My NUR keeps having issues in the github CI, but I can’t replicate these at all.
error: builder for '/nix/store/nzxm3yb9fvc2srn24mq2wb2b7lvds7dh-harbor-1.6.4-b1.drv' failed with exit code 1;
last 10 log lines:
> [INFO] Finished at: 2023-11-19T20:10:59Z
> [INFO] ------------------------------------------------------------------------
Error: > [ERROR] Plugin org.apache.maven.plugins:maven-resources-plugin:3.3.1 or one of its dependencies could not be resolved: The following artifacts could not be resolved: org.apache.maven.plugins:maven-resources-plugin:jar:3.3.1 (absent): Cannot access central (https://repo.maven.apache.org/maven2) in offline mode and the artifact org.apache.maven.plugins:maven-resources-plugin:jar:3.3.1 has not been downloaded from it before. -> [Help 1]
Error: > [ERROR]
Error: > [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
Error: > [ERROR] Re-run Maven using the -X switch to enable full debug logging.
Error: > [ERROR]
Error: > [ERROR] For more information about the errors and possible solutions, please read the following articles:
Error: > [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginResolutionException
For full logs, run 'nix log /nix/store/nzxm3yb9fvc2srn24mq2wb2b7lvds7dh-harbor-1.6.4-b1.drv'.
nix-build-uncached: nix build failed: exit status 1
Error: Process completed with exit code 1.
Shouldn’t this lead to the same error?
nix shell -I nixpkgs=channel:nixos-unstable -f '<nixpkgs>' nix-build-uncached -c nix-build-uncached ci.nix -A cacheOutputs
my only guess is that when i ran this against 23.05 it already cached those maven artifacts but nixos-unstable buildMaven is broken?
