NixOS rebuild stopped with device out of memory
I’m new to NixOS, already rebuild 14 times, but now, system just stop/freeze my pc when I try to rebuild NixOS. I’m delete all generation before 11, reboot, and nothing happen: on rebuild freeze, stopped all processes.
That’s RAM, not disk space. It means one or more of the following:
  • You’re not following a channel that is built by hydra (instead, e.g. master or release-*)
  • Your tmpfs is in RAM rather than on disk, as set by default
  • You’re evaluating many nixpkges
  • You have a ridiculous amount of browser tabs and chrome clones open
  • You have a very under-resourced system
Without seeing your configuration.nix (and potentially related files and nix-channels), it’s hard to tell you which of these apply.
Yeah, I have ~1650 pkgs
Also:
[romchik@nixos:~]$ nixos-version
25.11.6561.1267bb4920d0 (Xantusia)
and channel has:
nixos nixos-25.11 release nixos-25.11.7346.44bae273f9f8
How can I show configuration.nix?
Pastebins, sourceforges, paste here in code block. There are plenty of options.
Also please share some specs of your computer, like CPU and RAM.
I fix the issue, just remove telegram-desktop in pkgs, but it used to work for me, just a week ago I installed it and everything was fine, but now it installs a lot of packages and interferes with the build.
Also my configuration.nix:
{ config, pkgs, ... }:
  # Auto-update
  system.autoUpgrade.enable = true;
  system.autoUpgrade.dates = "weekly";
  # Cleanup
  nix.gc.automatic = true;
  nix.gc.dates = "daily";
  nix.gc.options = "--delete-older-than 10d";
  nix.settings.auto-optimise-store = true;
  imports =
      ./hardware-configuration.nix
  # Bootloader.
  # Use latest kernel.
  # networking.proxy.noProxy = "";
  # Enable networking
  # networking.nameservers = [ "8.8.8.8" "1.1.1.1" ];
  # users.users.YOUR_USERNAME.groups = [ "networkmanager" ];
  networking.wireless.enable = false;
  networking.interfaces.wlp3s0.useDHCP = true;
  # Set your time zone.
  time.timeZone = "Europe/Samara";
  i18n.extraLocaleSettings = {
    LC_ADDRESS = "ru_RU.UTF-8";
    LC_IDENTIFICATION = "ru_RU.UTF-8";
    LC_MEASUREMENT = "ru_RU.UTF-8";
    LC_MONETARY = "ru_RU.UTF-8";
    LC_NAME = "ru_RU.UTF-8";
    LC_NUMERIC = "ru_RU.UTF-8";
    LC_PAPER = "ru_RU.UTF-8";
    LC_TELEPHONE = "ru_RU.UTF-8";
    LC_TIME = "ru_RU.UTF-8";
  # Enable the GNOME Desktop Environment.
  services.xserver.desktopManager.gnome.enable = true;
  # Configure keymap in X11
  services.xserver.xkb = {
    layout = "us, ru";
    variant = "";
  # console.useXkbConfig = true;
  # Enable sound with pipewire.
  services.pulseaudio.enable = false;
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    #jack.enable = true;
    #media-session.enable = true;
  users.users.romchik = {
    isNormalUser = true;
    description = "romchik";
    extraGroups = [ "networkmanager" "wheel" "bluetooth"];
    packages = with pkgs; [
    #  thunderbird
  # Install firefox.
  # Allow unfree packages
  # $ nix search wget
  # Swap file
  swapDevices = [ {
    device = "/swapfile";
    size =  16384;
     wget
     vivaldi
     vscode
     zed-editor
     git
     curl
     steam
     firefox
     neofetch
     fastfetch
     wpsoffice-cn
     p7zip
     gnomeExtensions.blur-my-shell
     blueman
    (python3.withPackages (ps: with ps; [
      tkinter
      pip
      virtualenv
    tk
    nodejs
    nodePackages.typescript
    nodePackages.prettier
    rustc
    cargo
    rustfmt
    clippy
    rust-analyzer
    # GNU tools
    gcc
    gdb
    cmake
    gnumake
    xournalpp
  services.blueman.enable = true;
  security.sudo.extraRules = [
      groups = [ "wheel" ];
      commands = [
          command = "/run/current-system/sw/bin/firefox";
          options = [ "NOPASSWD" ];
          command = "/run/current-system/sw/bin/vivaldi";
          command = "/run/current-system/sw/bin/code";
  programs.dconf = {
    profiles.user.databases = [
        settings = {
          "org/gnome/shell" = {
            disable-user-extensions = false;
            enabled-extensions = [ "blur-my-shell@aunetx" ];
  programs.nix-ld.enable = true;
    hardware.bluetooth = {
      powerOnBoot = true;
      settings = {
        # General = {
        #   Enable = "Source, Sink, Media, Socket";
        #   Experimental = true;
  # services.vscode-server.enable = true;
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # Enable the OpenSSH daemon.
  # Open ports in the firewall.
  system.stateVersion = "25.11"; # Did you read the comment?
Right, that’ll explain it. The build for that specific package is currently failing, which means it’s not cached in hydra.
If you ask nix to build a package that isn’t cached, it will try to build it locally. In the case of telegram-desktop, that’s a pretty big build because it’s basically a skin for chrome, which means you’ll be building chrome which can easily take tens of gigabytes of memory and a lot of processing power.
There’s not much you can do about this, occasionally this will just happen if you use those packages.
Electron packages suck for a bunch of other reasons too, like memory use, and even security, since they’re usually relatively outdated versions of chrome that aren’t sandboxed as well. It’d be nice if electron could die already.
Personally, to avoid this, I just use the web versions of these kinds of applications in a normal browser.
I even wrote a wrapper to make them look like separate applications.
