Odoo addons help
I’ve been playing around with the Odoo module and was wondering if I can add an addon directory? I’ve added addon_path to the options in the config but I’m not sure its working. I added a few odoo modules in that dir but can’t get the ui to show them. It could very much be my issue as a first time Odoo user…
Also, in the config there is an option to add addons declaratively… are there any packaged and I’m just not finding them?
thanks for any guidance!
So it was my newbie-ness that was the problem. I didn’t have the correct permissions on the addon folder! Now it works. :melting_face:
