09.1388.03dc6471c12-x86_64-linux.iso  rescue
root@rescue:~# mkdir image
root@rescue:~# mkdir rescue/nix
root@rescue:~# mount /dev/disk/by-label/rescue rescue/
root@rescue:~# mount -o loop nixos-minimal-18.09.1388.03dc6471c12-x86_64-linux.iso  image/
mount: /dev/loop0 is write-protected, mounting read-only
root@rescue:~# unsquashfs -d rescue/nix/store image/
boot/               EFI/                nix-store.squashfs
.boot.cat           isolinux/           version.txt
root@rescue:~# unsquashfs -d rescue/nix/store image/nix-store.squashfs '*'
Parallel unsquashfs: Using 4 processors
70672 inodes (71312 blocks) to write
[================================================================================================/] 71312/71312 100%
created 54335 files
created 17163 directories
created 16337 symlinks
created 0 devices
created 0 fifos
root@rescue:~# cd rescue/
root@rescue:~/rescue# mkdir -p etc dev proc sys
root@rescue:~/rescue# df
Filesystem                         1K-blocks      Used  Available Use% Mounted on
devtmpfs                             2005948         0    2005948   0% /dev
178.33.124.57:/home/pub/rescue.v8 3763908936 282585208 3290105040   8% /nfs
tmpfs                                2007832    616716    1391116  31% /rw
aufs                                 2007832    616716    1391116  31% /
178.33.124.57:/home/pub/pro-power 3763908936 282585208 3290105040   8% /power
178.33.124.57:/home/pub/commonnfs 3763908936 282585208 3290105040   8% /common
tmpfs                                2007832         0    2007832   0% /dev/shm
tmpfs                                2007832      9860    1997972   1% /run
tmpfs                                   5120         0       5120   0% /run/lock
tmpfs                                2007832         0    2007832   0% /sys/fs/cgroup
tmpfs                                2007832        12    2007820   1% /tmp
/dev/sda3                            5029504   1808476    2942500  39% /root/rescue
/dev/loop0                            527360    527360          0 100% /root/image
root@rescue:~/rescue# mount --bind /dev/ dev
root@rescue:~/rescue# mount --bind /proc/ proc/
root@rescue:~/rescue# mount --bind /sys/ sys
root@rescue:~/rescue# INIT=$(find . -type f -path '*nixos*/init')
root@rescue:~/rescue# BASH=$(find . -type f -path '*/bin/bash' | tail -n 1)
root@rescue:~/rescue# sed -i "s,exec systemd,exec /$BASH," "$INIT"
root@rescue:~/rescue# chroot . /$INIT
/nix/store/czx8vkrb9jdgjyz8qfksh10vrnqa723l-bash-4.4-p23/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
<<< NixOS Stage 2 >>>
running activation script...
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
	LANGUAGE = "en_US:en",
	LC_ALL = "en_US.UTF-8",
	LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
setting up /etc...
/nix/store/czx8vkrb9jdgjyz8qfksh10vrnqa723l-bash-4.4-p23/bin/sh: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
Initializing machine ID from random generator.
starting systemd...
From my experience, this happens because the activation script of the livecd tries to execute nix-env; since 18.09, Nix defaults to using the “sandbox” mode, which doesn’t work in chroot environment.
Try to disable the sandbox mode by specifying sandbox = false in etc/nix/nix.conf (inside rescue).
Nice catch!
For people finding this solution through a google search, you can run
CONF=$(find . -type f -path '*-nix.conf')
sed -i "s,sandbox = true,sandbox = false," "$CONF"
Before jumping into the chroot to solve the problem.
I’ll send a message to the guy owning the guide previously cited.
Thanks again @pvgoran for the answer!!! :smiley:
Actually it’s not entirely solved ><
I have a similar problem while running nixos-install:
[root@nixos:/mnt/etc/nixos]# nixos-install --option sandbox false
building the configuration in /mnt/etc/nixos/configuration.nix...
[0/180 built, 1/350/353 copied (1405.5/1408.8 MiB), 27.5/27.9 MiB DL] copying btrfs-progs-4.15.1 from localerror: cloning builder process: Operation not permitted
[351 copied (1405.7 MiB), 27.5 MiB DL]
I still have the sandbox = false setup in my chroot’s /etc/nix configuration and added a nix.useSandbox = false; in my chroot’s /mnt/etc/nixos/configuration.nix.
Looks like the problem still comes from a container built in the chroot. Once again, google is no help on this.
TL;DR: you can’t install nixos on a kimsufi anymore.
[Original post]
I’m still making progress on this issue.
I’m debugging the nixos-install script step by step to see what’s wrong.
Turns out the problem comes from the Build the system configuration in the target filesystem. (https://github.com/NixOS/nixpkgs/blob/f591dd2fdf240bfc10f838ae1f792d89e8b75781/nixos/modules/installer/tools/nixos-install.sh#L95) step:
[root@nixos:/]# cat /etc/nix/nix.conf
# WARNING: this file is generated from the nix.* options in
# your NixOS configuration, typically
# /etc/nixos/configuration.nix.  Do not edit it!
build-users-group = nixbld
max-jobs = 1
cores = 1
sandbox = false
extra-sandbox-paths =
substituters = https://cache.nixos.org/
trusted-substituters =
trusted-public-keys = cache.nixos.org-1:6NCHdD59X431o0gWypbMrAURkbJ16ZPMQFGspcDShjY=
auto-optimise-store = false
require-sigs = true
trusted-users = root
allowed-users = *
builders =
[root@nixos:/]# nix build --out-link "$outLink" --store "$mountPoint" "${extraBuildFlags[@]}"         --extra-substituters "$sub" -f '<nixpkgs/nixos>' system -I "nixos-config=$NIXOS_CONFIG"
[0/257 built, 0/6 copied (0.0/0.0 MiB), 0.0/0.0 MiB DL] error: cloning builder process: Operation not permitted
[EDIT]
Alright, I’m still stuck on it.
I tried several things. Looks like this error is coming from nix somehow ignoring the “sandbox = false” directive. I sadly did not manage to track down the error in the nix store program.
Looks like you can’t use nix-build from within a chroot (at least from a chroot in the nixos-install process).
