Nixos-rebuild fails trying to build nixos-rebuild.drv
I’m suddenly unable to rebuild my configuration.nix. The only thing I did was add cron to systemPackages.
Here is the error I’m getting:
$ sudo nixos-rebuild switch --upgrade-all
[sudo] password for [user]:
unpacking channels...
  /nix/store/pbnjq8y0bdjz177125k0z3ngyjilnlv6-nixos-rebuild.drv
building '/nix/store/pbnjq8y0bdjz177125k0z3ngyjilnlv6-nixos-rebuild.drv'...
/nix/store/ymi8xq5lxkjhyhk6sfb5d32nkbqz9pvg-substitute.sh: line 23: installManPage: command not found
error: builder for '/nix/store/pbnjq8y0bdjz177125k0z3ngyjilnlv6-nixos-rebuild.drv' failed with exit code 127
building Nix...
these 30 derivations will be built:
error: builder for '/nix/store/jxj95vsq0apyijlcqz3w2qwliwsrsxl5-nixos-install.drv' failed with exit code 127
error: 1 dependencies of derivation '/nix/store/bwy1gyilsjs365afr0026j74h48mfgl4-system-path.drv' failed to build
error: 1 dependencies of derivation '/nix/store/q2b9f0pz0pna0q3n7p7ax39l4z8f9nzj-unit-script-nixos-upgrade-start.drv' failed to build
error: 1 dependencies of derivation '/nix/store/i5xqlnj7q1hwqcr6jl4gb1b2gvw5q1dp-nixos-system-thinkpad-24.05.6122.080166c15633.drv' failed to build
In the process of trying to fix this, one post included a garbage collection so I’ve lost my generations history – but between the last few generations the linux kernel toggled between 6.6.57 and 6.6.58 a couple of times. That’s the only other thing (besides adding cron) that I’m aware was changed.
Generation   Build-date           NixOS version            Kernel  Configuration Revision  Specialisation
223 current  2024-10-27 06:21:02  24.05.5993.cd3e8833d706  6.6.58
Any help or suggestions would be greatly appreciated.
…if I include the --show-trace flag, I get more errors (and more derivations attempting to build):
$ sudo nixos-rebuild switch --upgrade-all --show-trace
building Nix...
these 66 derivations will be built:
  /nix/store/01ah95l0rr1hr3yr4syr402win5356g9-string-hosts.drv
  /nix/store/0f2636n8wwn1gmvvqmx1sw1y1aamzxmj-unit-gdm.service-disabled.drv
  /nix/store/107ivzyfghdrdcacj4ci3lq9287ynzxh-nixos-manual-html.drv
  /nix/store/14xqw0hxgp9zq49qh2ay0470jf6iasg0-shutdown-ramfs-contents.drv
  /nix/store/3h9697jy3znzkwahafx7ygv9h52z4q6y-unit-nixos-upgrade.service.drv
  /nix/store/vp2nmzlaq3a05fs4szi0dpg1jvnmcika-systemd-boot.drv
  /nix/store/47ng1nqgnd9daprm5l5smnrj8pz4g7xd-install-systemd-boot.sh.drv
  /nix/store/4j4aim045phny9vyhnhb8lbgfyfjr6s0-udev-rules.drv
  /nix/store/iw6abs9sp1mmlvr6v7i5rk5wnkd1g6di-nixos-version.drv
  /nix/store/yll32hrgvh5x3m3v8qz6dyn3ah0xqa84-torbrowser.desktop.drv
