I’m a NixOs newbee! I have installed NixOS 23.11 under VirtualBox 7.0. Unfortunately, I have not yet succeeded in getting my second monitor to run. I have already defined two monitors in the VirtualBox settings. Unfortunately, after starting NixOS the item Display->Virtual Monitor 2->Activate is grayed out. Do someone have any idea what I could do here?
Here’s the output of the xrandr command:
xrandr
Screen 0: minimum 1 x 1, current 1920 x 1080, maximum 16384 x 16384
Virtual1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
800x600 60.00 + 60.32
3840x2400 59.97
3840x2160 59.97
2880x1800 59.95
2560x1600 59.99
2560x1440 59.95
1920x1440 60.00
1856x1392 60.00
1792x1344 60.00
1920x1200 59.88
1920x1080 59.96*
1600x1200 60.00
1680x1050 59.95
1400x1050 59.98
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1360x768 60.02
1280x800 59.81
1152x864 75.00
1280x768 59.87
1280x720 59.86
1024x768 60.00
640x480 59.94
Virtual2 disconnected (normal left inverted right x axis y axis)
Virtual3 disconnected (normal left inverted right x axis y axis)
Virtual4 disconnected (normal left inverted right x axis y axis)
Virtual5 disconnected (normal left inverted right x axis y axis)
Virtual6 disconnected (normal left inverted right x axis y axis)
Virtual7 disconnected (normal left inverted right x axis y axis)
Virtual8 disconnected (normal left inverted right x axis y axis)
