NixOS wont recognize other computers and other computers wont recognize nix os
Hello there
I have two computers one with windows 11 and one with nix-os
I use Local send (https://localsend.org/) to share files between them and synergy (Synergy - Share one mouse & keyboard across computers) to share one keyboard and mouse between them. Back when I used pop-os this worked fine but now that I use nix os these two programs don’t recognise the windows pc and the windows pc doesnt recognize the nix os pc. I have no idea why. They both use static IP addresses and the nix os computers hostname is “nixos” and the windows computers hostname is “littleboy” as the windows computer is smaller. in my configuration.nix i set networking.firewall.enable = false; and networking.useDHCP = false; and the issue persists
Have you ruled out your router? Could be that changing your hostname means that some firewall rules there no longer apply, or something.
I dont think so because I set all my firewall rules based on IP addresses and the IP is still the same as when I used pop os as the ip address is linked to the mac address so that if the mac address is the same the ip address is the same
Can you share your config?
This is my configuration.nix
{ config, pkgs, ... }:
  imports =
      ./hardware-configuration.nix
  # Bootloader.
  # Enable networking
  # Set your time zone.
  time.timeZone = "Australia/Brisbane";
  i18n.defaultLocale = "en_AU.UTF-8";
  i18n.extraLocaleSettings = {
    LC_ADDRESS = "en_AU.UTF-8";
    LC_IDENTIFICATION = "en_AU.UTF-8";
    LC_MEASUREMENT = "en_AU.UTF-8";
    LC_MONETARY = "en_AU.UTF-8";
    LC_NAME = "en_AU.UTF-8";
    LC_NUMERIC = "en_AU.UTF-8";
    LC_PAPER = "en_AU.UTF-8";
    LC_TELEPHONE = "en_AU.UTF-8";
    LC_TIME = "en_AU.UTF-8";
  # You can disable this if you're only using the Wayland session.
  # Enable the KDE Plasma Desktop Environment.
  services.displayManager.sddm.enable = true;
  services.desktopManager.plasma6.enable = true;
  # Configure keymap in X11
  services.xserver = {
    layout = "au";
    xkbVariant = "";
  # Enable sound with pipewire.
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    #jack.enable = true;
    #media-session.enable = true;
  users.users.rudra = {
    isNormalUser = true;
    description = "rudra";
    packages = with pkgs; [
      kdePackages.kate
      thunderbird
  # Install firefox.
  # Allow unfree packages
  # $ nix search wget
    vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
    wget
    opera
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # Enable the OpenSSH daemon.
  # Open ports in the firewall.
  system.stateVersion = "24.05"; # Did you read the comment?
And this is my hardware-configuration.nix
  imports =
  # Bootloader.
  # Enable networking
    layout = "au";
    xkbVariant = "";
    alsa.enable = true;
      kdePackages.kate
      thunderbird
  # Install firefox.
  # $ nix search wget
    wget
    opera
  #   enable = true;
It would appear your firewall is not in fact disabled. Uncomment the networking.firewall.enable line.
Yes! Thank you so much that fixed my issue both synergy and localsend work now!
