Hello
I’m not entirely sure. But it looks like after switching to the Gnome desktop and recently making changes to the sound settings, stereo recordings are no longer possible. To test this, I started Qjackctl and connected it to Audacity. There’s only one channel. What’s going on?
Btw, on a fresh Gnome with no changes made on the config it is the same…
Here are the sound settings. The audio interface is an external USB card with 2x XLR in…
# Remove sound.enable or set it to false if you had it set previously, as sound.enable is only meant for ALSA-based configurations
# rtkit is optional but recommended
hardware.pulseaudio.enable = false; # only for Gnome DE
security.rtkit.enable = true;
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
jack.enable = true;