I’m giving up on this one, I’m just going to dump my last try, could be handy for somebody else trying to tackle this problem:
nix-build --out-link "$outLink" --store "$mountPoint" --extra-substituters "$sub" -I "nixos-config=$NIXOS_CONFIG" '<nixpkgs/nixos>' --option "sandbox" "false"
  /nix/store/01pr08dl6xf8b0qscpbkyp4nf0wwxpz0-dhcpcd.exit-hook.drv
  /nix/store/c75vdj3v0s5h4jc2jcr3x0jpk5lfcvh8-pam-environment.drv
  /nix/store/14xaf9ad7r1kb6nb7mkx2h09yw5xvmdk-polkit-1.pam.drv
  /nix/store/1pvjyx1b633hfgasqk96pjzpphhls6g2-i3lock.pam.drv
  /nix/store/1ym7jj35ilslqdgg0r7l5lldzzmim431-etc-nixos.conf.drv
  /nix/store/2w2dg30gbfqil61cbh6ibhx2xmcwl1sy-etc-nixos.conf.drv
  /nix/store/3102qlnx5chpbp8vivx337jv732ps9fs-login.pam.drv
  /nix/store/4b11a22x6sw28w3zj4fg2gpr99h85nrs-groupdel.pam.drv
  /nix/store/6if3mkd3fl5rzx1v9y307cci668b05iv-su.pam.drv
  /nix/store/6jw26nr1qlysclw24ld4g16yvfjjhxy0-etc-fstab.drv
  /nix/store/6vh2q7v3ra7q88x5ss0057r5bw1a38zy-xscreensaver.pam.drv
  /nix/store/7c02x84bmfihapw8ynsn5vi87jx9q19y-etc-sshd_config.drv
  /nix/store/7fz9p9wxykn6vnpmvqgimcnygqgjkqwd-etc-os-release.drv
  /nix/store/7lnxkhsr0gimfi2a4fp21x5jfm0kmlms-i3lock-color.pam.drv
  /nix/store/0ln8fz8s43nky4wpih11xzwfz6dz6rnc-unit-systemd-journal-gatewayd.socket.drv
  /nix/store/59vm3zgsmjj22a2rk20az1ij9awdy1z3-unit-script-sshd-pre-start.drv
  /nix/store/1frlbircar7ldvj5mdh4lj14mnn6q8w6-unit-sshd.service.drv
  /nix/store/1nr44c32b64yf04z59dj494xxb9b1zk1-unit-systemd-random-seed.service.drv
  /nix/store/230f181bda2jw001kid6iybqzgwaavf9-unit-local-fs.target.drv
  /nix/store/2lghvgg057csfpnfd7ck2c5n5p7rm6dh-unit-systemd-binfmt.service.drv
  /nix/store/35cfgiwwgqzdldc7hb2j539iaykyr1wr-unit-remote-fs.target.drv
  /nix/store/3j7g5z63cdg86m1zrhcpp58h5l57a5xr-unit-nix-daemon.socket.drv
  /nix/store/jcwbizzll8ww893jmg2wq3zczf1yggm5-dhcpcd.conf.drv
  /nix/store/3klaw4mchv8zf9m7vps3wj43lkbxb4jw-unit-dhcpcd.service.drv
  /nix/store/s3a23ygr03hpgm5fkz21x128d55j17la-unit-script-pre-sleep-start.drv
  /nix/store/46la6yy0395xpxcxy14hf5yy2wfkah3m-unit-pre-sleep.service.drv
  /nix/store/yqr1djka38y497xkvrb0wza9hhm3i0q4-unit-script-prepare-kexec-start.drv
  /nix/store/5wsxclfzqqgfy98535my5sjlw7m99bds-unit-prepare-kexec.service.drv
  /nix/store/xwsb22b1wyqmgr4ah0qh4zzx51wlmnwa-nixos-help.drv
  /nix/store/j7qjrrgb7mmhffg930b9hhprvy8dc7cc-system-path.drv
  /nix/store/65j90aqbydy2vvrjmz3iqbnqa1yp49y1-unit-polkit.service.drv
  /nix/store/6yqv5ahpwydrfcwq4midf4wkfkrla26l-unit-save-hwclock.service.drv
  /nix/store/8kax9pxdik8rdi36bd3qxjw1npzq6p2w-unit-user-runtime-dir-.service.drv
  /nix/store/9ixalag6rdpzab9h88nnmrwyb76iwwln-unit-serial-getty-.service.drv
  /nix/store/9l0sfhdvykixz5v02496silg289avpmv-unit-systemd-journal-flush.service.drv
  /nix/store/ha2hlacazqvffk6kd5jrzhwhdl4msfqr-nixos.conf.drv
  /nix/store/akn6zfi1pvnl86l7i6j19wsq0qsm45kk-unit-systemd-modules-load.service.drv
  /nix/store/4wq8frbl375qgz5fv3dqh18s7vyvh3s5-unit-script-nscd-pre-start.drv
  /nix/store/dwicns95cpyhkdqcvqg9929vxfvzq2ll-etc-hosts.drv
  /nix/store/fyficlp3qq5wjnms9dx42l9fx867qpas-etc-nscd.conf.drv
  /nix/store/n98282igznkwjrg96yl39gv9az9n9303-etc-nsswitch.conf.drv
  /nix/store/y2kffvsay3388hnd9yqq6dskz6h0x0s9-unit-script-nscd-post-start.drv
  /nix/store/awswd4lxpkm7j5cmh018r2x55a1d1vs1-unit-nscd.service.drv
  /nix/store/azsbwd90ssvbqp3ak4vxgqwqbchk8c0k-unit-systemd-remount-fs.service.drv
  /nix/store/baf7bgjgv2nly7d84mg8ny904n6l96h3-unit-systemd-fsck-.service.drv
  /nix/store/brgb5871rysqmamr9qj23n04xhk862fs-unit-qemu-guest-agent.service.drv
  /nix/store/bvi7cnivfmny4f8ixpmdkm2fxnl3p69b-unit-nix-optimise.service.drv
