Hey everyone,
Problem
After installing NixOS on my new Lenovo Yoga Pro 7 14APH8, Audio does work, but both using PipeWire and PulseAudio the sound is either muted or 100%.
First I tried to search information about the codec not working, but that proved to be a dead end. (There’s other people having trouble with this ALC3306/ALC287)
I managed to find a lead by changing the PCM channel using alsamixer, which did change the audio level and led me to this topic about overriding PulseAudio files.
PulseAudio
I managed to get it working with PulseAudio, which I’m very happy with. I used the following code snippet and assign it to hardware.pulseaudio.package:
Code Snippet
pkgs.pulseaudio.overrideAttrs (old: {
pname = "${old.pname}-patched-with-pcm-control";
# Instead of overriding some post-build action, which would require a
# pulseaudio rebuild, we override the entire `buildCommand` to produce
# its outputs by copying the original package's files (much faster).
buildCommand = ''
set -euo pipefail
${# Copy original files, for each split-output (`out`, `dev` etc.).
lib.concatStringsSep "\n"
(map
(outputName:
echo "Copying output ${outputName}"
set -x
cp -a ${pkgs.pulseaudio.${outputName}} ''$${outputName}
set +x
old.outputs
# Find this file: share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
# and add these three lines:
# [Element Master]
# switch = mute
# volume = ignore
# Directly above of this part of code:
# [Element PCM]
# switch = mute
# volume = merge
# override-map.1 = all
# override-map.2 = all-left,all-right
set -x
INFILE=$out/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
sed 's/\[Element PCM\]/\[Element Master\]\nswitch = mute\nvolume = ignore\n\n[Element PCM]/' $INFILE > tmp.conf
# Ensure file changed (something was replaced)
! cmp tmp.conf $INFILE
chmod +w $out/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
cp tmp.conf $INFILE
set +x
PipeWire
However, using PipeWire, if I use the following code snippet and assign it to services.pipewire.package, it does not work.
Code Snippet
pkgs.pipewire.overrideAttrs (old: {
# name = "pulseaudio-patched";
buildCommand = ''
set -euo pipefail
(map
(outputName:
set -x
cp -a ${pkgs.pipewire.${outputName}} ''$${outputName}
set +x
old.outputs
# Find this file: /nix/store/vr4mv8jppbvr96ml2chlgikmy6f9crb7-pipewire-0.3.80-lib/share/alsa-card-profile/mixer/paths/analog-output.conf.common
# [Element Master]
# switch = mute
# volume = ignore
# [Element PCM]
# switch = mute
# volume = merge
set -x
INFILE=$lib/share/alsa-card-profile/mixer/paths/analog-output.conf.common
chmod +w $lib/share/alsa-card-profile/mixer/paths/analog-output.conf.common
cp tmp.conf $INFILE
set +x
After applying the last code snippet, I see two new pipewire folders being added to the nix store (of which one my modified one), and I see pulseaudio is also added to the nix store, but nothing seems to change for my audio settings.
In the PipeWire wiki page I saw that editing these configuration options (package = [...]) shouldn’t work and that one should put drop-in files in /etc/pipewire/pipewire.conf.d/. I don’t know how I would achieve the same using these configuration files, would anyone be able to help? I saw this topic (and this one) that might be of help. In the end, that person uses alsa-card-profiles to fix the issue, but that won’t help us, because it’s also a part of pipewire-lib…
Actually, I just ran into this patch, which I might just try and see if it works. (Although it didn’t fix the issue for the OP).
Question
How should I go about fixing this for PipeWire?
Should I report this issue perhaps somewhere? A workaround should perhaps be only temporary until the issue is resolved.
Curious to hear what you think of the way I solved it for PulseAudio and what you think is the best way to try to fix this for PipeWire!
Thanks in advance ![]()