  /nix/store/jnbi0qhmn80w5jqv0v0hpz68fh6cncyq-tor-browser-14.0.1.drv
  /nix/store/sdzdg4w4y97rn2yvna1h33svzvmr928a-nixos-help.drv
  /nix/store/zn28xwww1krl96s9mvclrpp7dyl8p2rl-nixos-help.drv
  /nix/store/51hwxzbmkf485x3vp8qykwrzdy0bq6b8-unit-accounts-daemon.service.drv
  /nix/store/i0g4wrgnza84fq1ci9q7g675hgdazzh3-gdm.drv
  /nix/store/rmw9zg8bb5bf9308hxgdi849nvaiv4sv-gnome-initial-setup.drv
  /nix/store/6rynqhp651qcw1n3nvbza2fvxjmn89jl-dconf-system-config.drv
  /nix/store/7yvk0gcw66n9473j3rk6g3h2alkf8n6c-system-shutdown.drv
  /nix/store/akf6l485q6b89rc8fhwlndnj9np93grs-tmpfiles.d.drv
  /nix/store/sx3n4wmjfswxks55maja25i7hhrq37np-dbus-1.drv
  /nix/store/ww6y2f3k1ix1wp5cgxny371c62xssni4-X-Restart-Triggers-dbus.drv
  /nix/store/7998bz0cxdgkbainp2ik8xind5fvv75k-unit-dbus.service.drv
  /nix/store/dh8cr1y8gyc0l39s7xkhng8yjdyq0ppx-user-units.drv
  /nix/store/dhfjyr46pqd7zgsvjmsbzivzc25h6baq-nix.conf.drv
  /nix/store/i3fvkwbp3yy7vjj9palsblyxva5x015g-hwdb.bin.drv
  /nix/store/lh6mclm1ybhwsqd05sy5fqnr0jh4gmny-user-environment.drv
  /nix/store/rv72wa9656f5jg4z4wc54fplqnf2llw4-fontconfig-etc.drv
  /nix/store/dwqzbyjb8qh2lgfn92f13wzgw1wy4njw-desktops.drv
  /nix/store/v25caljhgrlfid2q46grcafcckf84h10-etc-pam-environment.drv
  /nix/store/vasrxjrcp4qm251l4bz6awf4xn1i3q7s-system-generators.drv
  /nix/store/vfhzkj1fffj8sfcrwz6ssny9f7vwixxc-hosts.drv
  /nix/store/xh75mgjslyjind4wrbxpnibxmzhk54v4-set-environment.drv
  /nix/store/55qzi9lax3k9myx4vc933x36pdzbjcpf-unit-console-getty.service-disabled.drv
  /nix/store/p2mi8bfldaa6l9q5hj21sb37caygn3cg-X-Restart-Triggers-systemd-tmpfiles-resetup.drv
  /nix/store/59jwazqw99ca2q2x3zbmv55ilxlzizrk-unit-systemd-tmpfiles-resetup.service.drv
  /nix/store/72swpkmi8mxzzzgxr4irpqy1yiz6crrb-unit-nix-optimise.service.drv
  /nix/store/hb0y67pc3ds61fjmmn9kb74ar891xpbs-X-Restart-Triggers-polkit.drv
  /nix/store/93ir7k81vy55x3d5s0mgy8cwc8qjdwii-unit-polkit.service.drv
  /nix/store/9gwng3blfwwliafnn5z54q3bxmkq6kqq-unit-wireplumber.service-disabled.drv
  /nix/store/ciwx2zp9g2qbdr581bvm1gdddcwrcw04-unit-generate-shutdown-ramfs.service.drv
  /nix/store/lm0wb84963sa13cbi1mph7226p0jxnpg-nftables-rules.drv
  /nix/store/dzv5z7m9z7k27k4jsas5hhyd58lrjhg5-unit-nftables.service.drv
  /nix/store/gjzyrm351r1hinh1d0xgg134jsbqsfm8-unit-script-nix-gc-start.drv
  /nix/store/g8rr65z4crjnxqkrwn4l20xl86pzf8pc-unit-nix-gc.service.drv
  /nix/store/qrxffifhkmbdd15d81294vjrn4cx3f42-unit-script-display-manager-start.drv
  /nix/store/hal27w6irmhfp63hdzzd8ib3jb79y1b4-unit-display-manager.service.drv
  /nix/store/iiq8b1bcdkcn813njxadfnv1bksvvwa6-unit-pipewire.socket-disabled.drv
