Nvidia driver detected wrong monitor resolution!
My laptop has the following VGA controller:
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1000M] (rev a1)
After upgrading my NixOs to 21.05, I found my NixOs very lazy and slow in detecting my second monitor. So I decided to install the NVidia driver:
After that, that problem solved and now, I can plugin in my second monitor instantly and it will affect under the second.
But now, I have another problem. The Nvidia driver cannot detect my second monitor’s maximum resolution.
So what should I do? Does anyone have an idea to fix this problem?
My second monitor is LG 29UM68-P 29" 21:9 UltraWide which with a 2560 x 1080 resolution. But the Nvidia driver detects that as a 1920x1080 screen.
When I click on the resolution menu list, the maximum resolution is not 2560x1080:
Here is the output of xrandr -q:
Screen 0: minimum 8 x 8, current 3520 x 1080, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
LVDS-0 connected 1600x900+0+180 (normal left inverted right x axis y axis) 345mm x 194mm
   1600x900      60.03*+  40.02
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 1920x1080+1600+0 (normal left inverted right x axis y axis) 798mm x 334mm
   1920x1080     60.00*+  59.94    50.00    29.97    60.05    60.00    50.04
   1680x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       59.94
   640x480       75.00    59.94    59.93
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-6 disconnected (normal left inverted right x axis y axis)
Does another OS detect the resolution properly using same port, cable and screen?
Perhaps some parts don’t support necessary data rates?
Before upgrading to 21.05, It was on 20.09 without Nvidia driver. My screen was ok and without any problem. After upgrading to 21.05 I found that changing between dual monitor to single monitor or switching between them is very slow on 21.05. But the resolution was ok.
So I decided to install Nvidia. After that, the first problem fixed and now I can switch between monitors very fastly without any defect. But the second problem occurred and the driver cannot detect the exact resolution of my external monitor.
