Offline automated installation images for Disko
I’ve opened a PR for Disko that adds NixOS installer image generation to the flake-parts module
This means you can easily partition, create file systems, and install a hosts configuration with a single command, without network access from a simple installer image
I encourage anyone to check it out, and leave feedback or show your support if you want this to be merged! I’ve included some example usage on the PR
