I’ve recently discovered “popcorntime” , a great app to watch videos.
My problem is that for some reasons, I dont get audio for some videos (my pipewire audio setup works pretty well otherwise).
The recommended alternative is in general to use an alternative viewer (the button to open the video open a viewer list when clicking on its right). In my case, it doesn’t detect any alternative viewer: I have vlc and mpv installed.
Here is some log (could not find anything audio related):
$ nix shell nixpkgs#popcorntime
$ popcorntime
[573142:573142:0309/193104.718384:ERROR:policy_logger.cc(157)] :components/enterprise/browser/controller/chrome_browser_cloud_management_controller.cc(163) Cloud management controller initialization aborted as CBCM is not enabled.
[0309/193104.771560:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0309/193104.771761:ERROR:process_memory_range.cc(75)] read out of range
[573142:573191:0309/193104.825057:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[573142:573191:0309/193104.825619:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[573142:573191:0309/193104.832729:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[573172:573172:0309/193104.833351:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
ERR: Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.833432:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.833443:ERROR:gl_display.cc(786)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[573172:573172:0309/193104.833518:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.833538:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.833548:ERROR:gl_display.cc(786)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[573172:573172:0309/193104.833556:ERROR:gl_display.cc(820)] Initialization of all EGL display types failed.
[573172:573172:0309/193104.833570:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[573172:573172:0309/193104.836691:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.836738:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.836746:ERROR:gl_display.cc(786)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[573172:573172:0309/193104.836803:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.836820:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573172:573172:0309/193104.836827:ERROR:gl_display.cc(786)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[573172:573172:0309/193104.836833:ERROR:gl_display.cc(820)] Initialization of all EGL display types failed.
[573172:573172:0309/193104.836839:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[573172:573172:0309/193104.846284:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
[573204:573204:0309/193104.960319:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.960425:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.960441:ERROR:gl_display.cc(786)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[573204:573204:0309/193104.960567:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.960589:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.960598:ERROR:gl_display.cc(786)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[573204:573204:0309/193104.960607:ERROR:gl_display.cc(820)] Initialization of all EGL display types failed.
[573204:573204:0309/193104.960625:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[573204:573204:0309/193104.964027:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.964077:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.964088:ERROR:gl_display.cc(786)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[573204:573204:0309/193104.964203:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.964227:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: Could not dlopen libGL.so.1: libGL.so.1: cannot open shared object file: No such file or directory
[573204:573204:0309/193104.964236:ERROR:gl_display.cc(786)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[573204:573204:0309/193104.964245:ERROR:gl_display.cc(820)] Initialization of all EGL display types failed.
[573204:573204:0309/193104.964251:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[573204:573204:0309/193104.972780:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
[573198:573212:0309/193105.129304:ERROR:command_buffer_proxy_impl.cc(127)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[573176:573183:0309/193108.304534:ERROR:cert_verify_proc_builtin.cc(621)] No net_fetcher for performing AIA chasing.
[573176:573183:0309/193108.380374:ERROR:cert_verify_proc_builtin.cc(621)] No net_fetcher for performing AIA chasing.
[573176:573185:0309/193109.997528:ERROR:cert_verify_proc_builtin.cc(621)] No net_fetcher for performing AIA chasing.
[573176:573183:0309/193115.874470:ERROR:cert_verify_proc_builtin.cc(621)] No net_fetcher for performing AIA chasing.
[573176:573183:0309/193115.946457:ERROR:cert_verify_proc_builtin.cc(621)] No net_fetcher for performing AIA chasing.
[573176:573183:0309/193121.984698:ERROR:cert_verify_proc_builtin.cc(621)] No net_fetcher for performing AIA chasing.
I am curious if anyone with a similar issue knew either how to fix it or how to let popcorntime see VLC for instance ?
