I found that running nix run nixpkgs.glxinfo -c glxinfo on my machine sends back :
libGL error: MESA-LOADER: failed to open radeonsi (search paths /run/opengl-driver/lib/dri)
libGL error: failed to load driver: radeonsi
libGL error: MESA-LOADER: failed to open swrast (search paths /run/opengl-driver/lib/dri)
libGL error: failed to load driver: swrast
X Error of failed request: GLXBadContext
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 6 (X_GLXIsDirect)
Serial number of failed request: 60
Current serial number in output stream: 59
while still the search paths do contain the libraries :
dr-xr-xr-x - root 1 janv. 1970 d3d
dr-xr-xr-x - root 1 janv. 1970 dri
lrwxrwxrwx 16 root 1 janv. 1970 libEGL_mesa.so -> libEGL_mesa.so.0
lrwxrwxrwx 20 root 1 janv. 1970 libEGL_mesa.so.0 -> libEGL_mesa.so.0.0.0
.r-xr-xr-x 326k root 1 janv. 1970 libEGL_mesa.so.0.0.0
lrwxrwxrwx 16 root 1 janv. 1970 libGLX_mesa.so -> libGLX_mesa.so.0
lrwxrwxrwx 20 root 1 janv. 1970 libGLX_mesa.so.0 -> libGLX_mesa.so.0.0.0
.r-xr-xr-x 657k root 1 janv. 1970 libGLX_mesa.so.0.0.0
.r-xr-xr-x 8,4M root 1 janv. 1970 libvulkan_intel.so
.r-xr-xr-x 7,0M root 1 janv. 1970 libvulkan_radeon.so
lrwxrwxrwx 17 root 1 janv. 1970 libxatracker.so -> libxatracker.so.2
lrwxrwxrwx 21 root 1 janv. 1970 libxatracker.so.2 -> libxatracker.so.2.5.0
.r-xr-xr-x 6,4M root 1 janv. 1970 libxatracker.so.2.5.0
.r-xr-xr-x 7,1M root 1 janv. 1970 libXvMCnouveau.so
.r-xr-xr-x 7,1M root 1 janv. 1970 libXvMCr600.so
dr-xr-xr-x - root 1 janv. 1970 vdpau
The module controlling my configuration for this is just :
{ config, pkgs, lib, ... }:
with lib;
options.perso.gaming = mkEnableOption "Enable the gaming configuration on Hyperion";
config = mkIf config.perso.gaming {
# Using kernel parameters that supports the GPU (AMD Radeon R9 290X (Hawaii XT))
boot = with pkgs; {
kernelParams = [
"radeon.si_support=0"
"radeon.cik_support=0" # Disables Radeon CIK(Sea Island) Support
"amdgpu.si_support=0"
"amdgpu.cik_support=1" # Enables AMDGPU CIK(Sea Island) Support
"amdgpu.modeset=1"
"amdgpu.dc=1" # Enables Display Core driver
# Using the aforementionned driver
services.xserver.videoDrivers = [ "amdgpu" ];
# Using OpenGL as a fallback in case of non-working GPU config
hardware.opengl = {
driSupport = true;
driSupport32Bit = true;
The output of nix-shell -p nix-info --run "nix-info -m" is :
- system: `"x86_64-linux"`
- host os: `Linux 5.7.8, NixOS, 20.03.2533.76adfc180c0 (Markhor)`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.3.6`
- channels(root): `"nixos-20.03.2593.aaa66d8d887, home-manager-19.03"`
- channels(sirc): `"home-manager-19.03, nixos-20.03-20.03.2528.e69cfc351be, nixos-unstable-20.09pre234242.c71518e75bf, nixpkgs-20.09pre234831.e97fdce4e1b"`
- nixpkgs: `/home/sirc/.nix-defexpr/channels/nixpkgs`
Would anyone have an idea of why is that ?
