kf5.kservice.services: The desktop entry file "/run/current-system/sw/share/applications/qemu.desktop" has Type= "Application" but no Exec line
kf5.kservice.sycoca: Invalid Service : "/run/current-system/sw/share/applications/qemu.desktop"
Fontconfig warning: FcPattern object weight does not accept value [50 200)
Segmentation fault (core dumped)
here is a hint that this could be related to changes in freedesktop freedesktop
Hi,
might be unrelated but… Few days ago I encounter a similar
font issue after a rebuild. A simple fc-cache -fr as users
and root, reboot, and the issue is gone. It was only on one
machine (my not-much-used laptop) so I think it was a transient
problem, then I here another one with similar problem.
Unfortunately, there were multiple regressions when running apps from unstable on 20.03. They should be fixed now but if you encountered the issue your font cache was corrupted and you need to delete ~/.cache/fontconfig.
You should not need to run fc-cache -r as the NixOS module already generates a fontconfig cache. You will only need it when running apps built against incompatible fontconfig versions but you would need to run fc-cache from the same fontconfig package that the programs are linked against and that is just too annoying IMO. Instead I would recommend just updating 20.03 and unstable channels to the latest respective revision and deleting the cache directory.
the system state is not yet fixed
– system (eg. apps - like cpu monitor, terminal, browser) is freezing again and again
I don’t know if it is related but I would think so
nix-channel --update
/nix/store/ajhpj9prr57qqmralhcj01iaq37q3rg2-home-manager-20.03.drv
building '/nix/store/ajhpj9prr57qqmralhcj01iaq37q3rg2-home-manager-20.03.drv'...
error: unsupported builtin function 'unpack-channel'
builder for '/nix/store/ajhpj9prr57qqmralhcj01iaq37q3rg2-home-manager-20.03.drv' failed with exit code 1
error: --- Error ----------------------------------------------------------------------------------------------------------------------------------- nix-build
build of '/nix/store/ajhpj9prr57qqmralhcj01iaq37q3rg2-home-manager-20.03.drv' failed
error: --- Error --------------------------------------------------------------------------------------------------------------------------------- nix-channel
program '/nix/store/4mm13plq4fa1w4whkmqbplw10b1x1hhy-nix-2.4pre20200622_334e26b/bin/nix-build' failed with exit code 100