  /nix/store/kxj7lbn6jp38drp0nxrqf48sd1icslnl-unit-pipewire.service-disabled.drv
  /nix/store/ni65m9qz3jwmlr420ycdwmg0h2z7x3j1-unit-dbus.service.drv
  /nix/store/sp61gadrl8bk1gmp9jkd7hchnx62khd1-X-Restart-Triggers-systemd-udevd.drv
  /nix/store/sm3skp4dv5dpn0spdd5b6g59565kqyv7-unit-systemd-udevd.service.drv
  /nix/store/67540milbgfx9s8dayqlgyg0czkq9n9g-X-Restart-Triggers-nix-daemon.drv
  /nix/store/vl483x5qzgk94jifx5nv309kz5q25mz7-unit-nix-daemon.service.drv
  /nix/store/xzpkg8hxkfm66jaw4i9n4370rbpz7hdg-system-units.drv
  /nix/store/y6a0hvsi511fmsva5rpay0y1x55zic07-etc-profile.drv
  /nix/store/528l4gzwd0jd8fl5rir8awsvr248l1qr-etc.drv
  /nix/store/sd6m46yqxwa6kcvqpnb3rdcgph8kwns9-linux-6.6.58-modules.drv
  /nix/store/a5qbg5kaylqr32dqb9sibhf9i5yi5mic-linux-6.6.58-modules-shrunk.drv
  /nix/store/wrwvsy4pr5r0vwiasx0r5cv6mqn6mpcy-stage-1-init.sh.drv
  /nix/store/llaxyg7gk1klzibiq9lg7kddlp708pvr-initrd-linux-6.6.58.drv
  /nix/store/p00z5mmnkx0hccqj34wrr5h1frhip3wp-boot.json.drv
these 61 paths will be fetched (494.99 MiB download, 1438.53 MiB unpacked):
  /nix/store/4ibrw2afjwz5zfrvzf7dncbwv375c1dc-alsa-lib-1.2.11-dev
  /nix/store/ibw76ifhbc8w9lza5176fkaws8v8yn32-auto-patchelf-hook
  /nix/store/si9c1ncjikjq2hl5m8i6dzrfznmsz7g5-binutils-wrapper-2.41
  /nix/store/w0k2k9x26wzv18c3zkvgcg3zqksq4mln-binutils-wrapper-2.41
  /nix/store/s7274780s6jq33vmbjxkl0jbh5c1gz35-bisq-desktop-1.9.15
  /nix/store/yihv7jjrjd17pwb8sz4vanqmas5bica8-bisq-tor
  /nix/store/sla29qvjdiqh51z9jw0xxg3nqmx697qm-dbus-glib-0.112-dev
  /nix/store/xp400zj9kmllwld23mvr37az864dzinb-documentation-highlighter
  /nix/store/zkk5cnv8h35x69s2qwi4rgpyck7ijp3j-electron-32.1.1
  /nix/store/q206v5dd3x9libh5s2lw2jg53gy6lvfk-electron-unwrapped-32.1.1
  /nix/store/b3mcdijf2h98nzv4yn9d4kykqlbaabnq-element-desktop-1.11.82
  /nix/store/k5s80gd9gx9g94k2zg8dkl4zv287mppk-expand-response-params
  /nix/store/sf915hs92m1vksvh1dhf41klq3ch0s1l-expand-response-params
  /nix/store/bclcvk7n5ylciimklhncpgwzb79nclsd-fc-00-nixos-cache.conf
  /nix/store/jdmsfhl8dpk2lin37h2s76y3zr3bqhh5-fc-cache
  /nix/store/y1ckj126c6686ndn60w9grms8z2brkv9-firefox-132.0
  /nix/store/ixjwispzpi4pp7i1609rajhky949vrm5-firefox-unwrapped-132.0
  /nix/store/4xp51rm65hgvll0iw7h6g9mg285dkqs0-fontconfig-conf
  /nix/store/r6k305g2rn0qqkvdxfvzqg7mhh7rw679-gcc-wrapper-13.2.0
  /nix/store/1llwdvihd19v0x5jz5x58rawq3kkpjny-gdm-46.2
  /nix/store/9487rx05xg2nvn41bjxzb71ib4kqwyb6-gnome-browser-connector-42.1
  /nix/store/ny81nwx919mxmdp4h0hxz97fb1amrkm4-gnome-control-center-46.2
  /nix/store/ylfz18m89lcb3mh9yl1xpaly9n7dfvfw-gnome-gsettings-overrides
