I understand that Ollama can use either AMD or NVIDIA gpus, and that it’s normally defined like so:
# enable Ollama
services.ollama = {
acceleration = "cuda"; # "cuda" or "rocm"
I also found this on the GitHub page, and I’m trying to make some sense out of it as well:
acceleration = lib.mkOption {
type = types.nullOr (types.enum [ false "rocm" "cuda" ]);
default = null;
example = "rocm";
description = ''
What interface to use for hardware acceleration.
- `null`: default behavior
if `nixpkgs.config.rocmSupport` is enabled, uses `"rocm"`
if `nixpkgs.config.cudaSupport` is enabled, uses `"cuda"`
otherwise defaults to `false`
- `false`: disable GPU, only use CPU
- `"rocm"`: supported by most modern AMD GPUs
- `"cuda"`: supported by most modern NVIDIA GPUs
But If I were using this drive on other devices with different GPUs (NVIDIA, or AMD, or vice versa), how can I define GPU “acceleration”? So for instance, could I use lib.mkForce
as eitiher "true or false"
to indicate which GPU to use?
How can I write this in a config.nix file?
