No such interface “org.freedesktop.portal.Settings”
I can’t seem to open file pickers any more.
For example, if I click “Save page as…” from within Zen (Firefox fork), or “Save as…” from within Thunderbird, no file picker is displayed.
From the command line, if I run:
zenity --file-selection
I get:
(zenity:9469): Gdk-WARNING **: 22:01:27.172: Failed to read portal settings: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.portal.Settings” on object at path /org/freedesktop/portal/desktop
Any guidance on how I can get this working again?
Please share any portal-related config you have.
Also, what DE/compositor do you use?
I am running hyprland.
configuratoin.nix:
programs.hyprland = {
    package = inputs.hyprland.packages.${pkgs.stdenv.hostPlatform.system}.hyprland;
    portalPackage = inputs.hyprland.packages.${pkgs.stdenv.hostPlatform.system}.xdg-desktop-portal-hyprland;
xdg.portal = {
    extraPortals = [ pkgs.xdg-desktop-portal-gtk ];
    config = {
      hyprland = {
        default = [ "hyprland" "gtk" ];
That config actually looks perfectly normal. Are there any errors on the systemd user services associated with those portals?
Getting a similar error when opening a newly created .md file in yazi. All other markdown files open fine.
Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.portal.OpenURI” on object at path /org/freedesktop/portal/desktop
Exited with status code: 4
Process failed
My xdg related configuration.nix code:
xdg.autostart.enable = true;
  xdg.portal = {
    extraPortals = with pkgs; [
    config = {
      hyprland = {
If anyone has any sugggestions, it would be a big help.
Had to comment out an env var, add a couple xdg configs, and enable rtkit security for a dbus/pipewire error. Hope that helps any passersby.
    # NIXOS_XDG_OPEN_USE_PORTAL = "1"; # Disabled - causes issues with OpenURI portal interface
  security.rtkit.enable = true;
  xdg.portal = {
      xdg-desktop-portal
    config = {
      common = {
        default = [ "gtk" ];
        "org.freedesktop.impl.portal.Secret" = [ "gnome-keyring" ];
      hyprland = {
        "org.freedesktop.impl.portal.FileChooser" = [ "gtk" ];
        "org.freedesktop.impl.portal.OpenURI" = [ "gtk" ];
Worth noting the xdg-desktop-portal is needed to resolve the OpenURI error that I originally posted. Neither xdg-desktop-portal-hyprland or xdg-desktop-portal-gtk provide OpenURI.
I am setting up my new PC right now and I am running into the same issue, not sure if i fixed it not declarative before and have to deal with it again now, or if this is a new issue.
@guttermonk solution fixed part of my issue, I now have the FileChooser again, but for me gnome-keyring (when 1password tries to save the mfa token) (gnome-keyring was fixed by using gdm which properly unlocks it) and OpenUri don’t work. OpenUri worked with website links once (maybe I clicked set default browser or something?) yesterday, but after the reboot it is back to not working
I had the same problem for a couple of days now and the problem was that my browser (librewolf) decided to take a break from being my default browser. Upon installing another browser (brave) everything worked fine for me. I have “workaround” with simply specifying the mime types to use librewolf, it could be a coincidence but may I ask, which browser do you guys use?
Here the mime list:
xdg = {
    mime = {
      defaultApplications = {
        "text/html" = [ "librewolf.desktop" ];
        "x-scheme-handler/http"  = [ "librewolf.desktop" ];
        "x-scheme-handler/https" = [ "librewolf.desktop" ];
