Hi,
I am a newbie who just started using nixos (unstable). I followed advice from this article but I am not having any luck creating even the most simple python shell. For example, I tried following shell.nix
my-python = pkgs.python3;
python-with-my-packages = my-python.withPackages (p: with p; [
oscrypto
pkgs.mkShell {
buildInputs = [
shellHook = ''
PYTHONPATH=${python-with-my-packages}/${python-with-my-packages.sitePackages}
After I run nix-shell I do get a python interpreter with oscrypto package installed, but I get an exception
python -c 'from oscrypto import asymmetric' 10.0.2.15 via ❄️ impure (nix-shell)
File "<string>", line 1, in <module>
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/asymmetric.py", line 19, in <module>
from ._asymmetric import _unwrap_private_key_info
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/_asymmetric.py", line 27, in <module>
from .kdf import pbkdf1, pbkdf2, pkcs12_kdf
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/kdf.py", line 9, in <module>
from .util import rand_bytes
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/util.py", line 14, in <module>
from ._openssl.util import rand_bytes
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/_openssl/util.py", line 6, in <module>
from ._libcrypto import libcrypto, libcrypto_version_info, handle_openssl_error
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/_openssl/_libcrypto.py", line 15, in <module>
from ._libcrypto_ctypes import (
File "/nix/store/na2ysz3s2cfx5m60h4h5fa0k6hczgxkw-python3-3.9.10-env/lib/python3.9/site-packages/oscrypto/_openssl/_libcrypto_ctypes.py", line 28, in <module>
raise LibraryNotFoundError('The library libcrypto could not be found')
oscrypto.errors.LibraryNotFoundError: The library libcrypto could not be found
However, if I use nix-shell -p python39Packages.oscrypto, I don’t get the above error. I am now totally confused about what am I doing wrong. My ultimate goal is to replace a traditional python virtualenv that I normally use to develop several python packages.
Thank you.