  /nix/store/gpjn6l82sr0l41xq2kgmy4mlzy7dzzck-gnome-initial-setup-46.2
  /nix/store/9kd2qk8jjw8yihb4bsndj4g5ihx8qpim-gnome-session-46.0
  /nix/store/l6n183xkfr507zn1jf8zh7qcrwa43f1s-gnome-session-46.0-sessions
  /nix/store/fn424130j8yjky1zacgkjkrja0z95d8l-gnome-shell-46.2
  /nix/store/0x90crca9mrfazrn8y68fdhn0p3rhpwb-keymap
  /nix/store/mrc745kh1db9fc3fwgyzf21lvr6wxkkv-kmod-31-dev
  /nix/store/218hhm3cnpgfw81hw442ncanv2nwydid-libarchive-3.7.4-dev
  /nix/store/nr5q12bcab7qnqwv9rc2z4s2i2jw1w57-libredirect-0
  /nix/store/h70wvqfibwzbnaw19f907mgznh0sgsxc-link-units
  /nix/store/qf8nbw2s6rchr7l63n3kjbwdxj1r4c4b-lkl-2022-08-08-lib
  /nix/store/ifh7bm8n5syhka1kzirbaxyhf0ywcdjm-make-binary-wrapper-hook
  /nix/store/550qbd6mwglsfl1kpbgdaqxjvq5y3pw6-make-shell-wrapper-hook
  /nix/store/ydh90p60l5l7wq914qn76kfvc0xjgcfq-mutter-46.2
  /nix/store/5mnx5pgchj5j8ynm82a9c99h5h157fkx-nixos-render-docs-0.0
  /nix/store/js060hclsb55xmjasp2kzmy5070rdmd1-nixos-test-driver-docstrings
  /nix/store/hryvppqpddlpb1va8liq13awq0g2apmg-nss-3.106
  /nix/store/74vgi24ip5kqkbr79yh4kndsd9yfqfhs-nuke-references
  /nix/store/6gra549czdh6r32dzbsj686n5zaq4282-options.json
  /nix/store/c8livzcvaxq589mq6dgy3dbvziy37py4-options.json
  /nix/store/7dwsrsqqp4cvdwwxlpadbk375z7xfdc1-patchelf-0.18.0-unstable-2024-01-15
  /nix/store/vg326ppi4f7k00zcph0bg404h95k1126-python3-3.11.9-env
  /nix/store/wwf1dzxiwsldwwc888hsz4rd2px6njd1-python3.11-markdown-it-py-3.0.0
  /nix/store/l4ghpqszighn3rbrzzdxds1b92p9q7r8-python3.11-mdit-py-plugins-0.4.0
  /nix/store/iv4rcz0m3sm469657m7azgsqpcm6n35y-python3.11-mdurl-0.1.2
  /nix/store/x6w4yvg3f944a9m7xrmlb6a2q7xf99dq-python3.11-pyelftools-0.31
  /nix/store/9qiy2hyyd4v96s9zwinhlf4q2ab1sazn-sparrow-modules-1.9.1
  /nix/store/y73hypf74slfr0g5xrr8zjqc8r70g2rd-sparrow-unwrapped-1.9.1
  /nix/store/479jddljb3spih04qb01qlyv39qb2zn9-stdenv-linux
  /nix/store/wvkmvd1l3izbasb7qmfg93470c3vxzsf-systemd-default-tmpfiles
  /nix/store/qyvz82c9asikwv1d3pgwvgdvb8bl0c96-texinfo-7.0.3
  /nix/store/7i5qcshkq7brb8n0bxdkmb1vfm1pwbbc-tor-0.4.8.13
  /nix/store/bvj9ifbansv4wc2m44b0w8clvbqqd348-udev-rules
  /nix/store/31im4vmd4r0qyg431k6xcv8k400k6g7c-unifont-15.1.05
  /nix/store/kqa6a9kkl8q0ndpigwf45al30j3qw7vx-wrap-gapps-hook
  /nix/store/5c6v72vz13zljyrwcbwjz1ricvjr58kf-xf86-input-evdev-2.11.0
  /nix/store/h3a533hiipngraha21wpgqyhf2wxag8x-xf86-input-libinput-1.5.0
  /nix/store/6v3i4vjnxjjxjwliii937c8yd3r0vk8c-xserver.conf
  /nix/store/l7wnw0wddygxypb57c7g7wfvvkvgqib2-xwayland-24.1.4
building '/nix/store/sd6m46yqxwa6kcvqpnb3rdcgph8kwns9-linux-6.6.58-modules.drv'...
