Im trying to install nvidia graphic driver and when I reboot, xfce desktop just break with invisible menu and it is impossible to use brower since is is very slow. I did some research and it is an existing problem on other distros but I don’t know how to resolve it on NixOS.
Here is my configuration:
{ config, pkgs, lib, ... }:
#enable Nvidia driver
hardware.graphics.enable = true;
services.xserver.videoDrivers = ["nvidia" "intel" "modesetting"];
hardware.nvidia.open = false;
hardware.nvidia.prime = {
#Enable sync mode
sync.enable = true;
intelBusId = "PCI:0@0:2:0";
nvidiaBusId = "PCI:1@0:0:0";
#Modesetting is required
hardware.nvidia.modesetting.enable = true;
#Enable Nvidia settings menu,
#accessible via `nvidia-setting`.
hardware.nvidia.nvidiaSettings = true;
#Disable kernel module
#boot.kernelParams = [ "module_blacklist=i915" ];
#Add boot module
boot.extraModulePackages = [
config.boot.kernelPackages.nvidia_x11
config.boot.kernelPackages.lenovo-legion-module
hardware.nvidia.package = config.boot.kernelPackages.nvidiaPackages.stable;
# hardware.nvidia.package = config.boot.kernelPackages.nvidiaPackages.mkDriver {
# version = "580.105.08";
# sha256_64bit = "sha256-2cboGIZy8+t03QTPpp3VhHn6HQFiyMKMjRdiV2MpNHU=";
# sha256_aarch64 = "sha256-2cboGIZy8+t03QTPpp3VhHn6HQFiyMKMjRdiV2MpNHU=";
# openSha256 = "sha256-YvzWO1U3am4Nt5cQ+b5IJ23yeWx5ud1HCu1U0KoojLY=";
# settingsSha256 = "sha256-YvzWO1U3am4Nt5cQ+b5IJ23yeWx5ud1HCu1U0KoojLY=";
# persistencedSha256 = lib.fakeSha256;
my graphic card is rtx4050 laptop.
turned out it was a picom problem, I turned it off and now it works fine. The new problem is the driver is not recognising my second monitor and there is no audio.
Here is my dmesg | grep -C 5 audio output:
[ 4.996938] intel_tcc_cooling: Programmable TCC Offset detected
[ 4.998225] intel_rapl_common: Found RAPL domain package
[ 5.006700] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 5.007356] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 5.007424] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 5.007430] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 5.042690] input: FTCS0038:00 2808:0106 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-FTCS0038:00/0018:2808:0106.000B/input/input23
[ 5.044017] mc: Linux media interface: v0.10
[ 5.044901] input: FTCS0038:00 2808:0106 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-FTCS0038:00/0018:2808:0106.000B/input/input24
[ 5.048155] mousedev: PS/2 mouse device common for all mice
[ 5.052852] hid-multitouch 0018:2808:0106.000B: input,hidraw10: I2C HID v1.00 Mouse [FTCS0038:00 2808:0106] on i2c-FTCS0038:00
[ 15.011059] nvme nvme0: using unchecked data buffer
[ 15.034275] block nvme0n1: No UUID available providing old NGUID
[ 15.168090] Bluetooth: RFCOMM TTY layer initialized
[ 15.168099] Bluetooth: RFCOMM socket layer initialized
[ 15.168102] Bluetooth: RFCOMM ver 1.11
[ 15.939951] pci 0000:00:1f.3: deferred probe pending: snd_hda_intel: couldn't bind with audio component
I have tried everything I could, all the existing no sound help for nixos are having completely different output from me and they use the old audio.enable setting.
