Hi! I have encountered a funky issue with my new Legion Slim 5 laptop, and do not really understand what could be happening.
My issue is a little simular to NVIDIA power saving misbehaving when disconnecting laptop from power, but different in the sense that my laptop just completely powers off when (dis)connecting from wall-power.
I have the following relevant configuration (PCIs are set somewhere else):
# offload
(mkIf (cfg.enable && cfg.mode == "offload") {
hardware.nvidia.prime = {
offload = {
enableOffloadCmd = true;
# when disabling this line the issue does not appear!
hardware.nvidia.powerManagement.finegrained = mkDefault true;
# add a special boot entry NVIDIA Sync mode for gaming
specialisation = {
gaming.configuration = {
programs.gamemode.enable = true;
hardware.nvidia.powerManagement.finegrained = false;
hardware.nvidia = {
prime.sync.enable = lib.mkForce true;
prime.offload = {
enable = lib.mkForce false;
enableOffloadCmd = lib.mkForce false;
When in the GRUB menu the issue does not appear
When booted to my regular boot entry, so in offload mode, my the issue appears.
When I comment out the line containing finegrained = mkDefault true
, the issue does not appear
When booted to the gaming specialization, so in sync mode the issue does not appear.
My conclusion: the issue is with enabling finegrained mode, which I would like to do in order to save some power.
What does finegrained = true
do exactly, and can I fix this somehow?