copying path '/nix/store/qyvz82c9asikwv1d3pgwvgdvb8bl0c96-texinfo-7.0.3' from 'https://cache.nixos.org'...
copying path '/nix/store/7i5qcshkq7brb8n0bxdkmb1vfm1pwbbc-tor-0.4.8.13' from 'https://cache.nixos.org'...
copying path '/nix/store/5c6v72vz13zljyrwcbwjz1ricvjr58kf-xf86-input-evdev-2.11.0' from 'https://cache.nixos.org'...
copying path '/nix/store/h3a533hiipngraha21wpgqyhf2wxag8x-xf86-input-libinput-1.5.0' from 'https://cache.nixos.org'...
building '/nix/store/dhfjyr46pqd7zgsvjmsbzivzc25h6baq-nix.conf.drv'...
building '/nix/store/jxj95vsq0apyijlcqz3w2qwliwsrsxl5-nixos-install.drv'...
building '/nix/store/iw6abs9sp1mmlvr6v7i5rk5wnkd1g6di-nixos-version.drv'...
building '/nix/store/vp2nmzlaq3a05fs4szi0dpg1jvnmcika-systemd-boot.drv'...
copying path '/nix/store/4ibrw2afjwz5zfrvzf7dncbwv375c1dc-alsa-lib-1.2.11-dev' from 'https://cache.nixos.org'...
copying path '/nix/store/sla29qvjdiqh51z9jw0xxg3nqmx697qm-dbus-glib-0.112-dev' from 'https://cache.nixos.org'...
copying path '/nix/store/xp400zj9kmllwld23mvr37az864dzinb-documentation-highlighter' from 'https://cache.nixos.org'...
copying path '/nix/store/ylfz18m89lcb3mh9yl1xpaly9n7dfvfw-gnome-gsettings-overrides' from 'https://cache.nixos.org'...
copying path '/nix/store/0x90crca9mrfazrn8y68fdhn0p3rhpwb-keymap' from 'https://cache.nixos.org'...
copying path '/nix/store/h70wvqfibwzbnaw19f907mgznh0sgsxc-link-units' from 'https://cache.nixos.org'...
copying path '/nix/store/550qbd6mwglsfl1kpbgdaqxjvq5y3pw6-make-shell-wrapper-hook' from 'https://cache.nixos.org'...
copying path '/nix/store/js060hclsb55xmjasp2kzmy5070rdmd1-nixos-test-driver-docstrings' from 'https://cache.nixos.org'...
copying path '/nix/store/6gra549czdh6r32dzbsj686n5zaq4282-options.json' from 'https://cache.nixos.org'...
copying path '/nix/store/c8livzcvaxq589mq6dgy3dbvziy37py4-options.json' from 'https://cache.nixos.org'...
copying path '/nix/store/7dwsrsqqp4cvdwwxlpadbk375z7xfdc1-patchelf-0.18.0-unstable-2024-01-15' from 'https://cache.nixos.org'...
copying path '/nix/store/9qiy2hyyd4v96s9zwinhlf4q2ab1sazn-sparrow-modules-1.9.1' from 'https://cache.nixos.org'...
building '/nix/store/i0g4wrgnza84fq1ci9q7g675hgdazzh3-gdm.drv'...
building '/nix/store/rmw9zg8bb5bf9308hxgdi849nvaiv4sv-gnome-initial-setup.drv'...
created 3 symlinks in user environment
kernel version is 6.6.58
Validating generated nix.conf
/nix/store/4vq3350zc6sqnibkqpgic2d6cvi1r9hq-substitute-all.sh: line 19: installManPage: command not found
building '/nix/store/14xqw0hxgp9zq49qh2ay0470jf6iasg0-shutdown-ramfs-contents.drv'...
building '/nix/store/01ah95l0rr1hr3yr4syr402win5356g9-string-hosts.drv'...