  /nix/store/d3h7z0j0va8y7a1r5q9s1kpzb95ia8bv-unit-mdadm-grow-continue-.service.drv
  /nix/store/dhb2fynxh42a8zz7xrfh995ywbvc9ii7-unit-systemd-user-sessions.service.drv
  /nix/store/p0ml8jia1ys06s7y20xkls8gy8c779nl-unit-script-nix-gc-start.drv
  /nix/store/falw2xblvpxsyw5inr0fdbsrqyszaidz-unit-nix-gc.service.drv
  /nix/store/flpbmf84qn685bcsjn4idcg6q1a784q2-unit-keys.target.drv
  /nix/store/frpzzm287q2341cn27mcaqnaxwh8xrmk-unit-fs.target.drv
  /nix/store/g1qbfcg7n5fjmzr3p0cs68qhl3iirnj0-unit-script-network-local-commands-start.drv
  /nix/store/gp8zr8hf6v545zyczzjgwgkkpw1a9rzh-unit-network-local-commands.service.drv
  /nix/store/nhv7kjwj5kkqzcn4vnqwvfj407xhd3dv-dbus-catalog.xml.drv
  /nix/store/qq56d4brnzchpha531n5j8krwk9f0z6k-dbus-1.drv
  /nix/store/hx4q8x6r2jijfnblr1pdzfmcsi33zsrm-unit-dbus.service.drv
  /nix/store/i6k73vss15jngw6kih0n4np2041bh60i-unit-mdmon-.service.drv
  /nix/store/ix8fn7iyxrrrw62j9c9sg1dzzk2y35lp-unit-network-interfaces.target.drv
  /nix/store/javi5abgmp9k27d7ifv6lw1zbmlpmyzl-unit-container-getty-.service.drv
  /nix/store/9wa0dbvb5pw03mrp2a46gl8rzfr3rrps-unit-script-post-resume-start.drv
  /nix/store/jxjkgw0mzlrn73m4q84b3sl8shlscgcc-unit-post-resume.service.drv
  /nix/store/1jhrkmqyjrigzgz9h7c1jx3li15azyjb-unit-script-nixos-upgrade-start.drv
  /nix/store/k9m2wqx09djylv1h9phv02naqhmw1mib-unit-nixos-upgrade.service.drv
  /nix/store/8ckpmmn92vrkv5as8zl8blwwnp1388wf-unit-script-network-setup-start.drv
  /nix/store/kck80czbil5nc33hkc6nm7kfcvia025j-unit-network-setup.service.drv
  /nix/store/lg1mdp9mwpncrb2klrzzach24kmhk8fj-unit-mdadm-shutdown.service.drv
  /nix/store/lnbnd1pscgrvg917pqj0h6wkcwwp2s50-unit-user-.service.drv
  /nix/store/fkgxn7w7v0l0fmx2cdy4272vwn4kqp9j-etc-journald.conf.drv
  /nix/store/lqc5jga49mzn7fjvf3bk8jckicjz7j6y-unit-systemd-journald.service.drv
  /nix/store/b8b8ll9x3zf7wq5zm0bl0c71p43c6fr1-etc-nixos.conf.drv
  /nix/store/mlsh7vhkkvdydi7ssdm9kk2n9acmy3k8-unit-systemd-sysctl.service.drv
  /nix/store/myc2hw13jqbxcafhb1a9fnj7r5hmq644-unit-systemd-backlight-.service.drv
  /nix/store/4m4ww5ndz6bw2kqp2f8wi94vx0fx0wrj-reload-container.drv
  /nix/store/82czwpk95rjr61kz3knbpkmmxl2grm9x-unit-script-container_-pre-start.drv
  /nix/store/rkmqc8973zjqmqiihxlvkmva2vjz2qd0-container-init.drv
  /nix/store/aqa0af560b0rablr526648xzczn07fmz-unit-script-container_-start.drv
  /nix/store/fnakl0xhx5ap3gpclrwy6ph5isd5sh94-unit-script-container_-post-start.drv
  /nix/store/gymlb79f62an0ic1ka2sdh1a8m5vz8gs-unit-script-container_-pre-stop.drv
  /nix/store/n0rga7h72h2pm3vbsi19cvzg3byz4mdb-unit-container-.service.drv
  /nix/store/9lg2ylspr7b815sdbnj9xxglb9c8p8n6-extra-hwdb-file.drv
  /nix/store/dc8qaqkjyqx47sflka0maf4924yd3djm-extra-udev-rules.drv
  /nix/store/n1lfgrkm0daidpf5vlfkspigkhjsq0ml-unit-systemd-udevd.service.drv
  /nix/store/p4bqwzzpf7lzqgn4ysagm0z3jih470jk-unit-post-resume.target.drv
  /nix/store/6fjl87n5a299fzpplmdm4mgkcj9b69yr-audit-stop.drv
  /nix/store/v49mrs6qz5p4df4141amj5r8lmjxzagv-audit-disable.drv
  /nix/store/vxkfnzh2mf7lkpqgf42d34p8jk16qcrj-unit-audit.service.drv
  /nix/store/w2gbkkwnnjhqvfjxn9fs19zqd8y760yy-unit-systemd-timedated.service.drv
  /nix/store/wp2zdah9qg7g58cm5c1f3fmk049yvfis-unit-systemd-logind.service.drv
  /nix/store/x7k0pyarair9ma8ljxnkmx8vglypspw9-unit-cpufreq.service.drv
  /nix/store/dsh2m8c3dr7cmdyafjykyicchwx85445-firewall-start.drv
  /nix/store/g10nh7qylkz7pxfs2nn7s5xrc0yzqfnn-firewall-stop.drv
  /nix/store/vxqzq3rl2d52x4qndyr1dzrh0ycw4i6r-firewall-reload.drv
  /nix/store/xrlyia8pidzrp620blrsdn3y3sk0i78x-unit-firewall.service.drv
