Hey, I just upgraded to 26.05 from 25.11 but it seems like there is an issue with sound, when I try to play sound the app that tried to play it will freeze.
• pipewire‑1.6.5
• wireplumber‑0.5.14
My nix config:
security.rtkit.enable = true;
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
✦ ❯ journalctl --user --unit pipewire --boot
Jun 13 13:19:52 systemd[3232]: Started PipeWire Multimedia Service.
❯ journalctl --user --unit wireplumber --boot
Jun 13 13:19:52 systemd[3232]: Started Multimedia Service Session Manager.
Jun 13 13:19:53 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
[string "rescan.lua"]:47: in global 'checkLinkable'
[string "rescan.lua"]:130: in function <[string "rescan.lua"]:125>
stack traceback:
[string "rescan.lua"]:166: in global 'handleLinkables'
[string "rescan.lua"]:214: in function <[string "rescan.lua"]:194>
Jun 13 13:19:53 wireplumber[3547]: wplua: [string "state-routes.lua"]:39: attempt to call a nil value (global 'Properties')
stack traceback:
[string "state-routes.lua"]:39: in function <[string "state-routes.lua"]:34>
Jun 13 13:19:53 wireplumber[3547]: wplua: [string "find-best-routes.lua"]:30: attempt to call a nil value (global 'Properties')
stack traceback:
[string "find-best-routes.lua"]:30: in function <[string "find-best-routes.lua"]:26>
Jun 13 13:19:53 wireplumber[3547]: wplua: [string "state-routes.lua"]:111: attempt to call a nil value (global 'Properties')
stack traceback:
[string "state-routes.lua"]:111: in function <[string "state-routes.lua"]:109>
stack traceback:
stack traceback:
stack traceback:
Jun 13 13:19:54 wireplumber[3547]: [0:00:59.633266156] [3547] INFO IPAManager ipa_manager.cpp:147 libcamera is not installed. Adding '/nix/store/src/ipa' to the IPA search path
Jun 13 13:19:54 wireplumber[3547]: [0:00:59.634731189] [3547] INFO Camera camera_manager.cpp:340 libcamera v0.6.0
Jun 13 13:19:54 wireplumber[3547]: wplua: [string "state-routes.lua"]:39: attempt to call a nil value (global 'Properties')
stack traceback:
Jun 13 13:19:54 wireplumber[3547]: wplua: [string "find-best-routes.lua"]:30: attempt to call a nil value (global 'Properties')
stack traceback:
Jun 13 13:19:54 wireplumber[3547]: wplua: [string "state-routes.lua"]:111: attempt to call a nil value (global 'Properties')
stack traceback:
Jun 13 13:19:54 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
[string "rescan.lua"]:61: in global 'unhandleLinkable'
[string "rescan.lua"]:110: in function <[string "rescan.lua"]:105>
stack traceback:
stack traceback:
stack traceback:
Jun 13 13:19:54 wireplumber[3547]: wplua: [string "state-routes.lua"]:195: attempt to index a nil value (local 'enum_route_it')
stack traceback:
[string "state-routes.lua"]:195: in function <[string "state-routes.lua"]:169>
stack traceback:
stack traceback:
stack traceback:
stack traceback:
stack traceback:
Jun 13 13:21:06 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:21:08 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:21:36 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:21:38 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:22:01 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:22:31 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:22:36 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:23:01 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:23:06 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
Jun 13 13:23:36 wireplumber[3547]: wplua: [string "rescan.lua"]:47: attempt to call a nil value (method 'get_property')
stack traceback:
