I’m trying to use System.Linux.Netlink.Simple
from the netlink hackage package with nix via
$ nix-shell -p "haskell.packages.ghc8107.ghcWithPackages (pkgs: with pkgs; [ netlink ])"
[nix-shell:~/git/github.com/Ongy/netlink-hs/Examples]$ ghc --make ListAddrs.hs
[1 of 1] Compiling Main ( ListAddrs.hs, ListAddrs.o )
ListAddrs.hs:7:1: error:
Could not find module `System.Linux.Netlink.Simple'
Perhaps you meant
System.Linux.Netlink.Route (from netlink-1.1.1.0)
System.Linux.Netlink.C
System.Linux.Netlink.Helpers (from netlink-1.1.1.0)
Use -v (or `:set -v` in ghci) to see a list of the files searched for.
7 | import qualified System.Linux.Netlink.Simple as NLS
I get the same error message with cabal install netlink
on ubuntu
But I did workaround this on ubuntu after a cabal build
and then a cabal install
inside a local git checkout of netlink.
How can I solve this with nix(-shell) ?