  /nix/store/y3vjdgi4kvdn5xbffzzwv1ihl0hkrn2a-unit-getty-.service.drv
  /nix/store/d2zf2d6zjr861jnl6imq1mzn2l5y1vx0-vconsole.conf.drv
  /nix/store/yadpj1cwkfmal63gi5mjgmy5wm9rm018-unit-systemd-vconsole-setup.service.drv
  /nix/store/dw1pajhzaxs0gvl8a1gi582a6knrxv2y-unit-script-network-addresses-enp1s0-pre-stop.drv
  /nix/store/hs5350n8ixcxzf064q18r78w5h8zpq8d-unit-script-network-addresses-enp1s0-start.drv
  /nix/store/yqq0y3n8hhlq0sgqzbsbfl74znzycxxm-unit-network-addresses-enp1s0.service.drv
  /nix/store/yqypkwqvwk41gz25xj9p3i4dvls827f4-unit-console-getty.service-disabled.drv
  /nix/store/kflrcxcympdf4i9sva71jmkcirxjr5wp-unit-script-network-link-enp1s0-start.drv
  /nix/store/z0lw3ax821bpy95p6a0x2hdiq2njq2np-unit-network-link-enp1s0.service.drv
  /nix/store/zb85b3q3bmpl2yz7b0kz0q39lr23vgzc-unit-systemd-update-utmp.service.drv
  /nix/store/89v14m8q76nn6qjjphmz9zc2c9yrlyz4-nix.conf.drv
  /nix/store/zlax5cspk3xrmrqa93bnv46fv0k152nc-unit-nix-daemon.service.drv
  /nix/store/zpz5804ryjw0w18s7f4i1ax3z17r9xrd-unit-network-online.target.drv
  /nix/store/7xvd0jfc4099w1qxicg65cyv93s3kh5z-system-units.drv
  /nix/store/822z3ibp09l66vq3vmm4smr1vgi4ff4i-etc-sleep.conf.drv
  /nix/store/83g8z630g3ca80xv61b4v082xi18izyq-etc-system.conf.drv
  /nix/store/8k2ysi7w5w2d31vnmjb7g1dyzdbbas9n-set-environment.drv
  /nix/store/9279l84hn0rzvvhw7j1mimyfvqypln43-passwd.pam.drv
  /nix/store/9ailbgi8zpc3ldspn8fkllqm8f7jwxl0-useradd.pam.drv
  /nix/store/a8yprynvqbnbfgv4pgjfpy8fnp9x653p-chpasswd.pam.drv
  /nix/store/bbhnx145wi641jq57ppfdcwpxvqd3965-vlock.pam.drv
  /nix/store/br5bwjdm17qj89lm50wm7xc09fsnn0ca-etc-host.conf.drv
  /nix/store/bwvr1fd9w8dd4m07psxnahai6kv0grfd-etc-10-nixos.rules.drv
  /nix/store/c29bw1lvlhjx12v79l4l3qwjpmv5s44v-chsh.pam.drv
  /nix/store/df9pdjqcjg3hyjngffy8na4bmij8d8bv-client.conf.drv
  /nix/store/dqfwf21cczncfk5ihk32vw3lwq8hp2xc-login.defs.drv
  /nix/store/dv828a03nz8gf3kfrfq1idf93jndp2h4-groupadd.pam.drv
  /nix/store/f5vqnq5xavbn136shx61aszhx1s0lnm6-other.pam.drv
  /nix/store/gddib6h89g6382mjfiz0b1f4sc49rq12-etc-shells.drv
  /nix/store/gf2m4lp9pxr34c7wy2sxvvqf6z7f7ba8-runuser-l.pam.drv
  /nix/store/haw2dhd6858jlgxhbka73f9kb023b4a3-ftp.pam.drv
  /nix/store/ikna2kmxg4gic18m7yxr4j576csvpvmc-issue.drv
  /nix/store/j1vbh83slz4fmn2y3vxzxrzf1jqlif0a-runuser.pam.drv
  /nix/store/jk3p3hn9fhcj7h3vl93m41lihb5mj25q-groupmod.pam.drv
  /nix/store/jmam7c1mpdz5anmxfc25q0klrz6zdmfm-screen.pam.drv
  /nix/store/k09l0abdafzpf3pv9a2id48zydrdsxa1-xlock.pam.drv
  /nix/store/kqmmiz90rhml73bfsg3vdyrawny5sadd-sudo.pam.drv
  /nix/store/l1ygr1kgcxggbkgvh16p6vmmf3f40rjk-sshd.pam.drv
  /nix/store/l9sglzp2r4kjzf2fc7i79i3gfx1537m7-hwdb.bin.drv
  /nix/store/m6mly4b9div91j0px3wchl005q92nx85-etc-resolvconf.conf.drv
  /nix/store/mjyb3wbzh0bkq906jzzlib5lhwlc8rc5-etc-bashrc.drv
  /nix/store/msa8fkpvxrpk1lyj123rsyj91wiqqlbr-unit-script-nixos-activation-start.drv
  /nix/store/bmf3cgl0b44s7xggkapyw22cqga746c9-unit-nixos-activation.service.drv
  /nix/store/kyd7fk5s5qvfmsbh6kj5f4knr1wsw3zn-unit-dbus.service.drv
  /nix/store/lc2zi69v9l2b4fzx0dk1p0x0qznwqggh-unit-dbus.socket.drv
  /nix/store/ss1sfa7zqjnn90877r4bys6rgs60vshl-unit-graphical-session.target.drv
  /nix/store/mrba1wd7hkhbk15dsn7vb51acvisxx7h-user-units.drv
  /nix/store/nm7laqcwnibdpv288xhgy9sphg9s3fbp-cups.pam.drv
  /nix/store/p4my1j7bj9ja15xgrv97vadbsc850yyv-etc-hostname.drv
  /nix/store/pvkvzwjih0sb63i0a0b9nz72s8iwldbz-etc-logind.conf.drv
  /nix/store/pvvd04bhgvdclj951y0krcd4m4hj3lgi-smb-dummy.conf.drv
  /nix/store/q95fin5mmn8drli2skal6sg83nvsdka2-locale.conf.drv
  /nix/store/s60glpyab1raswk6cy27ir07442l306x-groupmems.pam.drv
