journalctl --user-unit=pipewire -f
Mar 23 21:47:53 nixos systemd[1578]: Started PipeWire Multimedia Service.
Mar 23 21:47:53 nixos pipewire[1814]: spa.alsa: open failed: Invalid argument
Mar 23 21:54:29 nixos systemd[1578]: Stopping PipeWire Multimedia Service...
Mar 23 21:54:29 nixos systemd[1578]: Stopped PipeWire Multimedia Service.
Mar 23 21:54:29 nixos systemd[1578]: pipewire.service: Consumed 6.621s CPU time, 14.7M memory peak.
Mar 23 21:54:29 nixos systemd[1578]: Started PipeWire Multimedia Service.
Mar 23 21:54:29 nixos pipewire[3419]: spa.alsa: open failed: Invalid argument
Ok
I think best is to start over again.
Can you do these steps even if you just did them:
- Revisit Modprobe Options:
Test Legacy Mode Only:
boot.extraModprobeConfig = ''
options snd-intel-dspcfg dsp_driver=1
Then, Test Disabling Digital Mics:
options snd_hda_intel dmic_detect=0
But only one option at a time.
- Reset PipeWire Configuration:
- Removing or moving aside any user-specific PipeWire configuration directories (e.g.
~/.config/pipewire
or~/.local/share/pipewire
). - Restarting your session (or using
systemctl --user restart pipewire
after making changes).
- Examine and Adjust ALSA Settings
- Use
alsamixer
and check all channels (not just “Speakers”) to ensure nothing is muted or set to an extremely low level. Sometimes the analog output might be tied to another control. - List available soundcards with
aplay -l
and verify that your expected device is listed. If not, try reloading the ALSA modules withsudo modprobe -r snd_hda_intel && sudo modprobe snd_hda_intel
- Try out the older LTS Kernel 6.6 with
boot.kernelPackages = pkgs.linuxKernel.kernels.linux_6_6;