copying path '/nix/store/218hhm3cnpgfw81hw442ncanv2nwydid-libarchive-3.7.4-dev' from 'https://cache.nixos.org'...
copying path '/nix/store/mrc745kh1db9fc3fwgyzf21lvr6wxkkv-kmod-31-dev' from 'https://cache.nixos.org'...
copying path '/nix/store/nr5q12bcab7qnqwv9rc2z4s2i2jw1w57-libredirect-0' from 'https://cache.nixos.org'...
copying path '/nix/store/qf8nbw2s6rchr7l63n3kjbwdxj1r4c4b-lkl-2022-08-08-lib' from 'https://cache.nixos.org'...
copying path '/nix/store/hryvppqpddlpb1va8liq13awq0g2apmg-nss-3.106' from 'https://cache.nixos.org'...
copying path '/nix/store/74vgi24ip5kqkbr79yh4kndsd9yfqfhs-nuke-references' from 'https://cache.nixos.org'...
copying path '/nix/store/wvkmvd1l3izbasb7qmfg93470c3vxzsf-systemd-default-tmpfiles' from 'https://cache.nixos.org'...
copying path '/nix/store/bvj9ifbansv4wc2m44b0w8clvbqqd348-udev-rules' from 'https://cache.nixos.org'...
copying path '/nix/store/31im4vmd4r0qyg431k6xcv8k400k6g7c-unifont-15.1.05' from 'https://cache.nixos.org'...
copying path '/nix/store/l7wnw0wddygxypb57c7g7wfvvkvgqib2-xwayland-24.1.4' from 'https://cache.nixos.org'...
TIA
Try running nix-store --verify to check your system.
I’ve been able to build /nix/store/pbnjq8y0bdjz177125k0z3ngyjilnlv6-nixos-rebuild.drv locally
Thank you for responding! This is what I got:
$ nix-store --verify
reading the Nix store...
checking path existence...
path '/nix/store/8mvcwn96881p7v9zgjgl6n37128ppfig-armv6-no-ldrexd-strexd.patch' disappeared, removing from database...
path '/nix/store/bkky00l9i47dls8bbc4f7h0lnkgxqlka-e2fsprogs-1.47.0-info' disappeared, removing from database...
path '/nix/store/jsnsa7phpskwpi0fk569npwdvf5h3p1x-nixos' disappeared, removing from database...
path '/nix/store/k7nvyssicgjiw2hbpw5bh0swdica7bya-installed-tests-path.patch' disappeared, but it still has valid referrers!
warning: not all store errors were fixed
…I ran it again and got:
You mentioned building nixos-rebuild locally – is that something I should try (and if so, could you give me a hint as to how)?
~~ edit ~~
…still won’t build, same error as above.
Try running nix-store --verify --check-contents --repair to try and fix the issues, then run nixos-rebuild as before.
The verify operation will take longer as nix is checking the hash of all the files, however I suspect that more files have been corrupted.
That did it! I hadn’t been able to rebuild for 11 days.
Thank you so much for your help!
=== detail ===
For the record, here were the results of that magical command:
$ sudo nix-store --verify --check-contents --repair
[sudo] password for contrafiat:
copying path '/nix/store/k7nvyssicgjiw2hbpw5bh0swdica7bya-installed-tests-path.patch' from 'https://cache.nixos.org'...
checking link hashes...
checking store hashes...
path '/nix/store/2pfhkrv67md33k8dhkfxrcz4c1gznl96-python3.11-grpcio-tools-1.59.0-dev' was modified! expected hash 'sha256:163d6gdyzg9x6xl1k9l95n3nwg9k288158f99518swy96sy79srg', got 'sha256:05s3hbrimj87q1jlv32qxxhiz9rv1vzjlhxry9kdg11pch4fi6dk'
copying path '/nix/store/2pfhkrv67md33k8dhkfxrcz4c1gznl96-python3.11-grpcio-tools-1.59.0-dev' from 'https://cache.nixos.org'...