  /nix/store/sj7vx2hv80ghbxbp4q1l5wygrihdaif2-userdel.pam.drv
  /nix/store/vfzmfrcz91jrm0dffhp6fw3k6ksq1mlk-etc-ssh_config.drv
  /nix/store/vvpsd54rrzbpix49glw4m3z5jmgl5fkf-systemd-user.pam.drv
  /nix/store/w3yqkygj59ji8rn7dbayydqmrlxsyk3s-etc-subuid.drv
  /nix/store/whjd03kqliqbs4zr589sh1ilp1s9hgd1-usermod.pam.drv
  /nix/store/xhlmbas38052b8mvzi0khk0dm4rqvkdm-udev-rules.drv
  /nix/store/yrgf4f7mp1s7hwlp6ijcx6ymfldz3zhz-etc-ssh_known_hosts.drv
  /nix/store/z0qkdj6gl7xkz5pmcg1xkw2zba7281jh-chfn.pam.drv
  /nix/store/zcv44iw5b7qpaab5vk8pbywf9bfz2hgw-etc-user.conf.drv
  /nix/store/zdbfxy977lpyl3cjj9ldc8rsgjpkmaaf-etc-subgid.drv
  /nix/store/zm91p6nzb27j1awc032xnwllbhck5vly-etc-profile.drv
  /nix/store/zv9xvpqpa1rjl6561nx64p2fnnf9wy41-useradd.drv
  /nix/store/0bx1rs0m7vgvyyprkwzb7f1jagmlzj0h-etc.drv
  /nix/store/hjmq8kcb2hx2g55rlmdglyicmj1zpbhr-vm-run-stage2.drv
  /nix/store/vsrjqvln4jzwx4y1sg943aw0s80a3av7-vm-run.drv
  /nix/store/65nbi8qlvi4ax51xh3j6x2wq476qn5sj-system-path.drv
  /nix/store/ip8v13iw850s4kl40a39zjilcjkvhpm6-grub-config.xml.drv
  /nix/store/abiimwy5xgk75sakhj94dzdqrbaw80q8-install-grub.sh.drv
  /nix/store/dhnvdgslkxmbk91b2kar4jd8fic7gvm8-users-groups.json.drv
  /nix/store/rr6kxfk2js4m5mxk3sn2lv26s5ycz65z-append-initrd-secrets.drv
  /nix/store/355i3miq7mqxnklj16931wylyw9jv9k4-etc-fstab.drv
  /nix/store/56j7f08fjpa01jpp81z71p7m7k8aabbc-dbus-1.drv
  /nix/store/rjlxk12b2saj9icbpr94q93wiw5i3mzc-unit-dbus.service.drv
  /nix/store/cwwxl54kshibsnzpfj6i100gh5vbw3ks-user-units.drv
  /nix/store/bm3w243r4d2xjbb49grmjqcljwi1fnj0-unit-systemd-fsck-.service.drv
  /nix/store/j4xq073mj9dfhclhyafc4l5ma9rdf0bd-unit-dbus.service.drv
  /nix/store/k26qngipdbzk1pm7id81yx3a4w9mcrbi-unit-polkit.service.drv
  /nix/store/k55by3sq0mpqj8vmdirsrv69c3lb3db3-system-units.drv
  /nix/store/wijym8zbszgvvx1cxcpc64ijcsr4bh6h-etc.drv
  /nix/store/2jasfannwyfgfbn76l4pd8ljxhxyxv3x-local-cmds.drv
  /nix/store/xga7zl87kn93aaalmgndkyrkfvxfjdjc-stage-2-init.sh.drv
  /nix/store/68svy3y789qn2l17hajvxn5wjcdfyl5s-mdadm.conf.drv
  /nix/store/7p435ka0yrjzjf3wh0a53fcn6pnms5r7-kernel-modules-shrunk.drv
  /nix/store/93vclqa9hwj7v2x23gn3s7k9gvcz3kcx-initrd-fsinfo.drv
  /nix/store/k9bbng6knwa0i6qbbnr4w3v5ld78f1in-keymap.drv
  /nix/store/rwdf3vlvf8rgq205cvr8491r4jai1d9n-stage-1-init.sh.drv
  /nix/store/zha1gangvyvg5c0jann9jkdrrsdmavwf-initrd.drv
  /nix/store/zn3q16ld35b5cpvvg7l31g2ijmwlhw0s-nixos-system-alternativebit.fr-18.09.1420.5d4a1a3897e.drv
  /nix/store/jy0c0d32a4cr27wf7gdhqfbj0ap8dcg2-nixos-boot-disk.drv
  /nix/store/0xfqlh4jwvnrgqilvgvya52yi1jw7r6w-run-nixos-vm.drv
  /nix/store/6d687z2s5a2z28x7l8xcny7x2y3dxsjy-stage-2-init.sh.drv
  /nix/store/c4rwgyd50drgmqkmk27aa2av723ic41s-nixos-system-alternativebit.fr-18.09.1420.5d4a1a3897e.drv
  /nix/store/hv6wx2722rqkxnsjx7qj606lbqf5rbig-closure-info.drv
  /nix/store/pjj1rbm174vbg76jv8wp5p08dz8n8r61-run-nixos-vm.drv
  /nix/store/28vjvznxi3cnj8mncsbdpaclhwbm40yk-nixos-vm.drv
  /nix/store/8yqcnj3q0r466nypybn06widkn5cznqy-grub-config.xml.drv
  /nix/store/3w2sif0vjy06hlf9xd971x9k17mc8hyw-install-grub.sh.drv
  /nix/store/dz0j7p9lxy6w88wd6504cp0717002nr0-system-path.drv
  /nix/store/4gjyfjmjylimw78pdsawqjaq5i8fgz17-dbus-1.drv
  /nix/store/4mscnm4jkgnddk1fmq7z6xwkjv63q4sn-unit-rngd.service.drv
  /nix/store/sgwykdwxa0ylrrc7vqr2pn44v073q0m2-extra-udev-rules.drv
  /nix/store/5cwsndj1gwz8qq6127k8mahiwklf4391-hwdb.bin.drv
  /nix/store/yng3yx0mywlai3bfprc60047f0j361gc-dhcpcd.conf.drv
  /nix/store/5w10r24zkvckmhpyb932asamg7y1asv2-unit-dhcpcd.service.drv
  /nix/store/7blkd5468wn64f1x9b1mshzjdpn81jhq-unit-systemd-udevd.service.drv
