Opening link in sway does not work (xdg-open works)
If I open try to open a link in a desktop app (e.g. element) nothing happens. If I do the same thing with xdg-open it works.
My config for the portal is modules/wayland.nix · master · Florian Engel / nixosconfiguration · GitLab
I start sway with modules/wayland.nix · master · Florian Engel / nixosconfiguration · GitLab. I also tried adding `dbus-run-session` like suggested here Issue with xdg-open in sway - #2 by ketamin00 . Which did not change the behavior.
dbus-monitor shows
method call time=1773471980.121541 sender=:1.64 -> destination=org.freedesktop.DBus serial=1 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=Hello
method return time=1773471980.121590 sender=org.freedesktop.DBus -> destination=:1.64 serial=1 reply_serial=1
   string ":1.64"
signal time=1773471980.121626 sender=org.freedesktop.DBus -> destination=(null destination) serial=125 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameOwnerChanged
   string ":1.64"
   string ""
   string ":1.64"
signal time=1773471980.121681 sender=org.freedesktop.DBus -> destination=:1.64 serial=2 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameAcquired
   string ":1.64"
method call time=1773471980.122069 sender=:1.64 -> destination=org.freedesktop.DBus serial=2 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=GetNameOwner
   string "org.gnome.SessionManager"
error time=1773471980.122101 sender=org.freedesktop.DBus -> destination=:1.64 error_name=org.freedesktop.DBus.Error.NameHasNoOwner reply_serial=2
   string "Could not get owner of name 'org.gnome.SessionManager': no such name"
signal time=1773471980.123239 sender=org.freedesktop.DBus -> destination=:1.64 serial=4 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameLost
   string ":1.64"
signal time=1773471980.123284 sender=org.freedesktop.DBus -> destination=(null destination) serial=126 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameOwnerChanged
   string ":1.64"
   string ":1.64"
   string ""
method call time=1773471980.236231 sender=:1.65 -> destination=org.freedesktop.DBus serial=1 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=Hello
method return time=1773471980.236274 sender=org.freedesktop.DBus -> destination=:1.65 serial=1 reply_serial=1
   string ":1.65"
signal time=1773471980.236328 sender=org.freedesktop.DBus -> destination=(null destination) serial=127 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameOwnerChanged
   string ":1.65"
   string ""
   string ":1.65"
signal time=1773471980.236382 sender=org.freedesktop.DBus -> destination=:1.65 serial=2 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameAcquired
   string ":1.65"
method call time=1773471980.236610 sender=:1.65 -> destination=org.freedesktop.DBus serial=2 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=GetNameOwner
error time=1773471980.236640 sender=org.freedesktop.DBus -> destination=:1.65 error_name=org.freedesktop.DBus.Error.NameHasNoOwner reply_serial=2
signal time=1773471980.237784 sender=org.freedesktop.DBus -> destination=:1.65 serial=4 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameLost
   string ":1.65"
signal time=1773471980.237830 sender=org.freedesktop.DBus -> destination=(null destination) serial=128 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameOwnerChanged
   string ":1.65"
   string ":1.65"
   string ""
did you enable desktop portals?
try:
xdg.portal = {
        xdgOpenUsePortal = true;
        wlr.enable = true;
        extraPortals = with pkgs; [
            xdg-desktop-portal-gtk
Yes, I linked above to the part of my config that does that.
sry, didnt see that.
you use homemanager, i have no experience with that. regardless i once had this problem and it turned out to be systemd related. i fixed it with:
programs.sway.extraSessionCommands = " systemctl --user import-environment PATH # fix: xdg-open"
@StillerHarpo did you fix it?
No your extraSessionCommand did not fix it. With your change xdg-open also stopped working.
$ xdg-open “https://www.test.de/”Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.portal.OpenURI” on object at path /org/freedesktop/portal/desktop
I fixed it by moving the portal config from home-manager to the system configuration.