path '/nix/store/3pcx96yxjg2wmlxaxfgq0xx3y2py2rry-qtdeclarative-5.15.12' was modified! expected hash 'sha256:0rgbgss2408dwrfsw6l3b7imz3yp0mhwhhh86dq8zm51qlgz4z6c', got 'sha256:02q9164g45p4cav27swqwq7wdwkwmzigby36pq6xq9ikpsjnp12c'
copying path '/nix/store/3pcx96yxjg2wmlxaxfgq0xx3y2py2rry-qtdeclarative-5.15.12' from 'https://cache.nixos.org'...
path '/nix/store/5y5arv2aqq9ixrb5l13whv16zgdy4cnq-install-shell-files' was modified! expected hash 'sha256:13mgmd98ygd3wfykdigqc3jv9p1dk5cjdclypcic763h6k7jnciv', got 'sha256:1v85arv9xfsp14d3cjl5snl91wvmvlr459wagwggjfqvcmvrxhdm'
copying path '/nix/store/5y5arv2aqq9ixrb5l13whv16zgdy4cnq-install-shell-files' from 'https://cache.nixos.org'...
path '/nix/store/68j2zjax7z317ak637lxk42gl4i4a2ql-qtbase-5.15.12-bin' was modified! expected hash 'sha256:0vkv5m5nzf2cmsclxy491x58822p0fvz4g5d9m8791gjzspiwx56', got 'sha256:0jzdmlwp85isx68yf3ni0ww1n4g3vh11sj6gig9ra6ldk7li113v'
copying path '/nix/store/68j2zjax7z317ak637lxk42gl4i4a2ql-qtbase-5.15.12-bin' from 'https://cache.nixos.org'...
path '/nix/store/6g1xilr5xa0l7ddbgvlsw8x250cnc7mp-qtsvg-5.15.12-bin' was modified! expected hash 'sha256:1sgz7mcawci9xs2mh1wyx3aiv114gwlc1x7qmbzg9nxxfjgxv99b', got 'sha256:0yvfmph1vsy7jzj131jq9ln0ghjy9gffbzza7vasnw5irmq96m1k'
copying path '/nix/store/6g1xilr5xa0l7ddbgvlsw8x250cnc7mp-qtsvg-5.15.12-bin' from 'https://cache.nixos.org'...
path '/nix/store/9yhibb5zxr763hbywwc8dkvvd765bjkp-qtbase-5.15.12' was modified! expected hash 'sha256:02cnwpl7i1y82g5a5xk4wmdmrwpv6mzzinwsfdkl9qxrhxpkm5br', got 'sha256:080p0pm0ry5jpsrn5bna80m7c3hbj3dcnkg8sl0zycpkzfdh5s4q'
copying path '/nix/store/9yhibb5zxr763hbywwc8dkvvd765bjkp-qtbase-5.15.12' from 'https://cache.nixos.org'...
path '/nix/store/a8nlgg9hsmyvqkvr1219ixh7z0mh4qcy-qtwayland-5.15.12' was modified! expected hash 'sha256:1g0pnr5pnpns1dq2wyfnfcqrv3vwni8pxwvhkds3d3k3bf9fkax8', got 'sha256:0jpm55bgsgx5d521zlyghgg3xl8q20sbslcvw9cfg2cknjlpn81h'
copying path '/nix/store/a8nlgg9hsmyvqkvr1219ixh7z0mh4qcy-qtwayland-5.15.12' from 'https://cache.nixos.org'...
path '/nix/store/hc3455zr373r8v74vjqk3d0arf1vkzm3-qtwebchannel-5.15.12' was modified! expected hash 'sha256:0l4dm46wrddphk30si7xrs3cbwzv34kxq5hx9bwf5lkjizq2bl4k', got 'sha256:0bgk02ckyzx51lqzy6xvn6pz0xwsyqrcskc3lvwr0w4l2bw7kmr9'
copying path '/nix/store/hc3455zr373r8v74vjqk3d0arf1vkzm3-qtwebchannel-5.15.12' from 'https://cache.nixos.org'...
path '/nix/store/hqw5yy2az0v83i8y83a2klcn2hc78cgm-python3.11-grpcio-tools-1.59.0' was modified! expected hash 'sha256:0rbzwvmajpr4zmk7cq6590jmq4rdnnpsa2pkzbnbqnlaj8avyj78', got 'sha256:02p5j7sx05xb3bp97rxhdh3g7vbvh0x6lhjxwxss988mbn0lfsg0'
copying path '/nix/store/hqw5yy2az0v83i8y83a2klcn2hc78cgm-python3.11-grpcio-tools-1.59.0' from 'https://cache.nixos.org'...