  /nix/store/adhybg6ycijs67sdk082rxwh2n6rqp9z-etc-fstab.drv
  /nix/store/cgyqfykdpxdz32yh05qlk392jrg7v8vb-etc-timesyncd.conf.drv
  /nix/store/cvpjwckd3xp6m5204fndapr9np5lijbp-unit-systemd-fsck-.service.drv
  /nix/store/dvhc6gp311dz6nb1ck3vq5gcv3msc9j3-unit-systemd-timesyncd.service.drv
  /nix/store/fzdxdnm3la55k83hdwyp65x4cp41jn3x-unit-dbus.service.drv
  /nix/store/qw1pxa9jhc4mywdz9aqajwi5qwnp0dwa-unit-polkit.service.drv
  /nix/store/i6i0xrfdzw2fpawxy8vikr07nfyi2bgx-system-units.drv
  /nix/store/dacyniamm5rpblhn42n2is8lzb0fp4wh-unit-dbus.service.drv
  /nix/store/kpv6zimixcxzdkaicabim358ld0357yn-user-units.drv
  /nix/store/wq3n2djlcpfgdl9vqk17ki6zjidsv26k-udev-rules.drv
  /nix/store/8hjxc6rsglw20f6z96aw9j2gdv2nd5vn-etc.drv
  /nix/store/8ww80sprnbklnwhd51xl3c3rsg239d0n-initrd-fsinfo.drv
  /nix/store/a1dsmzp96f62xg7fv789797z2k3ypx6c-kernel-modules-shrunk.drv
  /nix/store/gvvny05px8qwjmfikri0mvmjqyvfpwqa-users-groups.json.drv
  /nix/store/k5xc7l58jpw27bpv8ks404zlnwrzpgj6-stage-1-init.sh.drv
  /nix/store/nnxkbpj3fmvwkdqws0rzmzyd9khj0j0m-nixos-vm.drv
  /nix/store/rkiy0y5adavbg7577yyg39lqn9b5sgqi-initrd.drv
  /nix/store/zslqc7qaknbfn0dihj5w6520a354v04m-nixos-system-alternativebit.fr-18.09.1420.5d4a1a3897e.drv
these paths will be fetched (84.99 MiB download, 454.82 MiB unpacked):
  /nix/store/044ih3akb7lwhchv5rl2wslifnpi3dsz-mesa-noglu-18.1.7-drivers
  /nix/store/0fnpfbv0wg9rnykplpnyjpql11kz3rs3-libomxil-bellagio-0.9.3
  /nix/store/0njxikghr5s5y3mbxwrcmc76gc0gxlk2-libdrm-2.4.93
  /nix/store/0qx75w9g8nwycpqrpc7xn1jiy8g9qji7-vte-0.52.2
  /nix/store/0sarg0z2l0qhrbff55rz27cd9g708lrz-epoxy-1.5.1
  /nix/store/0vk7ivr7pp7bphx8cmv4gvra93pwxgmg-libXi-1.7.9-dev
  /nix/store/0xgmyrx8086kljddblrirfkbs8ck26c5-cups-2.2.6
  /nix/store/17am6bza1av8i1gllx9aszgan8nhx65k-dconf-0.28.0-lib
  /nix/store/1hwxrxmwxni4p5d1cbxb01rlsqfl4y9p-libGL-1.0.0-dev
  /nix/store/1nnplnv2xn6gh1m66sjcvpw5gm8x0j0n-libdrm-2.4.93-bin
  /nix/store/1w1rryb0knx2x6sfp1jj9y9nqfapwr1v-libxkbcommon-0.8.0
  /nix/store/1whmyf4qpvrh4ydgl7nw7hwv77ay8g3b-libxcb-1.12-dev
  /nix/store/29l32ad1pc593bvaz9r802psnyz7sdsl-SDL2-2.0.8
  /nix/store/2ar3wn4xwwvzyxi34p12kh97hbq71n6h-nettle-3.4-dev
  /nix/store/2kqjjpg0slscm4frm6shdmlpinpkn6l0-libXrandr-1.5.1-dev
  /nix/store/32ayyxv62j400sim448lg1z73fnwlqmq-gettext-0.19.8.1
  /nix/store/33dirx4d9wm176w424jr59asvf1bhywv-libXdamage-1.1.4-dev
  /nix/store/3q86fk8zrn53sw3md122p43fsqf2zybw-libXxf86vm-1.1.4
  /nix/store/4p88zybzrsg5vgm09jwylzyw5v9vb6xs-libjpeg-turbo-1.5.3-bin
  /nix/store/4ps4yzv9lw772xqkb7sswp0rgmdp3rmn-expat-2.2.6-dev
  /nix/store/57nxbb09cyqx3al7axrrif2scafpwirl-jq-1.5-bin
  /nix/store/5am4ph6cvpcdnmw2kmj1zws0k86krri5-fixesproto-5.0
  /nix/store/5n1xwwvnw3v9igik1ixq2siv846bihsd-gdk-pixbuf-2.36.12-dev
  /nix/store/5papm7iy6207j1zn4cijdc8wlg7v6y10-mesa-noglu-18.1.7
  /nix/store/6dx3270dvf6bkalldvvgz0hcqp89wb8g-glibc-iconv-2.27
  /nix/store/6qlyc5b20r861ljkgagr8hqwk4sb8x06-python-2.7.15
  /nix/store/6qv4njj1zw6m2yjh0gcxmybhlsx0ii9j-wayland-protocols-1.16
  /nix/store/6rd2yk59zhjf56gm8d9if86crxvj3bac-spice-0.14.0
  /nix/store/73dhmykksrhl294kx3a518xg17bbr8kz-cups-2.2.6-dev
  /nix/store/755ism6nzmih63mkv78981jpdd7kqrxv-initrd
  /nix/store/847y2nbzll9j4mc58yih0b8zwbw5lwz7-libXvMC-1.0.10
  /nix/store/8fz98xhlk563kgsvmvihyj8m6i22pcc7-libogg-1.3.3
  /nix/store/8gm4zbvvdbnhbybrhm2cbzqkpkdlrlnq-libffi-3.2.1-dev
  /nix/store/8hhzkpwg0av28n03jd9crd4rpj6a8fpa-libXv-1.0.11
  /nix/store/8k2iby14iflz9wn8g8s3s8wa5v70s0di-renderproto-0.11.1
  /nix/store/8y421rdn40z4lqq04596kx1ya2d96iqb-libXau-1.0.8-dev
  /nix/store/93gm3fqaml75zmcc0674sy5k0w8ssjn8-gtk+3-3.22.30-dev
  /nix/store/985gmk6iri26qll1yqm0w8q1ih34d0f4-usbredir-0.8.0
  /nix/store/9irxxc8h4kbw1f8kwyp4448d9ln176gs-libtiff-4.0.9-dev
  /nix/store/9p1dqfvw4x3qp2adfgirw6790y8qvrln-autogen-5.18.12-lib
  /nix/store/9q5j5h83sivxx44ai532g2pkrr5vflbg-speexdsp-1.2rc3
  /nix/store/a0p0sd84yymb6zlay9wjm34hgr33ccan-gtk+3-3.22.30
  /nix/store/arlsi185rckwkrji6ayllnsbfgn80bi7-llvm-6.0.1-lib
  /nix/store/bbx1l1ljdjba237iaw5yvsrzq3hx65nr-qemu-host-cpu-only-for-vm-tests-3.0.0
  /nix/store/bdd20x4nnfkw1rmy9n0wj1p6p54h921i-xproto-7.0.31
  /nix/store/bfrvh4fpdz71g06m3z5559l65n0cmdlz-mesa-noglu-18.1.7-dev
  /nix/store/bjk3w674k67vvladazrlhs9m6lz5nvqk-cairo-1.15.12-dev
  /nix/store/bvbj06m245lbz26zzjww5z65p3b6r7yc-xineramaproto-1.2.1
  /nix/store/c62s4xk9nvx0v1ljlmfvb7izjkjnrmg9-wayland-1.15.0
  /nix/store/c9471ygh10cvbys3ilxbb54ldpg5yara-libXrender-0.9.10-dev
  /nix/store/cb0n9fv4gfykkycqmj8p9ai8qsjv0y2i-kbproto-1.0.7
  /nix/store/d07rplv06pgilqhar8zyfw965s9nqy2h-pango-1.42.1-bin
  /nix/store/db81kl5z7iadis1jmsqwa0m3gccnx7pv-libjpeg-turbo-1.5.3-dev
  /nix/store/dhrcg5drmihd0s4cmavg4dj5x9h628xm-zlib-1.2.11-dev
  /nix/store/dhwmp45fw81h5dx21453mdb90zfqkqay-libxshmfence-1.3
  /nix/store/dj3sdmwgfqbnn09bdf6spzw5p58ck0jq-pkg-config-0.29.2
  /nix/store/dzg92k3h3f2590rzwkkdgjhm7hzcqm7g-pcre2-10.31-bin
  /nix/store/f69ms8smldwfbba8s9b7n8in9afrmlxy-udev-rules
  /nix/store/f8xx5xjrf6s87s8wkxwyw516h3vpaznr-fftw-single-3.3.8
  /nix/store/fm0cl2sb112r4r6npxmw359wlmfakf1v-at-spi2-atk-2.26.2
  /nix/store/fpi95dnl53sa33qflwcglg0ly8zkrrgz-gptfdisk-1.0.4
  /nix/store/fpzn6dd3zl7alzjw4kfm9h4sh5lc0674-recordproto-1.14.2
  /nix/store/fw6kv6w6fjh5q7pmnr470pkp93ds13hb-libvorbis-1.3.6
  /nix/store/fyl6hvjgjzr43n6xwdbmai5ziv33w5p3-libXft-2.3.2-dev
  /nix/store/h2y23zv427cghcjdm0f2gmi6k2bijx57-libpng-apng-1.6.34-dev
  /nix/store/habc1ik5m90laf8hg2qrbyw9ls1y0l81-jasper-2.0.14-bin
  /nix/store/hc1pr3gmyjvl3x12iizh3kp09k35dx54-libXinerama-1.1.3-dev
  /nix/store/hix9xmrji19m4fs9vj371xq3g14ai74g-libpciaccess-0.14
  /nix/store/hj4y5krr6hgd2cah7qwrvpp3brygbqj2-qemu-host-cpu-only-3.0.0
  /nix/store/hp2rsb9j7k1i4shwm62y3fj6y0b60dmf-xkeyboard-config-2.24
  /nix/store/hpfrjdc8nm8rzgf31hps2yl5p072rvbv-xcb-util-0.4.0
  /nix/store/i9m39nd026k3nrqf41362qnkvhnhxq3f-virglrenderer-0.6.0
  /nix/store/ipba8r4418ls0j55p5y5gi4zmg2kna5n-gmp-6.1.2-dev
  /nix/store/iqvaq64hi6527l0yg01rp0digq07jmin-onig-6.8.2
  /nix/store/iqylql44flvay2fibls0gcxfkpx3ahdz-libXcomposite-0.4.4-dev
  /nix/store/j1gfp22j516j4v6f4xsjy5vdfsjngnjq-inputproto-2.3.2
  /nix/store/j5824xjv2mrzpa6bnwhh2bffgc64g3d8-libpulseaudio-12.2
  /nix/store/j5kg48z065dalnlmkcr5a2mwc2gwkh6c-mtools-4.0.18
  /nix/store/j7rjm10in090fpmwqdmb6np0pc3yl32c-qemu-host-cpu-only-3.0.0-ga
  /nix/store/jr0igqm4iy2gsa9l3rx1krn65i9dygf3-jq-1.5-lib
  /nix/store/k44a93h60ywpi44xdz7liga6lqyy72py-extra-utils
  /nix/store/k976m4xm2iy6zfgrabaxc7z9gp2r6vk2-libXcursor-1.1.15-dev
  /nix/store/kcn3yv1k67wi7mqszv9831zkbvb96vj8-snappy-1.1.7
  /nix/store/kd3h2d854nmypjnlmn6k71241cj4lxhj-compositeproto-0.4.2
  /nix/store/kkczf0s9g04f5sfiwzd7y0f0qj0hkrgw-glib-2.56.0-dev
  /nix/store/kkz8zrwh4r3cpssmgwiwhwfcyipc37zc-at-spi2-core-2.28.0
  /nix/store/kxz25dc76m0rmxl9kw004km3sdsi5liy-util-linux-2.32.1-dev
  /nix/store/lmw6ps4lmqnpa8rqar981r9ycjyb2n17-pcre2-10.31-dev
  /nix/store/ln7qxilv7kxqja5h5w1bgf9r29s2xawg-randrproto-1.5.0
  /nix/store/lpx9dhhzbnvimpkm4v7acxdaakgi7iwg-autogen-5.18.12
  /nix/store/lr4q2vqb86kyi5in3d8bjrh0npmp2fpf-gnutls-3.6.2-bin
  /nix/store/m3qnk7230x3zng1mqhjmhqwwzgl15y4x-scrnsaverproto-1.2.2
  /nix/store/nd07anmjq1klrn16g461qznjsk0lyd9g-pango-1.42.1-dev