path '/nix/store/n7n0aqbafgcqy2xqd3qrfinpgxv5fd6x-python3.11-grpcio-1.59.1' was modified! expected hash 'sha256:0494b8ip2cvrxgfhv03pzgrjs5mnzbh1wm84jlj94bgq5wb2jbm2', got 'sha256:0g6sc6aa8h1f7yjiqmb69j3m2f9cf8gv7400pjs2rrrbqbjy6dwm'
copying path '/nix/store/n7n0aqbafgcqy2xqd3qrfinpgxv5fd6x-python3.11-grpcio-1.59.1' from 'https://cache.nixos.org'...
path '/nix/store/rvln33wylf6rlx40qfqxq204h48wqv9y-qtdeclarative-5.15.12-bin' was modified! expected hash 'sha256:0n0lc7d7204yh64gzy7njlkh2yv9j98r5n561qz1sbs88w8486m5', got 'sha256:1wc4a8rsr5r7q06dbfbqsv5p7rjdlyyyr02wigq2mn6y7xwhqhd8'
copying path '/nix/store/rvln33wylf6rlx40qfqxq204h48wqv9y-qtdeclarative-5.15.12-bin' from 'https://cache.nixos.org'...
path '/nix/store/rybx14sh8dfvw7iqky4sdxvpdbynhcbn-qtsvg-5.15.12' was modified! expected hash 'sha256:0qwcz8a76bnrzh1wpcyix23slp9z9267d1czyhm8wpqx638svbyz', got 'sha256:1dhsdxvd2cm09fslcb6p8ga9z2iwhjlzb177p0yw1c492i1jyc88'
copying path '/nix/store/rybx14sh8dfvw7iqky4sdxvpdbynhcbn-qtsvg-5.15.12' from 'https://cache.nixos.org'...
path '/nix/store/slyyvchkaxs9bw9s1m8qhy0arypqkkyg-qtquickcontrols-5.15.12' was modified! expected hash 'sha256:1z85g5y5g97835cb1zfa9kgm1vhyppxj320hk1qv8w1nwz5c6jd8', got 'sha256:0andzq8ip88p4ss1zj7j50j280hx4v28jcplmpsjppimc3bd5fgy'
copying path '/nix/store/slyyvchkaxs9bw9s1m8qhy0arypqkkyg-qtquickcontrols-5.15.12' from 'https://cache.nixos.org'...
path '/nix/store/ym3bq1r8vznaqdh5b9id1i5l31r0lcdl-gnu-config-2024-01-01' was modified! expected hash 'sha256:1l43qv8hnmziw5a1qfa5nv3vbwgyyzza9jlxj50p97r0ka63wjvc', got 'sha256:0fma56chsg2c6qsqqsz1j1vwl9a4br4f29fqwc4jlmjz0gc9p1d2'
copying path '/nix/store/ym3bq1r8vznaqdh5b9id1i5l31r0lcdl-gnu-config-2024-01-01' from 'https://cache.nixos.org'...
path '/nix/store/zmjp6bch2m117z4f833ajg0vj6afx6ff-python3.11-pyasn-1.6.2' was modified! expected hash 'sha256:1h87c53nyv74hpqch5w68biif4gvpbwgchkzhahy3gm07pi84j21', got 'sha256:009kxczfygqn308z5xmz8r7fqf58cq8609mx3fhj1bqlxm4wnszb'
copying path '/nix/store/zmjp6bch2m117z4f833ajg0vj6afx6ff-python3.11-pyasn-1.6.2' from 'https://cache.nixos.org'...
I don’t know how all those files could have been changed, I don’t recognize any of them. Are you on NOSTR? Or do you have a way I can send a few sats as a thank you?
Thank you for the offer, but I don’t use cryptocurrency.
The corruption you see may be caused by forcefully powering off the computer in the middle of an update on some filesystems.
Thank you again. Marking this closed thanks to your solution.