  /nix/store/pc6h838ik0yb0rndfqngajwd4yynsbin-fontconfig-2.12.6-dev
  /nix/store/pda740qpdg8nirlzjk18l92565s8ina2-libtiff-4.0.9-bin
  /nix/store/ps3yzkv08x32smyr3arzk0403f38m1b8-atk-2.28.1-dev
  /nix/store/q3ridw6xdmf0py4fkl5iyz5qkqpw8h19-libpaper-1.1.24
  /nix/store/qcm7wxncrs6s045pr9cq2z8h2irb4613-libXdamage-1.1.4
  /nix/store/qiv51flrar60yx3nazn2bx9dwyyqp2kh-harfbuzz-1.8.8-dev
  /nix/store/qmrraik4xfwm7igq6c1l68salc0v2g23-gdbm-1.17
  /nix/store/qsvyz09nl9qcgkjqn1ljxzcjnynr1f2b-numactl-2.0.12
  /nix/store/qw61y70lrrailcn6w8i8ha1ajj905smr-libXtst-1.2.3
  /nix/store/r81p2x8zxrgxilvricgah9alkw5prz0n-libXxf86vm-1.1.4-dev
  /nix/store/rcqvp4cg75dz9dj5s83262xnmwjy9lvb-xextproto-7.3.0
  /nix/store/rmzxkjkyhlrr70cdvazpscsx5zh3fkwn-libXScrnSaver-1.2.2
  /nix/store/sfnik1cjki69gh70d4fbw0inc3kcxv9g-gsettings-desktop-schemas-3.28.0
  /nix/store/sn6l14lxz0v188wqwc7lpimf723scnkd-vde2-2.3.2
  /nix/store/sr8lgrbrxmmp6f1z0pr1m3krlr6dsazp-xz-5.2.4-dev
  /nix/store/vancdy0plyjzm0m7zwp8a821b4c58m4a-libGL-1.0.0
  /nix/store/vyxjnl1n0wqbwkcyg5gh3rgc1ci9ii9c-xcb-util-0.4.0-dev
  /nix/store/w8833ihykqsinx2wzgnw60jw66l2z8cm-libXfixes-5.0.3-dev
  /nix/store/wyl8bwby5n7sykd30b26l278cg547dj4-libpcap-1.8.1
  /nix/store/x48bylmg68wlk2763an55sqk7pmmh14y-jasper-2.0.14-dev
  /nix/store/x8m2d55l6y585djs02dshd0qaasb46fn-xf86vidmodeproto-2.3.1
  /nix/store/xycjz3xr3zcigpqhwkarf1kai9i4f0ks-libXext-1.3.3-dev
  /nix/store/yds3kxq3jqi9wcsxvp4ncazjgnb0p9n8-libsndfile-1.0.28
  /nix/store/z61za4nin8hs24wpqqmk54qak2wv8gq0-celt-0.5.1.3
  /nix/store/zavrkx3070qvv5zv8840grl8jrzp3wsk-freetype-2.9-dev
  /nix/store/zgal8qx33hhky4zck5i7xlz26nwjpy8s-gnutls-3.6.2-dev
  /nix/store/zhd6ybmvrhwxqdwqah9jlas9vnhz825v-libdrm-2.4.93-dev
  /nix/store/zhdgkqwra0zl8437bjy1kqv8p44nxqxv-libSM-1.2.2-dev
  /nix/store/zirndj8davmkjsm0aqx7fvh7ribdm7j5-flac-1.3.2
  /nix/store/zk120bhr8xv6v8qd81yy1zbnaq2q8l2j-grub-2.02
  /nix/store/zplplwngw36wawq11clm96mbsniw285c-libICE-1.0.9-dev
  /nix/store/zqrklfsn1m734d46pqcl50cmakczyr80-libX11-1.6.6-dev
This looks like a sandboxing issue. Could you try setting one of these:
https://github.com/obsidiansystems/obelisk/issues/172#issuecomment-411507818
Otherwise you can safely disable sandboxing with the sandbox false option.
Hey matthew. Indeed, it’s probably a sandboxing issue.
In my last post, I disabled the sandboxing in /etc/nix, /etc/nixos/config.nix (from both the chroot and the host config) as well as passing it via the CLI -option "sandbox" "false". For some reason, the configuration is ingnored and the build is occuring in a sandbox anyways.
I removed the installation, I can’t give you an access to it anymore. But I’ll try to reproduce this issue locally and open an issue on the nix repository shortly :wink:
The solution is: don’t chroot, pivot_root.
  1. Set up your chroot environment as you were, in say /real-root, and get the path to init (e.g. INIT=$(find . -type f -path '*nixos-system*/init'))
cd /real-root
mkdir old_root
mount --make-rprivate /
pivot_root . old_root
$INIT
  1. Now you’re in the livecd environment (ish), proceed to do your installation :slight_smile:. This worked for me when I needed to reinstall NixOS on a Kimsufi box today.
This approach doesn’t work if your filesystem or something else needs kernel modules that the Kimsufi rescue system doesn’t provide. If that is the case, you’ll need to create a NixOS chroot that you can kexec into, so that you get the NixOS kernel as well.
See https://github.com/nix-community/nixos-generators and https://github.com/cleverca22/nix-tests/tree/master/kexec for some existing sources on the kexec approach.
